#1 2026-04-05 18:35:22
alphalpha
awk-menu: a simple line selection tool + examples
If you have ever booted one of my isos or tried α-utilz, you have seen it
it is easy to use, but also very hackable, you can make custom keybindings and more
its says "examples" in the title, but these scripts are relative complex and quite usefull by themselves
the only dependencie is awk (gawk or mawk), which makes this ideal for very minimalist systems
if you need a minimalistic tool to change screen resolution, connect your wifi or mount usb-drives, check out:
gitlab.com/_alphalpha_/awk-menu
#2 2026-04-05 19:03:01
alphalpha
Re: awk-menu: a simple line selection tool + examples
i forgot to add a simple template:
[ ! "$SCRIPTS" ] && SCRIPTS="${0%/*}"
. "$SCRIPTS"/lib/text-center || exit 1
. "$SCRIPTS"/lib/awk-menu    || exit 1
. "$SCRIPTS"/lib/text-box    || exit 1
awk_menu_tmsg="template"
awk_menu_tmsg="$(text_box "$(text_center "$awk_menu_tmsg")")"
input_text="> Option 1
> Option 2
> Option 3
> Exit Script"
input_text="$(text_center "$input_text")"
selection="$(awk_menu "$input_text")"
case "$selection" in
  "> Option 1")	sleep;;
  "> Option 2")	wait;;
  "> Option 3")  return;;
  "> Exit Script") exit 0;;
esac
exit 0
