#1 2026-05-05 20:37:58
deepforest
Ceres upgrade to kernel 7.0.3 error NVIDIA driver
At end of the upgrading process i have this
Processing triggers for initramfs-tools (0.151)…
update-initramfs: Generating /boot/initrd.img-6.19.14+deb14-amd64
I: The initramfs will attempt to resume from /dev/sdd5
I: (UUID=132b6ad7-4fd2-4211-9072-871347617609)
I: Set the RESUME variable to override this.
Processing triggers for libc-bin (2.42-15)…
 linux-headers-7.0.3+deb14-amd64
 linux-headers-amd64
 linux-image-7.0.3+deb14-amd64
 linux-image-amd64
Error: Sub-process /usr/bin/dpkg returned an error code (1)
root@devuan:/etc/apt/sources.list.d#
sudo apt --fix-broken install
Building module(s).........................(bad exit status: 2)
Failed command:
env NV_VERBOSE=1 make -j4 modules KERNEL_UNAME=7.0.3+deb14-amd64; env NV_VERBOSE=1 make -j4 -C uvm modules KERNEL_UNAME=7.0.3+deb14-amd64 KBUILD_EXTMOD=/var/lib/dkms/nvidia-legacy-340xx/340
.108/build/uvm
Error! Bad return status for module build on kernel: 7.0.3+deb14-amd64 (x86_64)
Consult /var/lib/dkms/nvidia-legacy-340xx/340.108/build/make.log for more information.
Autoinstall on 7.0.3+deb14-amd64 failed for module(s) nvidia-legacy-340xx(10).
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
run-parts: /etc/kernel/postinst.d/dkms exited with return code 1
dpkg: error processing package linux-image-7.0.3+deb14-amd64 (--configure):
 old linux-image-7.0.3+deb14-amd64 package postinst maintainer script subprocess failed with exit status 1
dpkg: dependency problems prevent configuration of linux-headers-amd64:
 linux-headers-amd64 depends on linux-headers-7.0.3+deb14-amd64 (= 7.0.3-1); however:
  Package linux-headers-7.0.3+deb14-amd64 is not configured yet.
dpkg: error processing package linux-headers-amd64 (--configure):
dpkg: dependency problems prevent configuration of linux-image-amd64:
 linux-image-amd64 depends on linux-image-7.0.3+deb14-amd64 (= 7.0.3-1); however:
  Package linux-image-7.0.3+deb14-amd64 is not configured yet.
dpkg: error processing package linux-image-amd64 (--configure):
 linux-headers-amd64
 linux-image-amd64
nv.c: In function ‘nvidia_open’:
nv.c:1468:33: error: ‘screen_info’ undeclared (first use in this function)
 1468 |         if (nv->primary_vga && (screen_info.orig_video_isVGA != 0x01))
nv.c:1468:33: note: each undeclared identifier is reported only once for each function it appears in
make[4]: *** [/usr/src/linux-headers-7.0.3+deb14-common/scripts/Makefile.build:294: nv.o] Error 1
make[4]: *** Waiting for unfinished jobs....
make[3]: *** [/usr/src/linux-headers-7.0.3+deb14-common/Makefile:2129: .] Error 2
make[2]: *** [/usr/src/linux-headers-7.0.3+deb14-common/Makefile:260: __sub-make] Error 2
make[2]: Leaving directory '/var/lib/dkms/nvidia-legacy-340xx/340.108/build'
make[1]: *** [Makefile:260: __sub-make] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-7.0.3+deb14-common'
make: *** [Makefile:219: nvidia.ko] Error 2
make: Entering directory '/var/lib/dkms/nvidia-legacy-340xx/340.108/build/uvm'
cd ./..; make module SYSSRC=/lib/modules/7.0.3+deb14-amd64/source SYSOUT=/lib/modules/7.0.3+deb14-amd64/build KBUILD_EXTMOD=./..
NVIDIA UVM: CC=x86_64-linux-gnu-gcc-15, HOST_CC=x86_64-linux-gnu-gcc-15 NV_TARGET_ARCH=x86_64
NVIDIA UVM: CONFTEST=/bin/sh ./conftest.sh x86_64-linux-gnu-gcc-15 x86_64-linux-gnu-gcc-15 x86_64 /lib/modules/7.0.3+deb14-amd64/source /lib/modules/7.0.3+deb14-amd64/build
make[1]: Entering directory '/var/lib/dkms/nvidia-legacy-340xx/340.108/build'
KERNEL_SOURCES: /lib/modules/7.0.3+deb14-amd64/source
EXTRA_CFLAGS: -O2 -DNVIDIA_UVM_LITE_ENABLED -DLinux -D__linux__ -DNVIDIA_UVM_RM_ENABLED  -I/var/lib/dkms/nvidia-legacy-340xx/340.108/build -I./..
NVIDIA: calling KBUILD...
make NV_MODULE_SUFFIX= KBUILD_OUTPUT=/lib/modules/7.0.3+deb14-amd64/build KERNEL_SOURCES=/lib/modules/7.0.3+deb14-amd64/source KERNEL_OUTPUT=/lib/modules/7.0.3+deb14-amd64/build KBUILD_VERB
OSE=1 -C /lib/modules/7.0.3+deb14-amd64/source M=/var/lib/dkms/nvidia-legacy-340xx/340.108/build ARCH=x86_64 modules
make[2]: Entering directory '/usr/src/linux-headers-7.0.3+deb14-common'
make  -C /usr/src \
-f /usr/src/linux-headers-7.0.3+deb14-common/Makefile modules
make[3]: Entering directory '/usr/src'
make --no-print-directory -C /usr/src \
make -f /usr/src/linux-headers-7.0.3+deb14-common/scripts/Makefile.build obj=. need-builtin=1 need-modorder=1
/usr/src/linux-headers-7.0.3+deb14-common/scripts/Makefile.build:37: Makefile: No such file or directory
make[5]: *** No rule to make target 'Makefile'.  Stop.
make[4]: *** [/usr/src/linux-headers-7.0.3+deb14-common/Makefile:2129: .] Error 2
make[3]: *** [/usr/src/linux-headers-7.0.3+deb14-common/Makefile:260: __sub-make] Error 2
make[3]: Leaving directory '/usr/src'
make[2]: *** [Makefile:260: __sub-make] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-7.0.3+deb14-common'
make[1]: *** [Makefile:219: nvidia.ko] Error 2
make[1]: Leaving directory '/var/lib/dkms/nvidia-legacy-340xx/340.108/build'
make: *** [Makefile:226: ../Module.symvers] Error 2
make: Leaving directory '/var/lib/dkms/nvidia-legacy-340xx/340.108/build/uvm'
# exit code: 2
# elapsed time: 00:01:09
smile
pyzNi 3.14zDa! smile
#2 2026-05-05 23:01:50
deepforest
Re: Ceres upgrade to kernel 7.0.3 error NVIDIA driver
this command not help
sudo apt reinstall nvidia-legacy-340xx-kernel-dkms
root@devuan:/home/freeartist-devuan# dkms status
nvidia-legacy-340xx/340.108, 6.12.57+deb13-amd64, x86_64: installed
nvidia-legacy-340xx/340.108, 6.19.11+deb14-amd64, x86_64: installed
nvidia-legacy-340xx/340.108, 6.19.14+deb14-amd64, x86_64: installed
problem with dkms that can`t build nvidia uvm module for kernel 7.0.3
smile
#3 2026-05-06 12:28:42
And? You're running unstable with a bleeding-edge kernel and ancient out-of tree proprietary drivers. Did you expect that not to break?
Either patch the nvidia nonsense yourself or wait for Debian to do so. Nvidia probably never will, they're regularly behind on kernel kernel changes with their current driver, let alone one released over six years ago.
#4 2026-05-06 18:51:03
deepforest
What, and? Sid still have patches for this legacy drivers, that why i use Sid/Ceres, Debian drop support this drivers over 5 years ago only at stable, but Sid still support it.
https://packages.debian.org/ru/sid/nvid … 0xx-driver
https://pkginfo.devuan.org/cgi-bin/poli … .253.74.99
smile
#5 2026-05-06 22:07:59
Kristof12
Then would be a bit better using older kernel versions (I saw changelog and it seems staying on 6.19 works I guess), and I'm also waiting for nvidia to update with backports for their drivers on Debian repos... I hope it's soon... the usual pain with nvidia
#6 2026-05-06 22:16:17
deepforest
Agree!
I will try this trick at Stable Devuan
https://gist.github.com/Anakiev2/8d62e2 … ff855a22a7
smile
