#1 2026-01-20 10:44:35
kapqa
[SOLVED] (Alsa) Freia/Ceres - getting updates / should i be concerned?
Hello ,
have installed on the main laptop the Devuan Testing
and it seem function just fine;
however, nearly ever other day am receiving update to the laptop,
and for now , just tuckin along with them.
Today, got the alarm ring, now should i be concerned?
In all those packages, there is listed
libpulse-dev libpulse0 libpulse-mainloop-glib0 libpulsedsp
now , will installing these packages "break" the (supposed) alsa-only setup,
or has it already been compromised??
thank you very much.
https://ibb.co/FLZS03sd
https://ibb.co/RpLm09ZL
https://ibb.co/B2hGqX0n
https://ibb.co/yc4p0yJ8
https://ibb.co/h1FXXzJv
#2 2026-01-20 12:47:30
unixuser
Re: [SOLVED] (Alsa) Freia/Ceres - getting updates / should i be concerned?
Hi, libpulse0 is a dependence of chromium, ffmpeg, mpv, i3wm, etc...
It means it is present to build those programs but not necessarily used. If you don't have a pulse server it won't be activated (I HOPE).
To get rid of it you could recompile, for example chromium without this lib but it is hard work for a little.
If those libs need to be upgraded, it means they are already present on your system, please try to see why they are here and try to remove it.
#3 2026-01-20 13:04:53
igorzwx
$ apt remove libpulse0 --simulate
NOTE: This is only a simulation!
      apt needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
chromium chromium-driver chromium-l10n chromium-shell
ffmpeg ffmpegthumbnailer
mate-control-center mate-desktop-environment mate-desktop-environment-core mate-desktop-environment-extra mate-desktop-environment-extras mate-media mate-settings-daemon mate-user-guide
#4 2026-01-20 16:58:14
kapqa
thank you ,
your help has been very much appreciated.
think this can be marked solved.
sudo apt remove libpulse0 --simulate
[sudo] password for rich:
  accountwizard                 kgamma                          libjavascriptcoregtk-4.1-0        libklipper6                      libopenal-data                      milou
  aha                           kimageformat6-plugins           libjavascriptcoregtk-6.0-1        libklookandfeel6                 libopenal1                          mobile-broadband-provider-info
  akonadi-backend-mysql         kinfocenter                     libjs-underscore                  libkmailtransport-data           libopenh264-8                       network-manager
  akonadi-contacts-data         kio-extras-data                 libkaccounts6-2                   libkmime-data                    libopenni2-0                        network-manager-l10n
  akonadi-mime-data             kio-fuse                        libkate1                          libkmpris6                       libphonon-l10n                      nm-connection-editor
  akonadi-server                kio-ldap                        libkcalendarutils-data            libkolabxml1v5                   libpimcommon-data                   ocean-sound-theme
  amarok-common                 kmailtransport-plugins          libkcolorpicker-qt6-0             libkontactinterface-data         libpipewire-0.3-dev                 okular-data
  amarok-utils                  kmenuedit                       libkdcrawqt6-5                    libkpim6akonadiagentbase6        libplasma-geolocation-interface6    okular-doc
  amule-common                  knighttime                      libkdsoap-qt6-2                   libkpim6akonadiagentwidgetbase6  libplasma5support-data              oxygen-sounds
  amule-utils                   konqueror-data                  libkdsoapwsdiscoveryclient0       libkpim6akonadicalendarcore6     libplasma5support6                  partitionmanager
  apt-config-icons-large        konqueror-doc                   libkexiv2qt6-0                    libkpim6akonadicontactcore6      libplasmaactivitiesstats1           plasma-desktop-data
  apt-config-icons-large-hidpi  kscreen                         libkeybinder-3.0-0                libkpim6akonadicore6             libplasmaweatherdata6               plasma-desktop-doc
  audacity-data                 ksystemstats                    libkf5style5                      libkpim6akonadimime6             libplasmaweatherion6                plasma-discover-common
  baloo6                        kup-backup                      libkf6baloo6                      libkpim6akonadiprivate6          libportaudio2                       plasma-disks
  bluedevil                     kwin-style-breeze               libkf6balooengine6                libkpim6akonadisearchcore6       libportmidi2                        plasma-integration
  breeze                        kwin-wayland                    libkf6baloowidgets6               libkpim6akonadisearchdebug6      libportsmf0t64                      plasma-systemmonitor
  breeze-cursor-theme           kwrited                         libkf6bluezqt-data                libkpim6akonadisearchpim6        libpowerdevilcore2                  plasma-thunderbolt
  breeze-gtk-theme              libaccounts-glib0               libkf6bluezqt6                    libkpim6akonadisearchxapian6     libprocesscore10                    plasma-vault
  breeze-wallpaper              libaccounts-qt6-1               libkf6bookmarks-dev               libkpim6akonadiwidgets6          libprotobuf-lite32t64               plasma-workspace-data
  bup                           libakonadi-data                 libkf6bookmarks-doc               libkpim6calendarutils6           libproxy-tools                      plasma-workspace-doc
  bup-doc                       libakonadicalendar-data         libkf6calendarcore6               libkpim6gapicalendar6            libpthreadpool0                     plasma5-integration
  chromium-common               libakonadisearch-bin            libkf6completion-dev              libkpim6gapicore6                libqalculate-data                   power-profiles-daemon
  chromium-sandbox              libakonadisearch-data           libkf6completion-doc              libkpim6gapipeople6              libqalculate23                      powerdevil-data
  cinnamon-common               libakonadisearch-plugins        libkf6contacts-data               libkpim6gapitasks6               libqcoro6core0t64                   python3-brlapi
  cinnamon-control-center-data  libamd3                         libkf6contacts6                   libkpim6grantleetheme6           libqcoro6dbus0t64                   python3-bsddb3
  cjs                           libappstreamqt3                 libkf6dav-data                    libkpim6gravatar6                libqgpgmeqt6-15                     python3-dasbus
  cryfs                         libaribb24-0t64                 libkf6dav6                        libkpim6identitymanagementcore6  libqt5positioning5                  python3-fuse
  debconf-kde-data              libasm1t64                      libkf6globalaccel-dev             libkpim6imap6                    libqt5webchannel5                   python3-ibus-1.0
  default-mysql-client-core     libavc1394-0                    libkf6globalaccel-doc             libkpim6itinerary6               libqt5webengine-data                python3-louis
  default-mysql-server-core     libavformat61                   libkf6itemviews-dev               libkpim6kmanagesieve6            libqt5webengine5                    python3-mutagen
  dnsmasq-base                  libavtp0                        libkf6itemviews-doc               libkpim6kontactinterface6        libqt5webenginecore5                python3-pyasyncore
  dolphin-data                  libbabl-0.1-0                   libkf6jobwidgets-dev              libkpim6ksieve6                  libqt6bluetooth6                    python3-pyinotify
  dolphin-doc                   libbaloowidgets-bin             libkf6jobwidgets-doc              libkpim6ldapcore6                libqt6bluetooth6-bin                python3-pylibacl
  drkonqi                       libbatterycontrol6              libkf6kio-dev                     libkpim6ldapwidgets6             libqt6keychain1                     python3-pyqt6
  elfutils                      libboost-chrono1.88.0           libkf6kio-doc                     libkpim6libkleo6                 libqt6location6                     python3-pyqt6.sip
  espeak-data                   libboost-filesystem1.88.0       libkf6konq7                       libkpim6mailtransport6           libqt6networkauth6                  python3-pyxattr
  espeak-ng-data                libboost-program-options1.88.0  libkf6konqsettings7               libkpim6mbox6                    libqt6webview6                      python3-sentry-sdk
  ffmpegthumbs                  libboost-thread1.83.0           libkf6modemmanagerqt6             libkpim6mime6                    librest-1.0-0                       python3-speechd
  filezilla-common              libboost-thread1.88.0           libkf6networkmanagerqt6           libkpim6mimetreeparser6          librhythmbox-core10                 qml-module-org-kde-qqc2desktopstyle
  fonts-dejavu                  libcalendarsupport-data         libkf6notifications-dev           libkpim6pimcommonactivities6     libsamplerate0-dev                  qml-module-org-kde-sonnet
  fonts-hack                    libcamd3                        libkf6notifications-doc           libkpim6pkpass6                  libsasl2-modules-kdexoauth2         qml-module-qtwebengine
  frameworkintegration6         libccolamd3                     libkf6parts-dev                   libkpim6smtp6                    libsbc1                             qml6-module-org-kde-activities
  geoclue-2.0                   libcholmod5                     libkf6parts-doc                   libkpim6tnef6                    libsbsms10                          qml6-module-org-kde-baloo
  geocode-glib-common           libcinnamon-control-center1     libkf6people-data                 libkpimtextedit-data             libscim8v5                          qml6-module-org-kde-bluezqt
  gimp-data                     libcinnamon-menu-3-0            libkf6people6                     libkpipewire-data                libsgutils2-1.48                    qml6-module-org-kde-breeze
  gir1.2-accountsservice-1.0    libcjs0                         libkf6peoplebackend6              libkpipewire6                    libshout3                           qml6-module-org-kde-guiaddons
  gir1.2-babl-0.1               libcolamd3                      libkf6prison6                     libkpipewiredmabuf6              libsignon-plugins-common1           qml6-module-org-kde-kdeconnect
  gir1.2-camel-1.2              libcpuinfo0                     libkf6purpose-data                libkpipewirerecord6              libsignon-qt6-1                     qml6-module-org-kde-kholidays
  gir1.2-cmenu-3.0              libcrypto++8t64                 libkf6purpose6                    libkpmcore12                     libsonic0                           qml6-module-org-kde-kirigamiaddons-tableview
  gir1.2-ecal-2.0               libdca0                         libkf6purposewidgets6             libkscreen-bin                   libsoundtouch1                      qml6-module-org-kde-ksysguard
  gir1.2-edataserver-1.2        libddcutil5                     libkf6screen8                     libksieve-data                   libspa-0.2-bluetooth                qml6-module-org-kde-notifications
  gir1.2-gck-1                  libdecor-0-dev                  libkf6service-dev                 libksmtp-data                    libspa-0.2-dev                      qml6-module-org-kde-people
  gir1.2-gcr-3                  libdisplay-info-bin             libkf6service-doc                 libksysguard-bin                 libspandsp2t64                      qml6-module-org-kde-pipewire
  gir1.2-gexiv2-0.10            libdmapsharing-4.0-3t64         libkf6solid-dev                   libksysguard-data                libspatialaudio0t64                 qml6-module-org-kde-plasma-plasma5support
  gir1.2-girepository-2.0       libdmtx0t64                     libkf6solid-doc                   libksysguardformatter2           libspdlog1.15                       qml6-module-org-kde-syntaxhighlighting
  gir1.2-gsound-1.0             libdnnl3.6                      libkf6sonnet-dev                  libksysguardsensorfaces2         libspeechd-module0                  qml6-module-org-kde-userfeedback
  gir1.2-ibus-1.0               libdolphinvcs6                  libkf6sonnet-dev-bin              libksysguardsensors2             libspeexdsp1                        qml6-module-qtlocation
  gir1.2-ical-3.0               libdotconf0                     libkf6sonnet-doc                  libksysguardsystemstats2         libsrtp2-1                          qml6-module-qtwebview
  gir1.2-keybinder-3.0          libdv4t64                       libkf6sonnetui6                   libktextaddons-data              libsuil-0-0                         qml6-module-sso-onlineaccounts
  gir1.2-meta-muffin-0.0        libdvbpsi10                     libkf6syntaxhighlighting-data     libktnef-data                    libsuitesparseconfig7               qt6-base-private-dev
  gir1.2-nemo-3.0               libecal-2.0-3                   libkf6syntaxhighlighting-dev      libkworkspace6-6                 libtaskmanager6                     qt6-location-plugins
  gir1.2-nm-1.0                 libedata-cal-2.0-2t64           libkf6syntaxhighlighting-doc      liblastfm6-1                     libteamdctl0                        rhythmbox-data
  gir1.2-nma-1.0                libeditorconfig0                libkf6syntaxhighlighting6         liblc3-1                         libtextautogenerate-cmark-rc-copy0  signon-plugin-oauth2
  gir1.2-rb-3.0                 libei1                          libkf6textaddonswidgets1          libldacbt-abr2                   libtheora1                          smartmontools
  gir1.2-soup-3.0               libevdev-dev                    libkf6textautocorrectioncore1     libldacbt-enc2                   libtimezonemap-data                 sound-icons
  gir1.2-timezonemap-1.0        libeventviews-data              libkf6textautocorrectionwidgets1  liblrdf0                         libtimezonemap1                     sshfs
  gir1.2-totem-1.0              libexif-doc                     libkf6texteditor-data             libltc11                         libtotem0                           timgm6mb-soundfont
  gir1.2-totemplparser-1.0      libfakekey0                     libkf6texteditor-doc              libmailcommon-data               libumfpack6                         totem-common
  gir1.2-upowerglib-1.0         libfilezilla-common             libkf6textemoticonscore1          libmailimporter-data             libupnp17t64                        totem-video-thumbnailer
  gir1.2-wnck-3.0               libfilezilla50                  libkf6textemoticonswidgets1       libmbedtls21                     libvamp-hostsdk3t64                 user-session-migration
  gkbd-capplet                  libfreeaptx0                    libkf6textgrammarcheck1           libmbedx509-7                    libvlc-bin                          vlc-bin
  gnome-backgrounds             libfreerdp3-3                   libkf6texttranslator1             libmediaart-2.0-0                libvlc5                             vlc-data
  gnome-online-accounts         libgegl-common                  libkf6textutils1                  libmjpegutils-2.2-0              libvlccore9                         vlc-l10n
  gnome-online-accounts-gtk     libgeocode-glib-2-0             libkf6textwidgets-data            libmozjs-128-0                   libvo-aacenc0                       vlc-plugin-access-extra
  grilo-plugins-0.3             libgit2-1.9                     libkf6textwidgets-doc             libmpeg2encpp-2.2-0              libvo-amrwbenc0                     vlc-plugin-notify
  gwenview-doc                  libgoa-backend-1.0-2            libkf6userfeedback-data           libmplex2-2.2-0                  libwacom-dev                        vlc-plugin-qt
  ibus                          libgom-1.0-0t64                 libkf6userfeedback-doc            libmtdev-dev                     libweather-ion7                     vlc-plugin-samba
  ibus-data                     libgpod-common                  libkf6userfeedbackcore6           libmusicbrainz5-2                libwildmidi2                        vlc-plugin-skins2
  iio-sensor-proxy              libgpod4t64                     libkf6userfeedbackwidgets6        libmygpo-qt6-1                   libwinpr3-3                         vlc-plugin-video-output
  im-config                     libgrantleetheme-data           libkf6xmlgui-dev                  libmypaint-1.5-1                 libwnck-3-0                         vlc-plugin-video-splitter
  install-info                  libgrantleetheme-plugins        libkf6xmlgui-doc                  libmypaint-common                libwnck-3-common                    vlc-plugin-visualization
  kaccounts-providers           libgravatar-data                libkfontinst6                     libndp0                          libwxbase3.2-1t64                   vulkan-tools
  kaddressbook-data             libgrilo-0.3-0                  libkfontinstui6                   libneon27t64                     libxcb-xtest0                       wayland-utils
  kamera                        libgweather-4-0t64              libkgantt6-3                      libnm0                           libxcb-xv0                          xbrlapi
  kate-data                     libgweather-4-common            libkgapi-data                     libnma-common                    libxmp4                             xkbset
  kde-config-gtk-style          libhttp-parser2.9               libkglobalaccelmodel6             libnma0                          libxnnpack0.20241108                xsettingsd
  kde-config-sddm               libhyphen0                      libkimageannotator-common         libnotificationmanager1          libzbar0t64                         xwayland
  kde-config-updates            libibus-1.0-dev                 libkimageannotator-qt6-0          liboauth0                        libzxing3                           xwaylandvideobridge
  kde-style-breeze-qt5          libiec61883-0                   libkimap-data                     liboeffis1                       mariadb-client-core                 yelp-xsl
  kdeconnect-libs               libincidenceeditor-data         libkitinerary-data                libonnx1t64                      mariadb-server-core
  kdegraphics-thumbnailers      libinput-dev                    libkldap-data                     libonnxruntime-providers         messagelib-data
  kdenetwork-filesharing        libixml11t64                    libkleo-data                      libonnxruntime1.21               metacity-common
Installing dependencies:
  libfm-extra4t64  libfm-qt-l10n  libfm-qt6-17  libmenu-cache-bin  libmenu-cache3  lxqt-menu-data  wine-devel:i386  xdg-desktop-portal-lxqt
REMOVING:
  akregator                     gir1.2-gegl-0.4            konq-plugins                 libkf6texteditor-katepart           libokular6core4           orca                                 speech-dispatcher
  alsa-config-utils             gir1.2-gimp-3.0            konqueror                    libkf6texteditor6                   libpcaudio0               phonon4qt5-backend-gstreamer         speech-dispatcher-audio-plugins
  amarok                        gnome-sound-recorder       konsole                      libkf6textedittexttospeech1         libphonon4qt5-4t64        phonon4qt5-backend-vlc               speech-dispatcher-espeak-ng
  amule                         gstreamer1.0-plugins-bad   konsole-kpart                libkf6textwidgets-dev               libphonon4qt6-4t64        phonon4qt6                           sweeper
  audacious-plugins             gstreamer1.0-plugins-good  korganizer                   libkf6textwidgets6                  libpulse-dev              phonon4qt6-backend-vlc               task-cinnamon-desktop
  audacity                      gstreamer1.0-pulseaudio    kwrite                       libkpim6addressbookimportexport6    libpulse-mainloop-glib0   pim-data-exporter                    task-kde-desktop
  blueman                       gwenview                   libasound2-plugin-fftrate    libkpim6akonadicalendar6            libpulse0                 pim-sieve-editor                     tipp10
  chromium                      juk                        libasound2-plugins           libkpim6akonadicontactwidgets6      libpulsedsp               plasma-browser-integration           totem
  cinnamon                      kaddressbook               libavdevice62                libkpim6calendarsupport6            libqt6multimedia6         plasma-desktop                       totem-plugins
  cinnamon-control-center       kalendarac                 libcvc0t64                   libkpim6eventviews6                 libqt6multimediawidgets6  plasma-discover                      vlc
  cinnamon-core                 kate                       libdebconf-kde1              libkpim6identitymanagementwidgets6  libqt6texttospeech6       plasma-discover-backend-fwupd        vlc-plugin-base
  cinnamon-desktop-environment  kde-baseapps               libedataserverui-1.2-4t64    libkpim6importwizard6               libqt6virtualkeyboard6    plasma-widgets-addons                webext-plasma-browser-integration
  cinnamon-settings-daemon      kde-plasma-desktop         libespeak-ng1                libkpim6incidenceeditor6            libsdl2-2.0-0             plasma-workspace                     wine-devel
  debconf-kde-helper            kde-spectacle              libespeak1                   libkpim6ksievecore6                 libsdl2-classic           powerdevil                           wine-devel-amd64
  dolphin                       kde-standard               libfluidsynth-dev            libkpim6ksieveui6                   libsdl2-dev               pulseaudio-utils                     xdg-desktop-portal
  dolphin-plugins               kdeaccessibility           libfluidsynth3               libkpim6mailcommon6                 libsdl2-image-2.0-0       python3-pygame                       xdg-desktop-portal-gtk
  dragonplayer                  kdeconnect                 libfreerdp-client3-3         libkpim6mailimporter6               libsdl2-mixer-2.0-0       qml6-module-org-kde-prison           xdg-desktop-portal-kde
  espeak                        kdepim-addons              libgegl-0.4-0t64             libkpim6mailimporterakonadi6        libsdl2-ttf-2.0-0         qml6-module-org-kde-purpose          xdg-desktop-portal-xapp
  espeakup                      kdepim-runtime             libgimp-3.0-0                libkpim6messagecomposer6            libsdl3-0                 qml6-module-qtmultimedia             yakuake
  evolution-data-server         kdepim-themeeditors        libkcompactdisc6-5           libkpim6messagecore6                libsdl3-dev               qml6-module-qtquick-virtualkeyboard  yelp
  evolution-ews-core            kdialog                    libkf6prisonscanner6         libkpim6messagelist6                libwebkit2gtk-4.1-0       qsynth                               zoom
  exaile                        kio-audiocd                libkf6pulseaudioqt5          libkpim6messageviewer6              libwebkitgtk-6.0-4        remmina-plugin-rdp
  ffmpeg                        kio-extras                 libkf6purpose-bin            libkpim6pimcommon6                  libwxgtk3.2-1t64          rhythmbox
  filezilla                     kmail                      libkf6textautogeneratetext1  libkpim6pimcommonakonadi6           libyelp-1-0               rhythmbox-plugin-cdrecorder
  fluidsynth                    kmix                       libkf6textcustomeditor1      libkpim6templateparser6             mbox-importer             rhythmbox-plugins
  gimp                          kmousetool                 libkf6texteditor-bin         libkpim6textedit6                   mediainfo-gui             software-properties-qt
  gir1.2-cvc-1.0                kmouth                     libkf6texteditor-dev         libkpim6webengineviewer6            okular                    sound-juicer
Summary:
  Upgrading: 0, Installing: 8, Removing: 183, Not Upgrading: 3
Remv akregator [4:sudo apt remove libpulse0 --simulate
REMOVING:
Summary:
Remv akregator [4:25.08.3-2]
25.08.3-2]
