#1 2026-01-18 20:41:35
Duke Nukem
[SOLVED] Seeing Partitions on a Server
I have a server at 192.168.1.6 with more than one disk drive and some of those with more than one partition, for example a data partition on the mount point /home/server_name/Data/
My client PC successfully mounts (eg on /mnt by nfs) 192.168.1.6:/home/server_name and I can see the directory called Data, but it displays empty. The strange thing is that I have tried this several times, including mounting the server partition within the server either before or after the network mount, and sometimes I can see the files in the mounted partition below Data and sometimes I can't. There seems to be no consistency, and all the advice I can find seems to assume that the server only needs to show the client one level of partition.
What am I missing here? Are there some rules about this?  I suppose I could mount the server's separate partitions each as a separate entity, in parallel, rather than as a tree. That sounds a bit like Windows though.
#2 2026-01-19 08:47:33
Re: [SOLVED] Seeing Partitions on a Server
If you don't show us what is in /etc/exports and where your filesystems are mounted server, and /etc/fstab on the client, all that remains is speculation.
Speculation: You are trying to export a directory that contains mountpoints for other filesystems, without specifying the 'crossmnt' flag. See the exports(5) manual page.
#3 2026-01-19 11:30:26
Duke Nukem
Correct, thanks for that advice and the problem is now sorted.
FWIW, the exports manual page is not available on the client where I had been looking for it, only on the server. That's logical I suppose.
