#1 2026-03-30 09:09:51
kapqa
(devuan 6) caja no longer opening - apps unresponsive
Hello ,
on an older computer have installed the Devuan 6 -
had let it running for a while -
today change the internet connection (swapped router)
now i cannot seem to open the file manager any longer -
also app "simplentoe" that i use frequently for notes - no longer opens
maybe you can indicate the cause of error?
there are message like
root@devuan:~# simplenote
[0330/110021.069872:FATAL:electron_main_delegate.cc(288)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
Trace/breakpoint trap
root@devuan:~# thunar
-bash: thunar: command not found
root@devuan:~# caja
Segmentation fault
root@devuan:~# uname -a
Linux devuan 6.12.74+deb13+1-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.74-2 (2026-03-08) x86_64 GNU/Linux
root@devuan:~# cat /etc/os-release
PRETTY_NAME="Devuan GNU/Linux 6 (excalibur)"
NAME="Devuan GNU/Linux"
VERSION_ID="6"
VERSION="6 (excalibur)"
VERSION_CODENAME="excalibur"
ID=devuan
ID_LIKE=debian
HOME_URL="https://www.devuan.org/"
SUPPORT_URL="https://devuan.org/os/community"
BUG_REPORT_URL="https://bugs.devuan.org/"
simplenote
Checking for beta autoupdate feature for deb/rpm distributions
Found package-type: deb
thanks
#2 2026-03-30 10:15:14
Re: (devuan 6) caja no longer opening - apps unresponsive
Did you try a non-root user?
#3 2026-03-30 10:17:32
Segmentation fault
This is the problem. Reason?
#4 2026-03-30 15:04:17
kapqa
yes, error is also with non-root.
segmentation-fault -
this happend before , on other computers, sometimes when programs were not properly compatible or properly compiled (happened to me with mpv version of packaged for debian jess9e=) -
but the computer was behaving normally before - could not tell if something has gone bad -
only indicator - as said - i swapped the router (). (but rebooted).
other programs seem to open; simplenote has also opened before (it got installed via deb.file downloaded from official .git repository).
#5 2026-03-30 16:45:23
Elyon
Have you tried updating your system or reinstalling package?
Thinkpad x280 - Devuan Excalibur 6 - Xfce Desktop Environment - Apt/Appman
#6 2026-03-30 16:57:19
I think the router is an external device, the interface to the internet. I do not see any relation to your PC and the software its running.
Bit rot, disk error, hw fault. I would check the smart values of the disks first of all.
#7 2026-03-30 19:22:25
kapqa
thanks, rolfie,
that seems a sound advice;
there have been issue with some ssd before, will do some more testing;
and yes, system is updated (nor more updates proposed atm)
thank you all.
EDIT:
have been thinkging that have installed Linux wrongly since on startup there is always message:
(failed to locate :EFI : not found) or similar
but the Linux functioned "normally" nvtl until today.
and the SSD is like brandnew, so it should not be the issue.
the system is dualbooting with windows 7, maybe i have setup wrongly (the Linux is UEFI, and windows 7 could be installed in legacy, not sure).
This HP is the first workstation of them that had shipped with UEFI supposedly.
