#1 2026-06-27 11:33:11
chomwitt
Proposing an a11y & aging installer-login
proposition / a11y from the start .
prerequisites: The personal computer node should have haptic features that enable inserting live install media from users with different preferable sensor types / aquity level . User should have the physical media or have a computer with the installer running with poweron.
Installer should probe the user in a dialogue to agree on the preferable UI-display-input typed to use. Installer would probe first the hardware to see available UI devices .
So eg:
- (Installer) Hi User. Look,feel,hear all you devices of your computer. In you computer there are these output display types and these input types. State your preferences.
- (Installer) Hi User. Do you suffer from RSI ? I could install packages that prioritize input from less hand stressing devices.
Aligning with stated preferences the Distro should prioritize software tagged approprietely. For example : If a user states Display:Haptic Input:main-Sound,fallback braille keyboard then the Distro should install packages that can align with that choice. So in that case there is would be need for X11 but a haptic-display-server that can mediate access to that kind of device for different haptic friendly processes.  If a user states Display/Visual/Text oriented  distro could prioritize tmux over X11 and userspace land that can align with that.
The core idea here being that all IO hardawe could be used but the installer would prioritize packages aligning with the prefered interaction styles.
@ devuanwiki/Chomwitt
