#1 2026-05-02 10:09:21
pequi
[SOLVED] Deborphan - why is it not listed?
I can't find any references to deborphan in synaptic or with a aptitude search. I was fond of that utility, and assumed it had been dropped due to lack of support.
But when I searched for it in the "Packages" menu at the top of this page here it is:
<https://pkginfo.devuan.org/cgi-bin/pack … han=1.7.35>
I even have backports in my sources list.
Why is it not listed? Is it in some "other" source?
Is it safe to use?
#2 2026-05-02 11:02:52
brocashelm
Re: [SOLVED] Deborphan - why is it not listed?
Along with Orphaner, I think it got deprecated by Debian indefinitely, as nothing exists past Bookworm sans Sid for RISC-V. You could try to install it from Daedalus.
I just use Debfoster now.
#3 2026-05-02 11:04:23
pequi wrote:
... can't find any references to deborphan ...
Note that it is available but (presently) not for excalibur.
Devuan Package View wrote:
deborphan
1.7.35 http://deb.devuan.org/merged daedalus/main amd64
1.7.33 http://deb.devuan.org/merged chimaera/main amd64
1.7.31 http://archive.devuan.org/merged beowulf/main amd64
1.7.28.8-0.3+b1 http://archive.devuan.org/merged ascii/main amd64
1.7.28.8-0.1 http://archive.devuan.org/merged jessie/main amd64
In all probability, because it is not (presently) listed in the Debian Trixie repository:
Debian - Package search results wrote:
Package deborphan
bullseye (oldoldstable) 1.7.33: amd64 arm64 armhf i386
bookworm (oldstable) 1.7.35: amd64 arm64 armel armhf i386 mips64el mipsel ppc64el s390x
sid (unstable) (admin): 1.7.35+b1 [debports]: riscv64
Maybe they are looking for a way to make it dependent on systemd. 8^D
#4 2026-05-04 11:49:06
pequi
What a terrible idea. IOW, probably what they are doing.
Note it is still available for "bleeding edge" Debian sid, so there must be some other die-hards out there.
I've installed debfoster, and I'll play around with it.
It didn't show up o google searches, or in a synaptic search, so something new learned.
I'll mark this "closed".
