#1 2026-02-01 06:12:58
Qemu help
How do I switch to control alt f1-f12 in a vm on qemu?
I keep searching online but the search results are pretty damn useless.
One thing that popups a lot is sendkey, but what is the linux sendkey?
What key on the keyboard is that?
I don't understand
#2 2026-02-01 08:33:13
Re: Qemu help
you need to add a parameter to qemu so that it attaches its "monitor" to either a socket that you can connect to, OR as multiplexed with the serial console.
For the first option, you add the qemu command line arguments -monitor unix:QEMU,server,nowait, and thereby get its monitor serving the socket QEMU in the working directory. You then connect to that via socat with a command like the following
socat -,escape=0x1c,rawer unix:QEMU
which sets up a raw termnal connection to that monitor; you break the connection with key ctrl-\ (control-backslash).
For the second option you instead modify (or add) serial line arguments to be -serial mon:stdio, and thereby get multiplexed monitor and serial console on the run terminal. In that case it starts in serial mode so you need to press ctrl-a c to switch to the qemu monitor.
Then, once you have the monitor, you will issue the commands like sendkey ctrl-alt-f2 etc so as to make the monitor send that key.
hth
#3 2026-02-02 05:33:45
Re: Qemu help
@ralph
It seems I found a way, I misunderstood what I was seeing on the search engine.
I tried typing in sendkey ctrl alt f1 or something like that in qemu part and it worked.
That was a result I saw, but I misunderstood the sendkey part. where that was.
