#1 2026-04-11 23:47:55
devirx
[SOLVED] Time do not show correctly on Devuan Excalibur
I installed Devuan Excalibur and the time dont show correctly in Middle East.
I tried to run "dpkg-reconfigure tzdata" but nothing changed.
I also have another machine with Devuan Daedalus on it, but there time is shown correctly.
Any ideas what to do?
#2 2026-04-12 00:36:19
abower
Re: [SOLVED] Time do not show correctly on Devuan Excalibur
I don't _think_ this can be your problem because you have reconfigured the timezone based on the files you _do_ have, but one differnce between Daedalus and Excalibur is that a lot of non-canonical timezone forms were - with doubtful justification - split off into a new package, tzdata-legacy. More likely to affect people upgrading I should think, but might be worth installing it anyway.
#3 2026-04-12 19:26:16
devirx
Installation of tzdata-legacy didn't solved the problem but i figured it out.
Installed hwclock with
sudo apt install util-linux-extra
Set date manually with
sudo hwclock --set --date="YY-MM-DD HH:MM:SS"
Then synced system time with hwclock with
sudo hwclock -s
