#1 2026-03-17 16:13:05
tyder
How will life be without gvfs?
I'm about to find out for myself. It turned out that I didn't have to remove any userspace package to drop gvfs.
Which was kind of great surprise to me, I had the impression that 'everything' needed gvfs now and then.
In turn, it may indicate that the services gvfs provides, are not necessarily provided in an optimal way.
It's the old swiss army knife principle, which may mean jack of all trades, master of none.
And to some people, a swiss army knife is just what they need. Not to me, even though I happen to use them quite a lot ;-)
#2 2026-03-17 23:33:39
laurie_dev1
Re: How will life be without gvfs?
If you only need gvfs for external drive mounting and you dont mind the terminal there is a program called pmount which mounts external drives with user permissions/
pmount /dev/sdb1
mounts it to /media/sdb1
Or you can go old school and just use fstab for all external mount requirements.
GVfs comes with a set of back-ends, including trash support, SFTP, FTP, WebDAV, SMB, and local data via Udev integration, OBEX, MTP and others.
So just depends on your use case.
#3 2026-03-18 14:23:36
tux_99
I have been running a desktop PC with XFCE with gvfs uninstalled since a long time and I have never noticed any problems apart from the fact that I have to mount removable drives manually.
'pmount' as suggested is a good alternative to make manual mounting of removable drives easier, but of course you can also just use the standard 'mount' command.
“Either the users control the program – or the program controls the users” Richard Stallman
#4 2026-03-19 03:45:18
pcalvert
I created a stripped down Debian live CD back in 2017. I wanted to make sure that it would actually fit on a CD, so I excluded as much unnecessary stuff as possible, including gvfs. The lack of gvfs didn't cause any problems that I am aware of.
Another one is called Luxxle.
#5 2026-03-19 08:28:55
tyder
Thanks for the replies! :-)
That's very good for general, especially more occasional, use, but in my particular use cases, it hasn't been so useful. I have ended up doing (lots of) manual mounts for necessary control, for example. I think it has something to do with the 'need to be open'-thing too. Most volumes are unmounted most of the time etc.
Good to hear! My intuition is that I should rather make the mounting/unmounting more efficient than rely on gvfs automation.   And for me, the default is for services to be turned off when not in use: Boot partition/bootloader/initrd&kernel unmounted, init scripts rested when they have done their thing, media offline when not in use etc. Some of it, I think may be general good practice. The rest mostly related to workflow and reducing the impacts of own user errors.
#6 2026-03-19 11:35:16
Wanting a gnome-crap clean system, I purged most everything but when I purged gvfs I started having all sorts of issues.
One was that gnome-disks (the only useful gnome application I know of) would not work.
So I installed it again but then it screwed up my connection to a couple of android based thinguies (phone and tablet) when using PCManFM but not Thunar which I don't like as much but cannot get rid of as it is part of the actual XFCE clusterfuck.
I have since found that I can solve that by doing a "unplug thinguie, kill PCManFM, plug thinguie again, start PCManFM" dance.
Gets old in less that 30s.
I have also found that if I do pkill gvfs.* and run mtp-detect, then everything works fine.
Quite damning for gvfs ...
Note: without mtp-detect it does not work.
So ...
Q: how can I stop the gvfs service from running?
It is not listed when I run service --status-all | grep gvfs
But I found all these files which may hold a clue:
/usr/lib/systemd/user/gvfs-afc-volume-monitor.service
/usr/lib/systemd/user/gvfs-daemon.service                   <- ###### this?
/usr/lib/systemd/user/gvfs-goa-volume-monitor.service
/usr/lib/systemd/user/gvfs-gphoto2-volume-monitor.service
/usr/lib/systemd/user/gvfs-metadata.service
/usr/lib/systemd/user/gvfs-mtp-volume-monitor.service
/usr/lib/systemd/user/gvfs-udisks2-volume-monitor.service
~$ cat /usr/lib/systemd/user/gvfs-daemon.service
[Unit]
Description=Virtual filesystem service
PartOf=graphical-session.target
[Service]
ExecStart=/usr/libexec/gvfsd
Type=dbus
BusName=org.gtk.vfs.Daemon
Slice=session.slice
How to (safely) deal with this so it will not run at boot and allow me to check if anything goes south?
#7 2026-03-19 12:49:17
tux_99
Oh well if you use Gnome or even just gnome-disks then I'm not surprised that removing gvfs gives you problems, my experience without gvfs is purely with a clean XFCE, no gnome desktop stuff installed (other than polkit-gnome and gnome-keyring-daemon which AFAIR were installed by default with XFCE).
#8 2026-03-19 21:31:24
tux_99 wrote:
... you use Gnome or even just gnome-disks then I'm not surprised that removing gvfs gives you problems ...
Not only that.
If I do pkill gvfs.*, PCManFM will start it again.
Talk about invasive ...
To avoid the fuckups I have been getting I needed to at least disable gvfs-daemon.service.
Much to my chagrin, the only safe way I found on-line to do that was using systemctl, which I had to install.
Not happy about that. 8^/
When I ran it, I found that I also did not need to have these other services running:
# systemctl --user | grep gvfs
gvfs-afc-volume-monitor.service	  loaded inactive dead   Virtual filesystem service - Apple File Conduit monitor
gvfs-goa-volume-monitor.service   loaded inactive dead   Virtual filesystem service - GNOME Online Accounts monitor
So I disabled the ones I am certain I do not need:
# systemctl --user disable gvfs-daemon.service
# systemctl --user disable gvfs-afc-volume-monitor.service
# systemctl --user disable gvfs-goa-volume-monitor.service
Having to use a systemd tool utility to avoid running unneeded gvfs services is a very bad sign of things to come.
Grin and bear it, I guess.
I'll report if and when I find something is not working properly and in the mean time will see if getting rid of PCManFM cleans up some more of all this gvfs crap.
Sad state of affairs these are.
#9 2026-03-19 21:45:24
brocashelm
Personally, I got rid of Udisks2 (which also gets rid of GVfs) and have my USB flash drives automatically mount with the help of Udevil's Devmon running on a non-root level, optionally doing this through SpaceFM (for quick and efficient syncing and unmounting functionality baked in). Never had any issues that way, and I use a plugin for trash functionality.
See also this article on why Udisks2 is crap and is only just another Red Hat subversion (much like Systemd and Wayland). Still true fourteen years later.
#10 2026-03-20 12:21:16
tyder
Good to know there are alternatives for less manual use cases than mine. After years of frustrating experiences similar to @Altoid's, only complete removal of such stuff seems to give me less grievances that just putting up with it.
For the Devuan project, there may be a decision to make: Fix upstream first or next? Just adding gvfs-free alternatives and pointing to lots of successful users may be a smoother approach to introducing a change upstream than starting with a more principle-based discussion there.
#11 2026-03-20 14:46:29
You can replace polkit-gnome with mate-polkit or LXpolkit, you just need an authentication agent, any one will do.
The gnome keyring app is flawed and buggy, I got rid of that quite a while ago. Just store passwords in a local encrypted file, I made my own app for that.
#12 2026-03-20 14:55:07
Also, I may be the outlier here, and everybody knows I hate what gnome has become, i'm even to the point where i'm writing my own software specifically to take the place of gnome crap, that being said, gvfs and udisks are 2 that have never given me any trouble, and make for a lot of convenience in my system.
When I boot up my system, I want every partition and connected device to show up in that treeview, and I want to open them with a single click without any hoopla, I just don't have time in my day to work any other way, I work fast and the system either needs to keep up or get the **** out of the way and let me work. So far gvfs and udisks comply just fine with those requirements.
#13 2026-03-21 13:25:48
greenjeans wrote:
... may be the outlier here ...
Not necessarily so.
greenjeans wrote:
... hate what gnome has become ...
In my case, not hate as such.
I came across it many years ago when I was gifted a laptop (486?) and went looking for Linux to install.
There was something about it I disliked.
Gut feeling? No idea.
greenjeans wrote:
... gvfs and udisks ...
gvfs started acting up when I reinstalled it, fortunately I put paid to that by disabling the offending 'service' with systemctl, a systemd tool.
I am 'on the fence' so to speak about the rest of the gvfs crap running in my box.
While I both understand and sympathise with what you say, as far as I am concerned the less gnome crap we have in our Devuan box, the better.
As for udisks2 and having read that post linked to by brocashelm, if there is something to replace it I think it is a good idea.
Because we must return to the KISS principle if we want to continue to use our boxes as we see fit.
I arrived late to MSDOS and soon came W3.11, which I actually liked.
The when W95 came along, I had no choice but to use it at work.
When I mentioned this to one of the chaps I knew in IT, he said that W95 was a fantastic user interface, the future of 'computing'.
At that time, being a raw beginner in the use of a PC, I still remember the thought that crossed my mind sometime later:
"There will come a time when those who actually master the command line will be the only ones to have access to anything related to IT on their own terms."
And here we are ...
As always, just my $0.02
#14 2026-03-24 12:04:21
... report if and when I find something is not working properly ...
... see if getting rid of PCManFM cleans up some more of all this gvfs crap.
Well ...
It seems that, independently of what I did with sysmctl, things were not working as expected.
ie: same old gvfs screwing up things.
So I purged (with exreme prejudice) PCManFM and problem solved.
I then installed xfe, in my opinion a much underrated file manager that needs (?) gvfs but does not screw around with my mounting Android devices; lightweight and highly configurable.
I downloaded the latest version (2.1.5 *.run file) from sourceforge and installed it.
No issues for the time being.
I would also ditch Thunar but it seems not viable if using Xfce.
Will report if and when I find something is not working properly.
#15 2026-03-24 12:43:02
tux_99
My file manager of choice is mc (midnight commander), it runs everywhere (even remotely over a ssh connection) and does everything I need. I never understood the need for graphical file managers, they are usually slower and clumsier to operate.
#16 2026-03-24 14:22:51
tux_99 wrote:
... file manager of choice is mc ...
mc is one of the first things I have always installed on any PC, it has been that way ever since I can remember.
Although at that time it was Norton Commander on MS-DOS.
I always use it to ssh into my proto-NAS (WD MBL on OpenWRT) or when do any maintenance on my box, RPi or 1000HE.
I guess it comes down to unconscious preferences (?).
But yes, it is probably the best out there.
#17 2026-03-24 15:09:38
For a terminal based file manager, I think ranger is a lot better than mc.
#18 2026-03-24 15:45:07
tux_99
Hmm, I had never heard of ranger before but a glance at the description on the home page turned me off straight away because of this: "file manager with VI key bindings".
No thanks, while I do occasionally use vi(m) (I had to use vi when I was working on Solaris / HP-OS / AIX servers) I'm not a fan of its key bindings and only know the basic ones so ranger is not for me.
Like Altoid said, mc is inspired by Norton Commander and that's what I was using on MS DOS / Win 3.1 before switching to Linux in the mid 90s so that's what I prefer.
#19 2026-03-24 16:29:45
altoid wrote:
... then installed xfe, in my opinion ...
greenjeans wrote:
... I think ranger is ...
tux_99 wrote:
... never heard of ranger before ...
We (YT included, obviously) seem to have drifted off a bit.
Happens ...  8^°
The problem I have detected is that even with the use of systemctl, there does not seem to be a way to keep the gvfs.* services from running and if you purge it, at least in Xfce, it screws up things.
Talk about being 'plumbed in'. 8^/
I'm not sure but it seems that dbus (surpise!!!) will start all of them even if they are masked.
See here:
https://askubuntu.com/questions/1285637 … art-0.html
$ ls -1 /usr/share/dbus-1/services | grep vfs
org.gtk.vfs.AfcVolumeMonitor.service
org.gtk.vfs.Daemon.service
org.gtk.vfs.GPhoto2VolumeMonitor.service
org.gtk.vfs.GoaVolumeMonitor.service
org.gtk.vfs.MTPVolumeMonitor.service
org.gtk.vfs.Metadata.service
org.gtk.vfs.UDisks2VolumeMonitor.service
Like I mentioned earlier, PCManFM had some issue with gvfs which I solved by purging it and installing a replacement.
But the uneeded gvfs crap is still running.
ie: org.gtk.vfs.AfcVolumeMonitor.service and org.gtk.vfs.GoaVolumeMonitor.service
Any ideas?
#20 2026-03-24 18:49:02
I can do most everything I need to do in it with a mouse, it even displays pics. wink
Back on-topic: I'm sorry Altoid, but gvfs works really well with PcmanFM for me, and it's not even running until I open the file-manager for the first time in a session (i'm not using the file-manager to run the Desktop, so it's not on all the time either).
For me it's crucial to my workflow to be able to quickly access other partitions. If I could figure out a good solution to dropping it I would likely do so.
#21 2026-03-24 19:01:10
On my Excalibur with Cinnamon DE, I will keep gvfs as neccessary toolkit for the connection of my PC with my smartphone.
#22 2026-03-24 19:11:56
tux_99
@Altoid I don't know what's the root cause of your issues but I don't have any of those files you listed in that dbus folder (and I don't have gvfs installed) so I assume those files are only there because you have gvfs installed (or because it wasn't uninstalled properly in case you uninstalled gvfs).
#23 2026-03-24 19:56:45
greenjeans wrote:
... sorry Altoid ...
Whatever for?
We're just exchanging ideas.
And in a civilised manner.  ;^D
greenjeans wrote:
... gvfs works really well with PcmanFM ...
I also worked for me till I uninstalled it but quite a few things stopped working properly.
So I installed it again and I then had other issues.
Like I mentioned, getting rid of PCManFM solved the problem.
greenjeans wrote:
For me ...
No need to justify anything, to me or anyone else.
My objections to gvfs are based on it being wired, like the OP wrote, to be a jack-of-all-trades.
Does that approach to writing Linux applications sound familiar to you?
#24 2026-03-24 20:09:36
tux_99 wrote:
... don't know what's the root cause of your issues ...
Hmm ...
I have so many, but the root cause to any of them has eluded me from an early age.
Most of them can be found in any edition of Jon Winokur's 'The Portable Curmudgeon'.
... don't have any of those files you listed in that dbus folder ...
That is because I have gvfs installed and you do not.
I had to reinstall it.
