when i connect the Xbox Controller, stock at the TEST at "jstest-gtk" and not work at all emulators.
but they work fine at Window$ :-/
https://pasteboard.co/zZBhEqBazxrm.png
https://pasteboard.co/VvuAO7eWBRuD.png
they appear AXIS 2 and AXIS 5 moved to the top ! (lesft or rigth )
Bus 003 Device 017: ID 045e:028e Microsoft Corp. Xbox360 Controller
xboxdrv --dbus session --detach-kernel-drive
(not Work)
# xboxdrv --dbus session --detach-kernel-drive
-- [ ERROR ] ------------------------------------------------------
unrecognized option '--detach-kernel-drive'
/usr/bin/xboxdrvctl' -S
File "/usr/bin/xboxdrvctl", line 68, in <module>
bus = dbus.SessionBus()
File "/usr/lib/python3/dist-packages/dbus/_dbus.py", line 209, in __new__
return Bus.__new__(cls, Bus.TYPE_SESSION, private=private,
File "/usr/lib/python3/dist-packages/dbus/_dbus.py", line 99, in __new__
bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop)
File "/usr/lib/python3/dist-packages/dbus/bus.py", line 120, in __new__
bus = cls._new_for_bus(address_or_type, mainloop=mainloop)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11 ----
i try other commands , share by a friend from IRC :
1.- # rmmod xpad
2.- $ pgrep -f xboxdrv
3.- pkill -f xboxdrv
4.-$ xboxdrv --daemon < ---- OBLIGATORIO
5.-$ /usr/bin/xboxdrvctl --status
root@DELL:~# rmmod xpad
root@DELL:~# grep -f xboxdrv
grep: xboxdrv: No such file or directory
root@DELL:~# pkill -f xboxdrv
root@DELL:~# xboxdrv --daemon
xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/
Copyright © 2008-2011 Ingo Ruhnke <grumbel@gmail.com>
Licensed under GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details.
[ERROR] XboxdrvDaemon::run(): fatal exception: failed to get unique dbus name: Connection ":1.184" is not allowed to own the service "org.seul.Xboxdrv" due to security policies in the configuration file
root@DELL:~#
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11then i lose the controller at jstest-gtk
need , reconect the wire USB, to appear,
but still frozen!
does the xboxdrv daemon need to be started via the root user?
xpad should just work now, its a builtin kernel module.
