#1 2026-07-08 14:43:07
deepforest
[SOLVED] UMAX AstraSlim SE - Invalid argument
Excalibur
All did according instructions but scanner not working, please help)
https://cromwell-intl.com/open-source/x … ument.html
https://wiki.debian.org/UMAXAstraSlimSE
root@devuan:/usr/share/sane/artec_eplus48u# scanimage -L
device `artec_eplus48u:libusb:001:005' is a UMAX AstraSlim SE flatbed scanner
root@devuan:/usr/share/sane/artec_eplus48u# ls -l /dev/bus/usb/001/005
crw-rw-r-- 1 root root 189, 4 Jul  8 17:37 /dev/bus/usb/001/005
root@devuan:/usr/share/sane/artec_eplus48u# scanimage --device genesys:libusb:001:005 --format=tiff >test.tiff
scanimage: open of device genesys:libusb:001:005 failed: Invalid argument
smile
pyzNi 3.14zDa! smile
#2 2026-07-08 15:02:33
kapqa
Re: [SOLVED] UMAX AstraSlim SE - Invalid argument
you still could try the "forever" trick
sudo apt-get remove ipp-usb
reboot, try again, have luck.
#3 2026-07-09 13:51:45
deepforest
done, not help(
freeartist-devuan@devuan:~$ sudo scanimage --device artec_eplus48u:libusb:001:005 --format=tiff >test.tiff
scanimage: open of device artec_eplus48u:libusb:001:005 failed: Invalid argument
smile
#4 2026-07-09 14:41:44
deepforest
dmesg
[    4.826539] udevd[692]: GOTO 'libsane_rules_end' has no matching label in: '/etc/udev/rules.d/40-libsane.rules'
[    4.896201] udevd[692]: GOTO 'libsane_rules_end' has no matching label in: '/etc/udev/rules.d/S99-2000S1.rules'
generated by hplip for some HP printers?
i have HP1018 installed
smile
#5 2026-07-09 15:41:35
kapqa
remember some 5-8 years ago when ürchased the first ecotank printer,
that it was difficult sometime to scan with certain programs, not all would function equal, so i tired them through, (all) the different programs that were available,
and not all would function for the scanner for some reason or another; even the epson program itself would not function; so i started installing drivers etc, but since a lot has changed;
have an old samsung all-in-one here (relegated to shelve, since it laser), might aswell test it wout someday to see if can get scanning to function.
sometimes i do chit-chat-with gemini-chatbot since ma curiuos being;
but it warns that the answers can be inaccurate.
To grant your Linux system permissions to use an Epson scanner without root access, you must create a custom udev rule. This assigns the device to the scanner group and sets appropriate read/write permissions.Step 1: Find your Vendor and Product IDOpen a terminal and type lsusb. Look for your Epson device in the list and note down its IDs, which look similar to 04b8:012f (where 04b8 is the Vendor ID and 012f is the Product ID).Step 2: Create the udev RuleOpen a new rule file in your preferred text editor (e.g., Nano) with superuser privileges:sudo nano /etc/udev/rules.d/99-epson-scanner.rulesAdd the following line (replace YOUR_VENDOR_ID and YOUR_PRODUCT_ID with the numbers from Step 1):SUBSYSTEM=="usb", ATTRS{idVendor}=="YOUR_VENDOR_ID", ATTRS{idProduct}=="YOUR_PRODUCT_ID", MODE="0666", GROUP="scanner", ENV{libsane_matched}="yes"
Save the file and exit the text editor.Step 3: Apply and VerifyReload the udev rules for the changes to take effect:sudo udevadm control --reload-rulesUnplug your scanner's USB cable and plug it back in.Check if your user account is in the scanner group (if not, add it using sudo usermod -a -G scanner $USER).Run scanimage -L in your terminal to verify that your Epson scanner is detected.For more technical background on writing hardware rules, you can refer to general guides on Writing udev rules.Could you tell me the exact model of your Epson scanner and which Linux distribution you are using? This will allow me to provide the exact idVendor and idProduct numbers for your device, or help you troubleshoot specific SANE driver issues if they arise.
#6 2026-07-09 20:16:39
deepforest
add line
ATTRS{idVendor}=="05d8", ATTRS{idProduct}=="4009", MODE="0666", GROUP="scanner", ENV{libsane_matched}="yes"
export SANE_DEBUG_DLL=255 && scanimage -L
freeartist-devuan@devuan:~$ export SANE_DEBUG_DLL=255 && scanimage -L
[23:14:03.015078] [sanei_debug] Setting debug level of dll to 255.
[23:14:03.015138] [dll] sane_init: SANE dll backend version 1.0.13 from sane-backends 1.4.0
[23:14:03.015158] [dll] sane_init/read_dlld: attempting to open directory `./dll.d'
[23:14:03.015187] [dll] sane_init/read_dlld: attempting to open directory `/usr/local/etc/sane.d/dll.d'
[23:14:03.015214] [dll] sane_init/read_dlld: using config directory `/usr/local/etc/sane.d/dll.d'
[23:14:03.015264] [dll] sane_init/read_dlld: done.
[23:14:03.015291] [dll] sane_init/read_config: reading dll.conf
[23:14:03.015325] [dll] add_backend: adding backend `net'
[23:14:03.015347] [dll] add_backend: adding backend `abaton'
[23:14:03.015362] [dll] add_backend: adding backend `agfafocus'
[23:14:03.015377] [dll] add_backend: adding backend `apple'
[23:14:03.015390] [dll] add_backend: adding backend `artec'
[23:14:03.015403] [dll] add_backend: adding backend `artec_eplus48u'
[23:14:03.015416] [dll] add_backend: adding backend `as6e'
[23:14:03.015429] [dll] add_backend: adding backend `avision'
[23:14:03.015442] [dll] add_backend: adding backend `bh'
[23:14:03.015455] [dll] add_backend: adding backend `canon'
[23:14:03.015469] [dll] add_backend: adding backend `canon630u'
[23:14:03.015483] [dll] add_backend: adding backend `canon_dr'
[23:14:03.015496] [dll] add_backend: adding backend `canon_lide70'
[23:14:03.015508] [dll] add_backend: adding backend `cardscan'
[23:14:03.015522] [dll] add_backend: adding backend `coolscan'
[23:14:03.015535] [dll] add_backend: adding backend `coolscan3'
[23:14:03.015548] [dll] add_backend: adding backend `dell1600n_net'
[23:14:03.015561] [dll] add_backend: adding backend `dmc'
[23:14:03.015575] [dll] add_backend: adding backend `epjitsu'
[23:14:03.015588] [dll] add_backend: adding backend `epson2'
[23:14:03.015601] [dll] add_backend: adding backend `epsonds'
[23:14:03.015614] [dll] add_backend: adding backend `escl'
[23:14:03.015627] [dll] add_backend: adding backend `fujitsu'
[23:14:03.015641] [dll] add_backend: adding backend `genesys'
[23:14:03.015654] [dll] add_backend: adding backend `gt68xx'
[23:14:03.015672] [dll] add_backend: adding backend `hp'
[23:14:03.015686] [dll] add_backend: adding backend `hp3500'
[23:14:03.015700] [dll] add_backend: adding backend `hp3900'
[23:14:03.015713] [dll] add_backend: adding backend `hp4200'
[23:14:03.015725] [dll] add_backend: adding backend `hp5400'
[23:14:03.015739] [dll] add_backend: adding backend `hp5590'
[23:14:03.015752] [dll] add_backend: adding backend `hpljm1005'
[23:14:03.015766] [dll] add_backend: adding backend `hpsj5s'
[23:14:03.015778] [dll] add_backend: adding backend `hs2p'
[23:14:03.015792] [dll] add_backend: adding backend `ibm'
[23:14:03.015805] [dll] add_backend: adding backend `kodak'
[23:14:03.015818] [dll] add_backend: adding backend `kodakaio'
[23:14:03.015833] [dll] add_backend: adding backend `kvs1025'
[23:14:03.015846] [dll] add_backend: adding backend `kvs20xx'
[23:14:03.015859] [dll] add_backend: adding backend `kvs40xx'
[23:14:03.015873] [dll] add_backend: adding backend `leo'
[23:14:03.015886] [dll] add_backend: adding backend `lexmark'
[23:14:03.015899] [dll] add_backend: adding backend `ma1509'
[23:14:03.015913] [dll] add_backend: adding backend `magicolor'
[23:14:03.015926] [dll] add_backend: adding backend `matsushita'
[23:14:03.015939] [dll] add_backend: adding backend `microtek'
[23:14:03.015954] [dll] add_backend: adding backend `microtek2'
[23:14:03.015967] [dll] add_backend: adding backend `mustek'
[23:14:03.015985] [dll] add_backend: adding backend `mustek_usb'
[23:14:03.016000] [dll] add_backend: adding backend `mustek_usb2'
[23:14:03.016014] [dll] add_backend: adding backend `nec'
[23:14:03.016027] [dll] add_backend: adding backend `niash'
[23:14:03.016041] [dll] add_backend: adding backend `pie'
[23:14:03.016054] [dll] add_backend: adding backend `pieusb'
[23:14:03.016068] [dll] add_backend: adding backend `pint'
[23:14:03.016081] [dll] add_backend: adding backend `pixma'
[23:14:03.016095] [dll] add_backend: adding backend `plustek'
[23:14:03.016109] [dll] add_backend: adding backend `qcam'
[23:14:03.016123] [dll] add_backend: adding backend `ricoh'
[23:14:03.016136] [dll] add_backend: adding backend `ricoh2'
[23:14:03.016150] [dll] add_backend: adding backend `rts8891'
[23:14:03.016163] [dll] add_backend: adding backend `s9036'
[23:14:03.016176] [dll] add_backend: adding backend `sceptre'
[23:14:03.016190] [dll] add_backend: adding backend `sharp'
[23:14:03.016203] [dll] add_backend: adding backend `sm3600'
[23:14:03.016217] [dll] add_backend: adding backend `sm3840'
[23:14:03.016230] [dll] add_backend: adding backend `snapscan'
[23:14:03.016244] [dll] add_backend: adding backend `sp15c'
[23:14:03.016258] [dll] add_backend: adding backend `tamarack'
[23:14:03.016272] [dll] add_backend: adding backend `teco1'
[23:14:03.016285] [dll] add_backend: adding backend `teco2'
[23:14:03.016304] [dll] add_backend: adding backend `teco3'
[23:14:03.016318] [dll] add_backend: adding backend `u12'
[23:14:03.016332] [dll] add_backend: adding backend `umax'
[23:14:03.016347] [dll] add_backend: adding backend `umax1220u'
[23:14:03.016360] [dll] add_backend: adding backend `v4l'
[23:14:03.016374] [dll] add_backend: adding backend `xerox_mfp'
[23:14:03.016403] [dll] sane_get_devices
[23:14:03.016419] [dll] load: searching backend `xerox_mfp' in `/usr/local/lib/sane'
[23:14:03.016432] [dll] load: trying to load `/usr/local/lib/sane/libsane-xerox_mfp.so.1'
[23:14:03.016453] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-xerox_mfp.so.1'
[23:14:03.016617] [dll] init: initializing backend `xerox_mfp'
[23:14:03.019217] [dll] init: backend `xerox_mfp' is version 1.0.13
[23:14:03.020566] [dll] load: searching backend `v4l' in `/usr/local/lib/sane'
[23:14:03.020585] [dll] load: trying to load `/usr/local/lib/sane/libsane-v4l.so.1'
[23:14:03.020602] [dll] load: couldn't open `/usr/local/lib/sane/libsane-v4l.so.1' (No such file or directory)
[23:14:03.020612] [dll] load: couldn't find backend `v4l' (No such file or directory)
[23:14:03.020624] [dll] load: searching backend `umax1220u' in `/usr/local/lib/sane'
[23:14:03.020633] [dll] load: trying to load `/usr/local/lib/sane/libsane-umax1220u.so.1'
[23:14:03.020648] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-umax1220u.so.1'
[23:14:03.020749] [dll] init: initializing backend `umax1220u'
[23:14:03.020842] [dll] init: backend `umax1220u' is version 1.0.2
[23:14:03.020859] [dll] load: searching backend `umax' in `/usr/local/lib/sane'
[23:14:03.020873] [dll] load: trying to load `/usr/local/lib/sane/libsane-umax.so.1'
[23:14:03.020892] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-umax.so.1'
[23:14:03.020991] [dll] init: initializing backend `umax'
[23:14:03.024514] [dll] init: backend `umax' is version 1.0.45
[23:14:03.024527] [dll] load: searching backend `u12' in `/usr/local/lib/sane'
[23:14:03.024536] [dll] load: trying to load `/usr/local/lib/sane/libsane-u12.so.1'
[23:14:03.024550] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-u12.so.1'
[23:14:03.024645] [dll] init: initializing backend `u12'
[23:14:03.024767] [dll] init: backend `u12' is version 1.0.0
[23:14:03.024780] [dll] load: searching backend `teco3' in `/usr/local/lib/sane'
[23:14:03.024792] [dll] load: trying to load `/usr/local/lib/sane/libsane-teco3.so.1'
[23:14:03.024807] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-teco3.so.1'
[23:14:03.024885] [dll] init: initializing backend `teco3'
[23:14:03.026143] [dll] init: backend `teco3' is version 1.0.1
[23:14:03.026155] [dll] load: searching backend `teco2' in `/usr/local/lib/sane'
[23:14:03.026164] [dll] load: trying to load `/usr/local/lib/sane/libsane-teco2.so.1'
[23:14:03.026178] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-teco2.so.1'
[23:14:03.026261] [dll] init: initializing backend `teco2'
[23:14:03.028476] [dll] init: backend `teco2' is version 1.0.10
[23:14:03.028489] [dll] load: searching backend `teco1' in `/usr/local/lib/sane'
[23:14:03.028497] [dll] load: trying to load `/usr/local/lib/sane/libsane-teco1.so.1'
[23:14:03.028511] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-teco1.so.1'
[23:14:03.028588] [dll] init: initializing backend `teco1'
[23:14:03.030041] [dll] init: backend `teco1' is version 1.0.10
[23:14:03.030053] [dll] load: searching backend `tamarack' in `/usr/local/lib/sane'
[23:14:03.030061] [dll] load: trying to load `/usr/local/lib/sane/libsane-tamarack.so.1'
[23:14:03.030078] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-tamarack.so.1'
[23:14:03.030158] [dll] init: initializing backend `tamarack'
[23:14:03.030791] [dll] init: backend `tamarack' is version 1.0.0
[23:14:03.030807] [dll] load: searching backend `sp15c' in `/usr/local/lib/sane'
[23:14:03.030816] [dll] load: trying to load `/usr/local/lib/sane/libsane-sp15c.so.1'
[23:14:03.030829] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-sp15c.so.1'
[23:14:03.030909] [dll] init: initializing backend `sp15c'
[23:14:03.031149] [dll] init: backend `sp15c' is version 1.0.0
[23:14:03.031161] [dll] load: searching backend `snapscan' in `/usr/local/lib/sane'
[23:14:03.031169] [dll] load: trying to load `/usr/local/lib/sane/libsane-snapscan.so.1'
[23:14:03.031182] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-snapscan.so.1'
[23:14:03.031333] [dll] init: initializing backend `snapscan'
[23:14:03.032234] [dll] init: backend `snapscan' is version 1.4.53
[23:14:03.032247] [dll] load: searching backend `sm3840' in `/usr/local/lib/sane'
[23:14:03.032256] [dll] load: trying to load `/usr/local/lib/sane/libsane-sm3840.so.1'
[23:14:03.032271] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-sm3840.so.1'
[23:14:03.032369] [dll] init: initializing backend `sm3840'
[23:14:03.032439] [dll] init: backend `sm3840' is version 1.0.0
[23:14:03.032457] [dll] load: searching backend `sm3600' in `/usr/local/lib/sane'
[23:14:03.032467] [dll] load: trying to load `/usr/local/lib/sane/libsane-sm3600.so.1'
[23:14:03.032481] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-sm3600.so.1'
[23:14:03.032575] [dll] init: initializing backend `sm3600'
[23:14:03.032644] [dll] init: backend `sm3600' is version 1.0.6
[23:14:03.032656] [dll] load: searching backend `sharp' in `/usr/local/lib/sane'
[23:14:03.032668] [dll] load: trying to load `/usr/local/lib/sane/libsane-sharp.so.1'
[23:14:03.032682] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-sharp.so.1'
[23:14:03.032762] [dll] init: initializing backend `sharp'
[23:14:03.033414] [dll] init: backend `sharp' is version 1.0.0
[23:14:03.033426] [dll] load: searching backend `sceptre' in `/usr/local/lib/sane'
[23:14:03.033435] [dll] load: trying to load `/usr/local/lib/sane/libsane-sceptre.so.1'
[23:14:03.033449] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-sceptre.so.1'
[23:14:03.033529] [dll] init: initializing backend `sceptre'
[23:14:03.034182] [dll] init: backend `sceptre' is version 1.0.10
[23:14:03.034194] [dll] load: searching backend `s9036' in `/usr/local/lib/sane'
[23:14:03.034203] [dll] load: trying to load `/usr/local/lib/sane/libsane-s9036.so.1'
[23:14:03.034221] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-s9036.so.1'
[23:14:03.034302] [dll] init: initializing backend `s9036'
[23:14:03.034748] [dll] init: backend `s9036' is version 1.0.0
[23:14:03.034759] [dll] load: searching backend `rts8891' in `/usr/local/lib/sane'
[23:14:03.034768] [dll] load: trying to load `/usr/local/lib/sane/libsane-rts8891.so.1'
[23:14:03.034782] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-rts8891.so.1'
[23:14:03.034896] [dll] init: initializing backend `rts8891'
[23:14:03.034988] [dll] init: backend `rts8891' is version 1.0.2401
[23:14:03.035058] [dll] load: searching backend `ricoh2' in `/usr/local/lib/sane'
[23:14:03.035073] [dll] load: trying to load `/usr/local/lib/sane/libsane-ricoh2.so.1'
[23:14:03.035087] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-ricoh2.so.1'
[23:14:03.035185] [dll] init: initializing backend `ricoh2'
[23:14:03.035265] [dll] init: backend `ricoh2' is version 1.0.0
[23:14:03.035281] [dll] load: searching backend `ricoh' in `/usr/local/lib/sane'
[23:14:03.035290] [dll] load: trying to load `/usr/local/lib/sane/libsane-ricoh.so.1'
[23:14:03.035304] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-ricoh.so.1'
[23:14:03.035380] [dll] init: initializing backend `ricoh'
[23:14:03.035835] [dll] init: backend `ricoh' is version 1.0.0
[23:14:03.035852] [dll] load: searching backend `qcam' in `/usr/local/lib/sane'
[23:14:03.035865] [dll] load: trying to load `/usr/local/lib/sane/libsane-qcam.so.1'
[23:14:03.035883] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-qcam.so.1'
[23:14:03.035970] [dll] init: initializing backend `qcam'
[23:14:03.036008] [dll] init: backend `qcam' is version 1.0.0
[23:14:03.036020] [dll] load: searching backend `plustek' in `/usr/local/lib/sane'
[23:14:03.036029] [dll] load: trying to load `/usr/local/lib/sane/libsane-plustek.so.1'
[23:14:03.036042] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-plustek.so.1'
[23:14:03.036157] [dll] init: initializing backend `plustek'
[23:14:03.036379] [dll] init: backend `plustek' is version 1.0.0
[23:14:03.036392] [dll] load: searching backend `pixma' in `/usr/local/lib/sane'
[23:14:03.036405] [dll] load: trying to load `/usr/local/lib/sane/libsane-pixma.so.1'
[23:14:03.036419] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-pixma.so.1'
[23:14:03.036545] [dll] init: initializing backend `pixma'
[23:14:03.036650] [dll] init: backend `pixma' is version 1.0.28
[23:14:03.557584] [dll] load: searching backend `pint' in `/usr/local/lib/sane'
[23:14:03.557605] [dll] load: trying to load `/usr/local/lib/sane/libsane-pint.so.1'
[23:14:03.557626] [dll] load: couldn't open `/usr/local/lib/sane/libsane-pint.so.1' (No such file or directory)
[23:14:03.557646] [dll] load: couldn't find backend `pint' (No such file or directory)
[23:14:03.557661] [dll] load: searching backend `pieusb' in `/usr/local/lib/sane'
[23:14:03.557674] [dll] load: trying to load `/usr/local/lib/sane/libsane-pieusb.so.1'
[23:14:03.557696] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-pieusb.so.1'
[23:14:03.557868] [dll] init: initializing backend `pieusb'
[23:14:03.558030] [dll] init: backend `pieusb' is version 1.0.1
[23:14:03.558054] [dll] load: searching backend `pie' in `/usr/local/lib/sane'
[23:14:03.558072] [dll] load: trying to load `/usr/local/lib/sane/libsane-pie.so.1'
[23:14:03.558093] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-pie.so.1'
[23:14:03.558234] [dll] init: initializing backend `pie'
[23:14:03.559901] [dll] init: backend `pie' is version 1.0.9
[23:14:03.559919] [dll] load: searching backend `niash' in `/usr/local/lib/sane'
[23:14:03.559932] [dll] load: trying to load `/usr/local/lib/sane/libsane-niash.so.1'
[23:14:03.559953] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-niash.so.1'
[23:14:03.560108] [dll] init: initializing backend `niash'
[23:14:03.560217] [dll] init: backend `niash' is version 1.0.1
[23:14:03.560240] [dll] load: searching backend `nec' in `/usr/local/lib/sane'
[23:14:03.560257] [dll] load: trying to load `/usr/local/lib/sane/libsane-nec.so.1'
[23:14:03.560282] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-nec.so.1'
[23:14:03.560403] [dll] init: initializing backend `nec'
[23:14:03.561107] [dll] init: backend `nec' is version 1.0.0
[23:14:03.561127] [dll] load: searching backend `mustek_usb2' in `/usr/local/lib/sane'
[23:14:03.561143] [dll] load: trying to load `/usr/local/lib/sane/libsane-mustek_usb2.so.1'
[23:14:03.561165] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-mustek_usb2.so.1'
[23:14:03.561329] [dll] init: initializing backend `mustek_usb2'
[23:14:03.561372] [dll] init: backend `mustek_usb2' is version 1.0.10
[23:14:03.561471] [dll] load: searching backend `mustek_usb' in `/usr/local/lib/sane'
[23:14:03.561492] [dll] load: trying to load `/usr/local/lib/sane/libsane-mustek_usb.so.1'
[23:14:03.561519] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-mustek_usb.so.1'
[23:14:03.561669] [dll] init: initializing backend `mustek_usb'
[23:14:03.561812] [dll] init: backend `mustek_usb' is version 1.0.18
[23:14:03.561836] [dll] load: searching backend `mustek' in `/usr/local/lib/sane'
[23:14:03.561850] [dll] load: trying to load `/usr/local/lib/sane/libsane-mustek.so.1'
[23:14:03.561872] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-mustek.so.1'
[23:14:03.561996] [dll] init: initializing backend `mustek'
[23:14:03.563367] [dll] init: backend `mustek' is version 1.0.138
[23:14:03.563386] [dll] load: searching backend `microtek2' in `/usr/local/lib/sane'
[23:14:03.563402] [dll] load: trying to load `/usr/local/lib/sane/libsane-microtek2.so.1'
[23:14:03.563424] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-microtek2.so.1'
[23:14:03.563560] [dll] init: initializing backend `microtek2'
[23:14:03.564586] [dll] init: backend `microtek2' is version 1.0.0
[23:14:03.564612] [dll] load: searching backend `microtek' in `/usr/local/lib/sane'
[23:14:03.564626] [dll] load: trying to load `/usr/local/lib/sane/libsane-microtek.so.1'
[23:14:03.564652] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-microtek.so.1'
[23:14:03.564779] [dll] init: initializing backend `microtek'
[23:14:03.565802] [dll] init: backend `microtek' is version 1.0.0
[23:14:03.565821] [dll] load: searching backend `matsushita' in `/usr/local/lib/sane'
[23:14:03.565835] [dll] load: trying to load `/usr/local/lib/sane/libsane-matsushita.so.1'
[23:14:03.565856] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-matsushita.so.1'
[23:14:03.565974] [dll] init: initializing backend `matsushita'
[23:14:03.568299] [dll] init: backend `matsushita' is version 1.0.7
[23:14:03.568318] [dll] load: searching backend `magicolor' in `/usr/local/lib/sane'
[23:14:03.568337] [dll] load: trying to load `/usr/local/lib/sane/libsane-magicolor.so.1'
[23:14:03.568363] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-magicolor.so.1'
[23:14:03.573662] [dll] init: initializing backend `magicolor'
[23:14:03.573799] [dll] init: backend `magicolor' is version 1.0.1
[23:14:05.079476] [dll] load: searching backend `ma1509' in `/usr/local/lib/sane'
[23:14:05.079498] [dll] load: trying to load `/usr/local/lib/sane/libsane-ma1509.so.1'
[23:14:05.079522] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-ma1509.so.1'
[23:14:05.079720] [dll] init: initializing backend `ma1509'
[23:14:05.079868] [dll] init: backend `ma1509' is version 1.0.3
[23:14:05.079894] [dll] load: searching backend `lexmark' in `/usr/local/lib/sane'
[23:14:05.079908] [dll] load: trying to load `/usr/local/lib/sane/libsane-lexmark.so.1'
[23:14:05.079929] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-lexmark.so.1'
[23:14:05.080085] [dll] init: initializing backend `lexmark'
[23:14:05.080220] [dll] init: backend `lexmark' is version 1.0.32
[23:14:05.080332] [dll] load: searching backend `leo' in `/usr/local/lib/sane'
[23:14:05.080353] [dll] load: trying to load `/usr/local/lib/sane/libsane-leo.so.1'
[23:14:05.080375] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-leo.so.1'
[23:14:05.080497] [dll] init: initializing backend `leo'
[23:14:05.081928] [dll] init: backend `leo' is version 1.0.11
[23:14:05.081947] [dll] load: searching backend `kvs40xx' in `/usr/local/lib/sane'
[23:14:05.081961] [dll] load: trying to load `/usr/local/lib/sane/libsane-kvs40xx.so.1'
[23:14:05.081981] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-kvs40xx.so.1'
[23:14:05.082128] [dll] init: initializing backend `kvs40xx'
[23:14:05.082229] [dll] init: backend `kvs40xx' is version 1.0.1
[23:14:05.083213] [dll] load: searching backend `kvs20xx' in `/usr/local/lib/sane'
[23:14:05.083229] [dll] load: trying to load `/usr/local/lib/sane/libsane-kvs20xx.so.1'
[23:14:05.083284] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-kvs20xx.so.1'
[23:14:05.083444] [dll] init: initializing backend `kvs20xx'
[23:14:05.083554] [dll] init: backend `kvs20xx' is version 1.0.2
[23:14:05.085455] [dll] load: searching backend `kvs1025' in `/usr/local/lib/sane'
[23:14:05.085473] [dll] load: trying to load `/usr/local/lib/sane/libsane-kvs1025.so.1'
[23:14:05.085497] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-kvs1025.so.1'
[23:14:05.085655] [dll] init: initializing backend `kvs1025'
[23:14:05.085832] [dll] init: backend `kvs1025' is version 1.0.5
[23:14:05.085852] [dll] load: searching backend `kodakaio' in `/usr/local/lib/sane'
[23:14:05.085869] [dll] load: trying to load `/usr/local/lib/sane/libsane-kodakaio.so.1'
[23:14:05.085889] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-kodakaio.so.1'
[23:14:05.086842] [dll] init: initializing backend `kodakaio'
[23:14:05.086950] [dll] init: backend `kodakaio' is version 1.0.3
[23:14:05.088640] [dll] load: searching backend `kodak' in `/usr/local/lib/sane'
[23:14:05.088662] [dll] load: trying to load `/usr/local/lib/sane/libsane-kodak.so.1'
[23:14:05.088686] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-kodak.so.1'
[23:14:05.088819] [dll] init: initializing backend `kodak'
[23:14:05.088845] [dll] init: backend `kodak' is version 1.0.7
[23:14:05.089243] [dll] load: searching backend `ibm' in `/usr/local/lib/sane'
[23:14:05.089259] [dll] load: trying to load `/usr/local/lib/sane/libsane-ibm.so.1'
[23:14:05.089280] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-ibm.so.1'
[23:14:05.089411] [dll] init: initializing backend `ibm'
[23:14:05.090114] [dll] init: backend `ibm' is version 1.0.0
[23:14:05.090133] [dll] load: searching backend `hs2p' in `/usr/local/lib/sane'
[23:14:05.090147] [dll] load: trying to load `/usr/local/lib/sane/libsane-hs2p.so.1'
[23:14:05.090168] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hs2p.so.1'
[23:14:05.090308] [dll] init: initializing backend `hs2p'
[23:14:05.091359] [dll] init: backend `hs2p' is version 1.0.0
[23:14:05.091387] [dll] load: searching backend `hpsj5s' in `/usr/local/lib/sane'
[23:14:05.091402] [dll] load: trying to load `/usr/local/lib/sane/libsane-hpsj5s.so.1'
[23:14:05.091427] [dll] load: couldn't open `/usr/local/lib/sane/libsane-hpsj5s.so.1' (No such file or directory)
[23:14:05.091441] [dll] load: couldn't find backend `hpsj5s' (No such file or directory)
[23:14:05.091456] [dll] load: searching backend `hpljm1005' in `/usr/local/lib/sane'
[23:14:05.091470] [dll] load: trying to load `/usr/local/lib/sane/libsane-hpljm1005.so.1'
[23:14:05.091496] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hpljm1005.so.1'
[23:14:05.091650] [dll] init: initializing backend `hpljm1005'
[23:14:05.091753] [dll] init: backend `hpljm1005' is version 1.0.1
[23:14:05.091778] [dll] load: searching backend `hp5590' in `/usr/local/lib/sane'
[23:14:05.091797] [dll] load: trying to load `/usr/local/lib/sane/libsane-hp5590.so.1'
[23:14:05.091823] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hp5590.so.1'
[23:14:05.091979] [dll] init: initializing backend `hp5590'
[23:14:05.092089] [dll] init: backend `hp5590' is version 1.0.8
[23:14:05.092113] [dll] load: searching backend `hp5400' in `/usr/local/lib/sane'
[23:14:05.092127] [dll] load: trying to load `/usr/local/lib/sane/libsane-hp5400.so.1'
[23:14:05.092154] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hp5400.so.1'
[23:14:05.092299] [dll] init: initializing backend `hp5400'
[23:14:05.092432] [dll] init: backend `hp5400' is version 1.0.3
[23:14:05.092455] [dll] load: searching backend `hp4200' in `/usr/local/lib/sane'
[23:14:05.092469] [dll] load: trying to load `/usr/local/lib/sane/libsane-hp4200.so.1'
[23:14:05.092491] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hp4200.so.1'
[23:14:05.092646] [dll] init: initializing backend `hp4200'
[23:14:05.092776] [dll] init: backend `hp4200' is version 1.0.0
[23:14:05.092795] [dll] load: searching backend `hp3900' in `/usr/local/lib/sane'
[23:14:05.092809] [dll] load: trying to load `/usr/local/lib/sane/libsane-hp3900.so.1'
[23:14:05.092831] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hp3900.so.1'
[23:14:05.095998] [dll] init: initializing backend `hp3900'
[23:14:05.096153] [dll] init: backend `hp3900' is version 1.0.0
[23:14:05.096179] [dll] load: searching backend `hp3500' in `/usr/local/lib/sane'
[23:14:05.096194] [dll] load: trying to load `/usr/local/lib/sane/libsane-hp3500.so.1'
[23:14:05.096215] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hp3500.so.1'
[23:14:05.096370] [dll] init: initializing backend `hp3500'
[23:14:05.096471] [dll] init: backend `hp3500' is version 1.0.0
[23:14:05.096501] [dll] load: searching backend `hp' in `/usr/local/lib/sane'
[23:14:05.096520] [dll] load: trying to load `/usr/local/lib/sane/libsane-hp.so.1'
[23:14:05.096545] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-hp.so.1'
[23:14:05.096713] [dll] init: initializing backend `hp'
[23:14:05.096758] [dll] init: backend `hp' is version 1.0.8
[23:14:05.097938] [dll] load: searching backend `gt68xx' in `/usr/local/lib/sane'
[23:14:05.097954] [dll] load: trying to load `/usr/local/lib/sane/libsane-gt68xx.so.1'
[23:14:05.097975] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-gt68xx.so.1'
[23:14:05.098151] [dll] init: initializing backend `gt68xx'
[23:14:05.098363] [dll] init: backend `gt68xx' is version 1.0.84
[23:14:05.098545] [dll] load: searching backend `genesys' in `/usr/local/lib/sane'
[23:14:05.098565] [dll] load: trying to load `/usr/local/lib/sane/libsane-genesys.so.1'
[23:14:05.098587] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-genesys.so.1'
[23:14:05.099232] [dll] init: initializing backend `genesys'
[23:14:05.100442] [dll] init: backend `genesys' is version 1.0.0
[23:14:05.100595] [dll] load: searching backend `fujitsu' in `/usr/local/lib/sane'
[23:14:05.100611] [dll] load: trying to load `/usr/local/lib/sane/libsane-fujitsu.so.1'
[23:14:05.100631] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-fujitsu.so.1'
[23:14:05.100807] [dll] init: initializing backend `fujitsu'
[23:14:05.100847] [dll] init: backend `fujitsu' is version 1.0.140
[23:14:05.101362] [dll] load: searching backend `escl' in `/usr/local/lib/sane'
[23:14:05.101379] [dll] load: trying to load `/usr/local/lib/sane/libsane-escl.so.1'
[23:14:05.101401] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-escl.so.1'
[23:14:05.133883] [dll] init: initializing backend `escl'
[23:14:05.133943] [dll] init: backend `escl' is version 1.0.0
[23:14:05.135025] [dll] load: searching backend `epsonds' in `/usr/local/lib/sane'
[23:14:05.135039] [dll] load: trying to load `/usr/local/lib/sane/libsane-epsonds.so.1'
[23:14:05.135053] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-epsonds.so.1'
[23:14:05.135292] [dll] init: initializing backend `epsonds'
[23:14:05.135421] [dll] init: backend `epsonds' is version 1.0.0
[23:14:05.136366] [dll] load: searching backend `epson2' in `/usr/local/lib/sane'
[23:14:05.136379] [dll] load: trying to load `/usr/local/lib/sane/libsane-epson2.so.1'
[23:14:05.136392] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-epson2.so.1'
[23:14:05.136509] [dll] init: initializing backend `epson2'
[23:14:05.136581] [dll] init: backend `epson2' is version 1.0.124
[23:14:06.139189] [dll] load: searching backend `epjitsu' in `/usr/local/lib/sane'
[23:14:06.139202] [dll] load: trying to load `/usr/local/lib/sane/libsane-epjitsu.so.1'
[23:14:06.139218] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-epjitsu.so.1'
[23:14:06.139378] [dll] init: initializing backend `epjitsu'
[23:14:06.139398] [dll] init: backend `epjitsu' is version 1.0.33
[23:14:06.139491] [dll] load: searching backend `dmc' in `/usr/local/lib/sane'
[23:14:06.139506] [dll] load: trying to load `/usr/local/lib/sane/libsane-dmc.so.1'
[23:14:06.139521] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-dmc.so.1'
[23:14:06.139609] [dll] init: initializing backend `dmc'
[23:14:06.140071] [dll] init: backend `dmc' is version 1.0.0
[23:14:06.140087] [dll] load: searching backend `dell1600n_net' in `/usr/local/lib/sane'
[23:14:06.140099] [dll] load: trying to load `/usr/local/lib/sane/libsane-dell1600n_net.so.1'
[23:14:06.140115] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-dell1600n_net.so.1'
[23:14:06.140258] [dll] init: initializing backend `dell1600n_net'
[23:14:06.140275] [dll] init: backend `dell1600n_net' is version 1.0.0
[23:14:06.440648] [dll] load: searching backend `coolscan3' in `/usr/local/lib/sane'
[23:14:06.440667] [dll] load: trying to load `/usr/local/lib/sane/libsane-coolscan3.so.1'
[23:14:06.440691] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-coolscan3.so.1'
[23:14:06.440877] [dll] init: initializing backend `coolscan3'
[23:14:06.440988] [dll] init: backend `coolscan3' is version 1.0.0
[23:14:06.441380] [dll] load: searching backend `coolscan' in `/usr/local/lib/sane'
[23:14:06.441395] [dll] load: trying to load `/usr/local/lib/sane/libsane-coolscan.so.1'
[23:14:06.441416] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-coolscan.so.1'
[23:14:06.441596] [dll] init: initializing backend `coolscan'
[23:14:06.442627] [dll] init: backend `coolscan' is version 1.0.0
[23:14:06.442646] [dll] load: searching backend `cardscan' in `/usr/local/lib/sane'
[23:14:06.442659] [dll] load: trying to load `/usr/local/lib/sane/libsane-cardscan.so.1'
[23:14:06.442680] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-cardscan.so.1'
[23:14:06.442839] [dll] init: initializing backend `cardscan'
[23:14:06.442940] [dll] init: backend `cardscan' is version 1.0.3
[23:14:06.442989] [dll] load: searching backend `canon_lide70' in `/usr/local/lib/sane'
[23:14:06.443004] [dll] load: trying to load `/usr/local/lib/sane/libsane-canon_lide70.so.1'
[23:14:06.443025] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-canon_lide70.so.1'
[23:14:06.443194] [dll] init: initializing backend `canon_lide70'
[23:14:06.443353] [dll] init: backend `canon_lide70' is version 1.0.0
[23:14:06.443384] [dll] load: searching backend `canon_dr' in `/usr/local/lib/sane'
[23:14:06.443398] [dll] load: trying to load `/usr/local/lib/sane/libsane-canon_dr.so.1'
[23:14:06.443419] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-canon_dr.so.1'
[23:14:06.443580] [dll] init: initializing backend `canon_dr'
[23:14:06.443623] [dll] init: backend `canon_dr' is version 1.0.65
[23:14:06.444436] [dll] load: searching backend `canon630u' in `/usr/local/lib/sane'
[23:14:06.444459] [dll] load: trying to load `/usr/local/lib/sane/libsane-canon630u.so.1'
[23:14:06.444486] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-canon630u.so.1'
[23:14:06.444654] [dll] init: initializing backend `canon630u'
[23:14:06.444786] [dll] init: backend `canon630u' is version 1.0.1
[23:14:06.444807] [dll] load: searching backend `canon' in `/usr/local/lib/sane'
[23:14:06.444822] [dll] load: trying to load `/usr/local/lib/sane/libsane-canon.so.1'
[23:14:06.444846] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-canon.so.1'
[23:14:06.444992] [dll] init: initializing backend `canon'
[23:14:06.445384] [dll] init: backend `canon' is version 1.0.0
[23:14:06.445408] [dll] load: searching backend `bh' in `/usr/local/lib/sane'
[23:14:06.445426] [dll] load: trying to load `/usr/local/lib/sane/libsane-bh.so.1'
[23:14:06.445448] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-bh.so.1'
[23:14:06.445586] [dll] init: initializing backend `bh'
[23:14:06.446661] [dll] init: backend `bh' is version 1.0.4
[23:14:06.446681] [dll] load: searching backend `avision' in `/usr/local/lib/sane'
[23:14:06.446694] [dll] load: trying to load `/usr/local/lib/sane/libsane-avision.so.1'
[23:14:06.446715] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-avision.so.1'
[23:14:06.446905] [dll] init: initializing backend `avision'
[23:14:06.467439] [dll] init: backend `avision' is version 1.0.297
[23:14:06.487991] [dll] load: searching backend `as6e' in `/usr/local/lib/sane'
[23:14:06.488008] [dll] load: trying to load `/usr/local/lib/sane/libsane-as6e.so.1'
[23:14:06.488029] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-as6e.so.1'
[23:14:06.488176] [dll] init: initializing backend `as6e'
[23:14:06.488234] [dll] load: searching backend `artec_eplus48u' in `/usr/local/lib/sane'
[23:14:06.488252] [dll] load: trying to load `/usr/local/lib/sane/libsane-artec_eplus48u.so.1'
[23:14:06.488280] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-artec_eplus48u.so.1'
[23:14:06.488450] [dll] init: initializing backend `artec_eplus48u'
[23:14:06.488790] [dll] init: backend `artec_eplus48u' is version 1.0.0
[23:14:06.488819] [dll] load: searching backend `artec' in `/usr/local/lib/sane'
[23:14:06.488837] [dll] load: trying to load `/usr/local/lib/sane/libsane-artec.so.1'
[23:14:06.488864] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-artec.so.1'
[23:14:06.489028] [dll] init: initializing backend `artec'
[23:14:06.490059] [dll] init: backend `artec' is version 1.0.0
[23:14:06.490083] [dll] load: searching backend `apple' in `/usr/local/lib/sane'
[23:14:06.490097] [dll] load: trying to load `/usr/local/lib/sane/libsane-apple.so.1'
[23:14:06.490123] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-apple.so.1'
[23:14:06.490277] [dll] init: initializing backend `apple'
[23:14:06.492534] [dll] init: backend `apple' is version 1.0.0
[23:14:06.492546] [dll] load: searching backend `agfafocus' in `/usr/local/lib/sane'
[23:14:06.492559] [dll] load: trying to load `/usr/local/lib/sane/libsane-agfafocus.so.1'
[23:14:06.492574] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-agfafocus.so.1'
[23:14:06.492669] [dll] init: initializing backend `agfafocus'
[23:14:06.493111] [dll] init: backend `agfafocus' is version 1.0.0
[23:14:06.493123] [dll] load: searching backend `abaton' in `/usr/local/lib/sane'
[23:14:06.493132] [dll] load: trying to load `/usr/local/lib/sane/libsane-abaton.so.1'
[23:14:06.493145] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-abaton.so.1'
[23:14:06.493245] [dll] init: initializing backend `abaton'
[23:14:06.493884] [dll] init: backend `abaton' is version 1.0.0
[23:14:06.493896] [dll] load: searching backend `net' in `/usr/local/lib/sane'
[23:14:06.493905] [dll] load: trying to load `/usr/local/lib/sane/libsane-net.so.1'
[23:14:06.493919] [dll] load: dlopen()ing `/usr/local/lib/sane/libsane-net.so.1'
[23:14:06.494032] [dll] init: initializing backend `net'
[23:14:06.494985] [dll] init: backend `net' is version 1.4.0
[23:14:06.494999] [dll] sane_get_devices: found 1 devices
[23:14:06.495012] [dll] sane_exit: exiting
[23:14:06.495018] [dll] sane_exit: calling backend `xerox_mfp's exit function
[23:14:06.495094] [dll] sane_exit: calling backend `umax1220u's exit function
[23:14:06.495155] [dll] sane_exit: calling backend `umax's exit function
[23:14:06.495214] [dll] sane_exit: calling backend `u12's exit function
[23:14:06.495281] [dll] sane_exit: calling backend `teco3's exit function
[23:14:06.495333] [dll] sane_exit: calling backend `teco2's exit function
[23:14:06.495386] [dll] sane_exit: calling backend `teco1's exit function
[23:14:06.495439] [dll] sane_exit: calling backend `tamarack's exit function
[23:14:06.495494] [dll] sane_exit: calling backend `sp15c's exit function
[23:14:06.495543] [dll] sane_exit: calling backend `snapscan's exit function
[23:14:06.495599] [dll] sane_exit: calling backend `sm3840's exit function
[23:14:06.495656] [dll] sane_exit: calling backend `sm3600's exit function
[23:14:06.495713] [dll] sane_exit: calling backend `sharp's exit function
[23:14:06.495766] [dll] sane_exit: calling backend `sceptre's exit function
[23:14:06.495817] [dll] sane_exit: calling backend `s9036's exit function
[23:14:06.495870] [dll] sane_exit: calling backend `rts8891's exit function
[23:14:06.495921] [dll] sane_exit: calling backend `ricoh2's exit function
[23:14:06.495977] [dll] sane_exit: calling backend `ricoh's exit function
[23:14:06.496028] [dll] sane_exit: calling backend `qcam's exit function
[23:14:06.496073] [dll] sane_exit: calling backend `plustek's exit function
[23:14:06.496131] [dll] sane_exit: calling backend `pixma's exit function
[23:14:06.496189] [dll] sane_exit: calling backend `pieusb's exit function
[23:14:06.496244] [dll] sane_exit: calling backend `pie's exit function
[23:14:06.496298] [dll] sane_exit: calling backend `niash's exit function
[23:14:06.496355] [dll] sane_exit: calling backend `nec's exit function
[23:14:06.496405] [dll] sane_exit: calling backend `mustek_usb2's exit function
[23:14:06.496464] [dll] sane_exit: calling backend `mustek_usb's exit function
[23:14:06.496519] [dll] sane_exit: calling backend `mustek's exit function
[23:14:06.496573] [dll] sane_exit: calling backend `microtek2's exit function
[23:14:06.496628] [dll] sane_exit: calling backend `microtek's exit function
[23:14:06.496680] [dll] sane_exit: calling backend `matsushita's exit function
[23:14:06.496732] [dll] sane_exit: calling backend `magicolor's exit function
[23:14:06.496823] [dll] sane_exit: calling backend `ma1509's exit function
[23:14:06.496877] [dll] sane_exit: calling backend `lexmark's exit function
[23:14:06.496930] [dll] sane_exit: calling backend `leo's exit function
[23:14:06.496979] [dll] sane_exit: calling backend `kvs40xx's exit function
[23:14:06.497028] [dll] sane_exit: calling backend `kvs20xx's exit function
[23:14:06.497084] [dll] sane_exit: calling backend `kvs1025's exit function
[23:14:06.497136] [dll] sane_exit: calling backend `kodakaio's exit function
[23:14:06.497191] [dll] sane_exit: calling backend `kodak's exit function
[23:14:06.497241] [dll] sane_exit: calling backend `ibm's exit function
[23:14:06.497290] [dll] sane_exit: calling backend `hs2p's exit function
[23:14:06.497344] [dll] sane_exit: calling backend `hpljm1005's exit function
[23:14:06.497395] [dll] sane_exit: calling backend `hp5590's exit function
[23:14:06.497447] [dll] sane_exit: calling backend `hp5400's exit function
[23:14:06.497497] [dll] sane_exit: calling backend `hp4200's exit function
[23:14:06.497553] [dll] sane_exit: calling backend `hp3900's exit function
[23:14:06.497609] [dll] sane_exit: calling backend `hp3500's exit function
[23:14:06.497661] [dll] sane_exit: calling backend `hp's exit function
[23:14:06.497714] [dll] sane_exit: calling backend `gt68xx's exit function
[23:14:06.497763] [dll] sane_exit: calling backend `genesys's exit function
[23:14:06.498011] [dll] sane_exit: calling backend `fujitsu's exit function
[23:14:06.498064] [dll] sane_exit: calling backend `escl's exit function
[23:14:06.499459] [dll] sane_exit: calling backend `epsonds's exit function
[23:14:06.499505] [dll] sane_exit: calling backend `epson2's exit function
[23:14:06.499550] [dll] sane_exit: calling backend `epjitsu's exit function
[23:14:06.499595] [dll] sane_exit: calling backend `dmc's exit function
[23:14:06.499633] [dll] sane_exit: calling backend `dell1600n_net's exit function
[23:14:06.499786] [dll] sane_exit: calling backend `coolscan3's exit function
[23:14:06.499831] [dll] sane_exit: calling backend `coolscan's exit function
[23:14:06.499871] [dll] sane_exit: calling backend `cardscan's exit function
[23:14:06.499913] [dll] sane_exit: calling backend `canon_lide70's exit function
[23:14:06.499958] [dll] sane_exit: calling backend `canon_dr's exit function
[23:14:06.500001] [dll] sane_exit: calling backend `canon630u's exit function
[23:14:06.500042] [dll] sane_exit: calling backend `canon's exit function
[23:14:06.500074] [dll] sane_exit: calling backend `bh's exit function
[23:14:06.500110] [dll] sane_exit: calling backend `avision's exit function
[23:14:06.500166] [dll] sane_exit: calling backend `artec_eplus48u's exit function
[23:14:06.500202] [dll] sane_exit: calling backend `artec's exit function
[23:14:06.500238] [dll] sane_exit: calling backend `apple's exit function
[23:14:06.500272] [dll] sane_exit: calling backend `agfafocus's exit function
[23:14:06.500305] [dll] sane_exit: calling backend `abaton's exit function
[23:14:06.500336] [dll] sane_exit: calling backend `net's exit function
[23:14:06.500515] [dll] sane_exit: finished
smile
#7 2026-07-09 20:49:39
deepforest
@kapqa Thanks for helping!:)
solved!
firmware must be placed at this both folders
/usr/local/share/sane/artec_eplus48u/Artec48.usb
/usr/share/sane/artec_eplus48u/Artec48.usb
smile
