#1 2026-05-10 11:23:12
pdbq
systemd compatibility layer
Many projects, and especially smaller community one, are created with systemd in mind, which is a deal breaker for many people who use them and who want to get away from systemd.
Are there plans to create a compatibility layer for other init systems so that projects created for systemd can work with them, without having to patch and repackage them?
Similar post: Seamless Devuan Project
#2 2026-05-11 17:06:00
coder-hase
Re: systemd compatibility layer
When you say are created with systemd in mind, can you give some examples?
#3 2026-05-11 17:57:17
pdbq
Sure. GNOME is the largest, Ambxst installer is the smallest that I know of.
#4 2026-05-11 19:39:30
JCK
A recent discussion on the subject: https://forum.artixlinux.org/index.php/ … 724.0.html
