#1 2026-01-08 22:48:14
maccine2012
Issues running EasyEffects
Hi friends.
I'm having trouble getting EasyEffects to work on Devuan. I've already tried the native package from the Debian repository. I've also tried via flatpak, and nothing works. The following error messages appear:
DEBIAN PACKAGE
"devu2012@devu2012:~$ easyeffects
[W][19:40:18.718393] pw.conf      | [          conf.c: 1204 pw_conf_load_conf_for_context()] setting config.name to client-rt.conf is deprecated, using client.conf
(easyeffects:2890): easyeffects-ERROR **: 19:40:18.719:         pipe_manager.cpp:1598   context connection failed
Trace/breakpoint trap
devu2012@devu2012:~$ "
FLATPAK
"devu2012@devu2012:~$ flatpak run com.github.wwmm.easyeffects
ldconfig: /app/lib/libQt6Graphs.so.6 não é um link simbólico
ldconfig: /app/lib/libQt6GraphsWidgets.so.6 não é um link simbólico
easyeffects: pw_manager.cpp:327 Context connection failed
Has anyone else experienced this problem and have any idea how to solve it? I'm using Devuan Excalibur with Runit.
#2 2026-01-09 14:58:06
steveo314
Re: Issues running EasyEffects
What was your outcome with the package in the devuan excalibur repo?
#3 2026-01-09 20:39:57
maccine2012
the outcome was:
(easyeffects:10701): Gtk-WARNING **: 17:36:15.115: Unknown key gtk-modules in /home/devu2012/.config/gtk-4.0/settings.ini
[W][17:36:15.185632] pw.conf      | [          conf.c: 1204 pw_conf_load_conf_for_context()] setting config.name to client-rt.conf is deprecated, using client.conf
(easyeffects:10701): easyeffects-ERROR **: 17:36:15.187:        pipe_manager.cpp:1598   context connection failed
Image of the terminal: https://imgur.com/a/bpXmWWc
