#1 Today 03:26:06
dgh
How do I report a bad hyperlink in a package description? (Debian?)
Hi, I recently came back to Devuan after years using MX.
Muscle memory-- tried to open a calculator, realized one wasn't installed.
Went to install Galculator and clicked on the "Homepage" link in the package description and it brought me to some unrelated bullshit.
I'm assuming this is a Debian problem and not a Devuan problem but figured I'd ask here what, if anything, I should report.
Thanks!
#2 Today 04:12:41
Re: How do I report a bad hyperlink in a package description? (Debian?)
Yes it's a debian package (not forked). First go to bugs.debian.org an check if it's been reported already, and then maybe add to that. Otherwise as per instructions, send an email to submit@bugs.debian.org with the first two body lines nominating package and version.
