#1 2026-02-21 13:19:27
markus23
[Excalibur] LXC in Proxmox: /run not mounted as tmpfs
Problem
When creating an LXC container in Proxmox 9, /run and /tmp are not mounted as tmpfs.
This causes e.g. the eth0 network interface to stay DOWN after
pct start
(on proxmox), even though
/etc/network/interfaces
is correctly configured with
allow-hotplug eth0
auto eth0
has same behavior) and the right IP.
**Workaround:** After boot, running
ifdown eth0 && ifup eth0
brings the interface up correctly or removing some files in /run at early stages:
/run/network/ifstate /run/network/ifstate.* /run/network/.ifstate.lock
Reproduction
Reproducible for both
1.  devuan-6.0-excalibur_20251124_amd64.tar.xz https://fra1lxdmirror01.do.letsbuildthe … tfs.tar.xz 29adc79fae8c0a0be17533fbe91b85d87fe0133753572575b111479c056dccd4
2.. Devuan Excalibur LXC image from linuxcontainers.org (2026-02-20)
pct create 130 local:vztmpl/devuan-6.0-ansible-ready.tar.zst \
  --hostname test --storage local-zfs --cores 2 --memory 8192 --swap 8192 \
  --rootfs local-zfs:80 --net0 "name=eth0,bridge=vmbr1,ip=10.0.0.30/24,gw=10.0.0.254" \
  --unprivileged 1 --onboot 1
pct start 130
pct exec 130 -- ip addr show eth0
# Shows: state DOWN, qdisc noop, no inet address
Current Status
What doesn't work is mounting /run within the bootup, as we want the container to not have these privileges.
The mount already present in the bootup scripts fails silently.
What we are currently investigating if
pct --features ,mount=<fstype;fstype;....
can be helpful.
https://pve.proxmox.com/pve-docs/pct.1.html
Does anyone use Devuan Excalibur as container in Proxmox and can us help here?
#2 2026-02-21 15:25:51
markus23
Re: [Excalibur] LXC in Proxmox: /run not mounted as tmpfs
Solution is to add in
/etc/pve/lxc/<vmid>.conf
lxc.mount.entry: tmpfs run tmpfs rw,nosuid,nodev,relatime 0 0
