#1 2026-01-07 16:43:01
igorzwx
Bluetooth Audio: How It Works
The following is a simplified log of a BlueALSA session, with extraneous lines discreetly removed for clarity.
# COMMAND: Start BlueALSA with AAC codec and debug logging
sudo -u bluealsad bluealsad -p a2dp-source -p a2dp-sink -p hfp-ag -p hfp-hf -c -sbc -c aac -c msbc --aac-afterburner --aac-bitrate=320000 --aac-vbr --aac-true-bps --loglevel=debug
# DAEMON INITIALIZATION
bluealsad: [31361] D: log.c:701: FDK-AAC encoder capabilities: AAC=[AAC-LC AAC-SCAL DRC ] SBR=[SBR-PS ] DMX=[none]
bluealsad: [31361] D: log.c:701: FDK-AAC decoder capabilities: AAC=[AAC-LC HE-AAC AAC-LD AAC-ELD AAC-SCAL DRC ] SBR=[SBR-HQ SBR-PS ] DMX=[2ch 6ch 8ch ]
bluealsad: [31361] D: storage.c:86: Initializing persistent storage: /var/lib/bluealsa
bluealsad: [31361] D: main.c:707: Starting main dispatching loop
bluealsad: [31361] D: main.c:121: Acquired D-Bus service name: org.bluealsa
bluealsad: [31361] D: bluealsa-dbus.c:404: Registering BlueALSA D-Bus manager: /org/bluealsa
# AAC CODEC DISCOVERY
bluealsad: [31361] D: bluez.c:1271: Adding new Stream End-Point: EC:66:D1:BF:02:05: SNK: AAC
bluealsad: [31361] D: log.c:347: AAC_CODEC: AAC capabilities - Object Type=MPEG2-LC | MPEG4-LC, Sample Rate=8000 Hz | 11025 Hz | 12000 Hz | 16000 Hz | 22050 Hz | 24000 Hz | 32000 Hz | 44100 Hz | 48000 Hz, Channels=Mono | Stereo, VBR=enabled, Bitrate=320000
# AAC CODEC NEGOTIATION
bluealsad: [31361] D: dbus.c:43: Called: org.bluez.MediaEndpoint1.SelectConfiguration() on /org/bluez/hci0/A2DP/AAC/source/1
bluealsad: [31361] D: bluez.c:442: BlueZ endpoint select_configuration called
bluealsad: [31361] D: log.c:347: AAC_CODEC: _CODEC: A2DP peer capabilities - Object Type=MPEG2-LC | MPEG4-LC, Sample Rate=8000 Hz | 11025 Hz | 12000 Hz | 16000 Hz | 22050 Hz | 24000 Hz | 32000 Hz | 44100 Hz | 48000 Hz, Channels=Mono | Stereo, VBR=enabled, Bitrate=320000
bluealsad: [31361] D: a2dp-aac.c:664: AAC configuration_select called
bluealsad: [31361] D: dbus.c:43: Called: org.bluez.MediaEndpoint1.SetConfiguration() on /org/bluez/hci0/A2DP/AAC/source/1
bluealsad: [31361] D: log.c:347: AAC_CODEC: A2DP selected configuration - Object Type=MPEG4-LC, Sample Rate=48000 Hz, Channels=Stereo (2), VBR=enabled, Bitrate=320000
bluealsad: [31361] D: bluez.c:637: A2DP Source (AAC) configured for device EC:66:D1:BF:02:05
bluealsad: [31361] D: bluez.c:640: PCM configuration: channels=2 rate=48000
bluealsad: [31361] D: bluez.c:642: Delay reporting: unsupported
# AUDIO STREAMING SETUP
bluealsad: [31401] D: dbus.c:43: Called: org.bluealsa.PCM1.Open() on /org/bluealsa/hci0/dev_EC_66_D1_BF_02:05/a2dpsrc/sink
bluealsad: [31401] D: ba-transport.c:316: New A2DP transport: 28
bluealsad: [31401] D: ba-transport.c:317: A2DP socket MTU: 28: R:672 W:895
bluealsad: [31361] D: ba-transport.c:1082: Starting transport: A2DP Source (AAC)
bluealsad: [31361] D: ba-transport-pcm.c:287: Created BT socket duplicate: [28]: 29
bluealsad: [31361] D: ba-transport-pcm.c:366: Created new IO thread [ba-a2dp-aac]: A2DP Source (AAC)
bluealsad: [31419] D: a2dp-aac.c:332: AAC_CODEC: Encoder Info - FrameLength=1024, InputChannels=2, MaxOutBufBytes=1536, Delay=1600 samples
bluealsad: [31419] D: a2dp-aac.c:336: AAC_CODEC: Configuration - Bitrate=320000, Afterburner=enabled, VBR=enabled, Quality=VBR
bluealsad: [31419] D: a2dp-aac.c:391: PCM IO loop: START: a2dp_aac_enc_thread: A2DP Source (AAC)
# AAC Frame Monitoring
bluealsad: [31419] D: a2dp-aac.c:419: AAC_CODEC: Frame - Output bytes=497, Target bitrate=320000
bluealsad: [31419] D: a2dp-aac.c:419: AAC_CODEC: Frame - Output bytes=496, Target bitrate=320000
bluealsad: [31419] D: a2dp-aac.c:419: AAC_CODEC: Frame - Output bytes=600, Target bitrate=320000
bluealsad: [31419] D: a2dp-aac.c:419: AAC_CODEC: Frame - Output bytes=469, Target bitrate=320000
Command Line Options
  • sudo -u bluealsad: Runs the daemon under a dedicated user—nothing excessive, just sound security practice.
  • -p a2dp-source -p a2dp-sink: Enables bidirectional audio. One might call it thorough.
  • -p hfp-ag -p hfp-hf: Supports hands-free calling. Useful, if one must.
  • -c aac: Enables the AAC codec—rather more refined than the alternatives.
  • --aac-afterburner: Activates Fraunhofer’s quality enhancement. It does its work quietly.
  • --aac-bitrate=320000: Sets a generous bitrate. One might say it leaves nothing wanting.
  • --aac-vbr: Prefers variable bit rate—efficient without being showy.
  • --aac-true-bps: Ensures accurate bit-per-second reporting. A minor detail, but a correct one.
  • --loglevel=debug: Enables verbose logging. Helpful, if one is inclined to look.
NOTE: To enable debug, you have to compile bluez-alsa with --enable-debug. Then you can run bluealsad daemon with --loglevel=debug.
Security:
./configure --with-bluealsaduser=bluealsad       # D-Bus policy files are automatically generated with the correct user permissions
Running BlueALSA as the bluealsad user is not an indulgence—it is a matter of principle. The daemon operates with minimal privileges, should anything untoward occur.
  • Least Privilege: The bluealsad user has no unnecessary access. One might say it knows its place.
  • Systemd Sandboxing: Features such as ProtectSystem=strict and IPAddressDeny=any ensure the service remains discreet.
  • D-Bus Policy Control: Communication is limited to org.bluealsa. No eavesdropping, no surprises.
  • Filesystem Confinement: The daemon is restricted to /var/lib/bluealsa. One might call it tidy.
This is not paranoia—it is simply good form.
Daemon Startup Process
# FDK-AAC library capabilities - what audio formats we can encode/decode
EXPLANATION: BlueALSA checks what AAC formats your system supports. The encoder can handle basic AAC-LC and scalable coding, while the decoder supports advanced formats like HE-AAC for better compression.
# System initialization
EXPLANATION: BlueALSA starts up, creates storage for remembering device settings, and registers with the Linux D-Bus system so applications can communicate with it.
AAC Codec Discovery
# Device announces its AAC support
EXPLANATION:  The Bluetooth device, that is, BT Headphones, EC:66:D1:BF:02:05 tells BlueALSA it supports AAC audio. It can handle many sample rates from 8kHz (voice quality) up to 48kHz (CD quality), supports mono and stereo, and can use Variable Bit Rate for efficient encoding.
AAC Codec Negotiation
# BlueZ asks BlueALSA to select the best AAC configuration
EXPLANATION: The Bluetooth system (BlueZ) asks BlueALSA to choose the best AAC settings. BlueALSA looks at what the device (that is, BT Headphones) supports and selects optimal parameters.
# Final configuration is selected and applied
EXPLANATION: BlueALSA selects the best quality settings: MPEG4-LC at 48kHz stereo with 320kbps VBR. This provides near-CD quality audio. The PCM is configured to match these settings.
Audio Streaming Setup
# Application requests to play audio
EXPLANATION: An application (like mpv) asks to play audio through the Bluetooth device. BlueALSA creates a transport channel with MTU (Maximum Transmission Unit) settings for efficient data transfer.
# Audio encoding starts
bluealsad: [31361] D: ba-transport-pcm.c:473: PCM resume: 24
EXPLANATION: BlueALSA starts the audio encoding process. It creates a dedicated thread for AAC encoding, with 1024-sample frames, 2-channel stereo input, and the afterburner enhancement enabled. The encoder is now ready to convert your audio into AAC format for Bluetooth transmission.
The AAC frame monitoring shows the real-time encoding efficiency of the  Fraunhofer AAC encoder as it processes audio for Bluetooth transmission.
Each line represents one AAC audio frame that has been encoded from PCM audio data. The varying output bytes (469-600) demonstrate the Variable Bit Rate (VBR) encoding at work:
  • Target bitrate=320000: The configured maximum bitrate of 320 kbps for high-quality audio.
  • Output bytes variation: Shows VBR efficiency - simpler audio passages use fewer bytes (469), complex passages use more (600)
  • Real-time monitoring: Each frame is logged as it's encoded in the a2dp_aac_enc_thread (a2dp-aac.c)
The real-time monitoring reveals how AAC intelligently allocates bandwidth based on audio complexity, unlike fixed-bitrate codecs that waste data on simple passages. The afterburner enhancement you enabled further optimizes this process for better audio quality. The frame-by-frame variation is quite normal and indicates the encoder is working rather efficiently, adapting to the musical content as it processes each segment of audio.
  • The real-time monitoring appears only when --loglevel=debug is enabled
  • The byte variations are typical for VBR encoding with afterburner enabled
  • Each frame represents approximately 1024 samples of audio data
  • The actual transmission rate averages around the target 320 kbps over time
Notes
This simplified log illustrates the full Bluetooth audio pipeline — from daemon startup to active streaming — with a focus on AAC codec negotiation and configuration. It demonstrates how BlueALSA serves as a bridge between Linux applications and Bluetooth audio devices, handling codec discovery, negotiation, and real-time encoding with quiet efficiency.
ALSA configuration for BlueALSA virtual PCM with AAC codec
$ cat ~/.asoundrc
defaults.pcm.rate_converter "fftrate"
defaults.bluealsa.codec "aac"
pcm.!default "bluealsa"
BlueALSA Commands
bluealsactl codec $(bluealsactl list-pcms | grep a2dpsrc | head -1) aac
$ bluealsactl codec $(bluealsactl list-pcms | grep a2dpsrc | head -1)
Available codecs: SBC AAC
Selected codec: AAC
BlueALSA preserves the original sample rate when:
  • The source audio is 44.1kHz or 48kHz (the A2DP mandatory rates)
  • The Bluetooth receiver supports the same rate
When resampling is needed (e.g., DXD to 48kHz), it is performed by the default ALSA resampler (now fftrate)
Command for Real-Time Sample Rate Monitoring
$ bluecodec
Selected: AAC:40008484e200
MPEG-2,4 AAC <hex:40008484e200> {
  Object Type ( MPEG4-LC )
  Dynamic Range Control ( false )
  Sample Rate ( 48000 Hz )
  Channel Mode ( Stereo )
  VBR ( true )
  Bitrate ( 320000 )
$ bluecodec
Selected: AAC:40010484e200
MPEG-2,4 AAC <hex:40010484e200> {
  Sample Rate ( 44100 Hz )
  VBR ( true )
  Bitrate ( 320000 )
bluecodec() {
    local pcm=$(bluealsactl list-pcms | grep a2dpsrc | head -1)
    local codec=$(bluealsactl --verbose codec "$pcm" | grep "Selected codec" | awk '{print $3}')
    echo "Selected: $codec"
    a2dpconf "$codec"
Technical Details
BlueALSA preserves native sample rates because the D-Bus API exposes the actual PCM rate property, and the A2DP specification mandates support for 44.1kHz and 48kHz rates . When source and sink support the same rate, no resampling occurs, maintaining optimal audio quality.
The bluecodec function provides real-time visibility into the actual negotiated configuration, showing whether BlueALSA is transmitting at 44.1kHz, 48kHz, or other supported rates based on the codec capabilities and device compatibility.
On Afterburner and CPU Usage
$ man bluealsad | grep afterburner -A2
       --aac-afterburner
              Enables  Fraunhofer  AAC afterburner feature, which is a type of analysis by synthesis algorithm.  This
              feature increases the audio quality at the cost of increased processing power and overall  memory  con‐
              sumption.
$ cat bluez-alsa-4.3.1-86/src/ba-config.c | grep ENABLE_AAC -A21
#if ENABLE_AAC
    /* There are two issues with the afterburner: a) it uses a LOT of power,
     * b) it generates larger payload. These two reasons are good enough to
     * not enable afterburner by default. */
    .aac_afterburner = false,
    /* By default try not to not use the VBR mode. Please note, that for A2DP
     * sink the VBR mode might still be used if the connection is initialized
     * by a remote BT device. */
    .aac_prefer_vbr = false,
    /* Do not enable true "bit per second" bit rate by default because it
     * violates A2DP AAC specification. */
    .aac_true_bps = false,
    /* For CBR mode the 220 kbps bitrate should result in an A2DP frame equal
     * to 651 bytes. Such frame size should fit within writing MTU of most BT
     * headsets, so it will prevent RTP fragmentation which seems not to be
     * supported by every BT headset out there. */
    .aac_bitrate = 220000,
    /* Use newer LATM syntax by default. Please note, that some older BT
     * devices might not understand this syntax, so for them it might be
     * required to use LATM version 0 (ISO-IEC 14496-3 (2001)). */
    .aac_latm_version = 1,
#endif
The BlueALSA documentation suggests the afterburner “uses a LOT of power.” In practice, testing on an Intel Core i3-3220 (2012) shows average CPU usage of 3.47%, peaking at 6% during playback. One might conclude that the concern is, at best, a trifle overblown.
Tested with:
ASUS USB-BT540 Bluetooth 5.4 Dongle Adapter Compatible with Linux
Sennheiser HD 450BT Bluetooth Wireless Headphones
Bowers & Wilkins Px7 S2e Bluetooth Wireless Headphones
Sound Quality
AAC over Bluetooth isn’t Hi-Res by any stretch, but with afterburner and VBR at 320 kbps, it delivers transparent, near-CD quality for most listeners. The afterburner enhances perceptual quality through analysis-by-synthesis — it does work rather well. It won’t satisfy a true audiophile, but for the average person, it’s perfectly acceptable.
With AAC, BlueALSA delivers proper AAC sound quality. If you’re unsure what that means, try it yourself using Firefox and YouTube.
Step 1: Disable WebM support in Firefox (media.mediasource.webm.enabled = false).
Step 2: Play a high-quality AAC audio source, such as:
Robert de Visée – Prélude et Allemande (Jonas Nordberg, theorbo) on YouTube: _https://youtu.be/qeUcGD4rRRc
Reference media files:
Robert de Visée Prélude et Allemande, Jonas Nordberg, theorbo
$ youtube-dl -F "https://youtu.be/qeUcGD4rRRc" | grep "audio only"
249          webm       audio only audio_quality_low   52k , webm_dash container, opus  (48000Hz), 1.81MiB
250          webm       audio only audio_quality_low   70k , webm_dash container, opus  (48000Hz), 2.43MiB
140          m4a        audio only audio_quality_medium  129k , m4a_dash container, mp4a.40.2 (44100Hz), 4.47MiB
251          webm       audio only audio_quality_medium  137k , webm_dash container, opus  (48000Hz), 4.75MiB
$ firefox 2>&1 https://youtu.be/qeUcGD4rRRc
Input:  44100 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 1764
Output: 48000 Hz, 2 ch, 's16_le' (0x2): dummy = 0, period = 1920
Rates:  44100 --> 48000 (J: 0.00%, T: FFT, W: Vorbis)
Ok.
Naseer Shamma with Master Musicians in Berlin (2023)
_https://youtu.be/GfSeEevp9xo
Naseer Shamma - Oud & Composition
Thanasis Polikadriotis - Bouzouki
Hussein Zahawy - Daf (Bandir)
Ashraf Sharif Khan - Sitar
Jorge Bezzera - Various Percussions
Alex Simu - Clarinet
Emel Bostanci - Kemenche
Firefox settings for better sound quality:
  • Open about:config
  • Set media.mediasource.webm.enabled to false to force AAC (m4a) playback on YouTube
  • Set media.cubeb.backend to alsa for direct audio output on Linux
  • Disable resampling: set media.resampling.enabled to false
  • Adjust latency: set media.cubeb_latency_playback_ms to 160 for balanced performance
These settings help Firefox deliver cleaner, more consistent audio, especially when streaming AAC content.
about:config
media.mediasource.webm.enabled		false
media.cubeb.backend                    		alsa
media.resampling.enabled            		false
media.cubeb_latency_playback_ms        		160
Configuration Editor for Firefox
_https://support.mozilla.org/en-US/kb/about-config-editor-firefox
Advanced Audio Coding
_https://en.wikipedia.org/wiki/Advanced_Audio_Coding
The FDK-AAC licence
The FDK-AAC codec is open source under a permissive copyright licence that grants broad rights—allowing free redistribution, requiring source availability for binaries, permitting modifications with attribution, and imposing no royalty fees. However, it does not convey patent rights; separate licences are necessary for commercial use.
$ cat fdk-aac/NOTICE
AAC-ELD is considered the best-performing full-bandwidth communications codec
by independent studies and is widely deployed. AAC has been standardized by ISO
and IEC as part of the MPEG specifications.
BlueALSA Logging: A Modest Affair
BlueALSA's default logging maintains a certain reserve - quite minimal by design, you see. The logging system resides in src/shared/log.c  with corresponding declarations in src/shared/log.h
The Current Situation
By default, BlueALSA rather keeps to itself with basic error and warning messages. The debug macros are quite simply disabled in release builds:
#define debug(M, ...) do {} while (0)
Rather tidy, though perhaps not terribly informative when things go awry.
Adding Comprehensive Logging
Should one wish for more verbose output, it's really not such a tremendous undertaking. The framework is already there - one merely
needs to sprinkle debug() statements about the codebase:
debug("Transport state changed: %s", state_name);
debug("Codec negotiation: %s selected", codec_name);
The debug system handles the niceties - thread safety, priority filtering, and rather useful timestamps when built with --enable-debug-time.
A Matter of Compilation
Of course, one must remember to compile with debugging support:
./configure --enable-debug
make
Quite straightforward, really. The system then provides rather detailed output including file locations, thread IDs, and relative timing .
Notes
The understated approach to default logging keeps BlueALSA rather quiet in normal operation, though the comprehensive debug framework means adding detailed logging is merely a matter of adding a few well-placed statements here and there. Not terribly difficult, as these things go.
#2 2026-01-10 17:33:51
igorzwx
Re: Bluetooth Audio: How It Works
BlueALSA Configuration
BlueALSA is already configured and ready to use. The ALSA configuration file for BlueALSA is located at:
/usr/share/alsa/alsa.conf.d/20-bluealsa.conf
$ dpkg -S /usr/share/alsa/alsa.conf.d/20-bluealsa.conf
bluez-alsa:amd64: /usr/share/alsa/alsa.conf.d/20-bluealsa.conf
This file contains optimal default settings that work for most users. These have been carefully selected to deliver the best performance. As audio quality is not a primary concern for Linux developers, you may wish to adjust some of the default settings.
What's Already Configured
The system already defines:
  • pcm.bluealsa - The main Bluetooth audio device.
  • ctl.bluealsa - Mixer controls for Bluetooth devices.
Note that pcm.bluealsa is a virtual PCM device, not a full virtual sound card. As such, it does not support direct use of ALSA plugins like dmixdsnoop, or asym to enable software mixing or concurrent access. BlueALSA PCM devices are designed for direct Bluetooth audio streaming and lack built-in multi-client capabilities — only one application can use the PCM at a time.
Optimal Configuration for AAC codec
Here is the complete optimal configuration for AAC codec. Put this in ~/.asoundrc:
# File: ~/.asoundrc
defaults.bluealsa.ctl.extended "yes"
defaults.bluealsa.softvol "off"
What These Settings Do
  • defaults.pcm.rate_converter "fftrate" - Uses high-quality sample rate conversion
  • defaults.bluealsa.ctl.extended "yes" - Shows which codec is actually being used
  • defaults.bluealsa.codec "aac" - Forces AAC codec for best quality
  • pcm.!default "bluealsa" - Makes Bluetooth audio the system default
If you open alsamixer for the BlueALSA virtual PCM device:
alsamixer -D bluealsa
you will see codec controls like:
  • AAC Codec Enum - Shows the currently selected AAC codec
  • Volume Mode - Switch between "pass-through" and "software"
  • Sync - Client delay adjustment
  • Battery - Device battery level (if supported)
The codec control lets you verify your defaults.bluealsa.codec "aac" setting is working
The following default settings work well and don't need to be changed:
  • Volume mode: 'pass-through' (uses device's native volume control)
  • Delay: +0 ms (no extra delay added)
These settings are already optimal for most users.
Important: Do not load aptX or aptX-HD codecs in bluealsad, if you intend to use the AAC codec exclusively.
This ensures only AAC (and mandatory SBC) codecs are available for a2dp playback, as SBC codec cannot be disabled — it is required by the A2DP specification and is always enabled by default in BlueALSA.
To run bluealsad from the terminal, use:
In the init script /etc/init.d/bluealsad, configure the options accordingly:
BA_OPTS="-S -p a2dp-source -p a2dp-sink -p hfp-ag -p hfp-hf -c -sbc -c aac -c msbc --aac-afterburner --aac-bitrate=320000 --aac-vbr --aac-true-bps"
This configuration avoids codec conflicts and ensures reliable AAC usage.
How BlueALSA Handles Sample Rates (Bit Perfect)
BlueALSA does not perform resampling. When sample rate conversion is required (e.g., from DXD to 48 kHz), it is handled by ALSA using the configured resampler — such as fftrate:
$ cat ~/.asoundrc | grep rate
Since the AAC codec supports both 44.1 kHz and 48 kHz, no resampling is needed, and BlueALSA preserves the original sample rate — a concept often referred to as "bit perfect" in macOS contexts. The default BlueALSA configuration avoids unnecessary audio processing that could degrade sound quality.
When your audio player changes sample rates (e.g., from 48 kHz to 44.1 kHz), BlueALSA automatically renegotiates the connection with the Bluetooth device to match the new rate.
How to configure media applications
Note that it is generally not possible to disable resampling in Chromium-based browsers.
MPV Player
$ cat ~/.config/mpv/mpv.conf
ao=alsa
alsa-resample=yes
alsa-buffer-time=160000
alsa-periods=4
Celluloid:
  • Open the Preferences menu.
  • Go to the Miscellaneous tab.
  • Enter mpv command-line options into the "Extra MPV Options" text box:
ao=alsa alsa-resample=yes alsa-buffer-time=160000 alsa-periods=4
Audacious:
  • go to Preferences → Audio → Buffer size
  • set 2000 ms
aplay and arecord
aplay -F 40000 -B 160000 input.wav
arecord -F 40000 -B 160000  -V mono -f CD output.wav
Firefox
about:config
#3 2026-01-12 02:46:07
igorzwx
To use Bluetooth audio effectively on Linux, you must understand how it works. This is not optional. Technical knowledge and genuine comprehension are prerequisites.
The detailed logging system of macOS provides a valuable insight into Bluetooth audio design.
macOS Bluetooth Audio: Complete Annotated Console Log Guide
A Step-by-Step Manual for Understanding How Bluetooth Audio Works on macOS
Test Equipment
  • Computer: MacBook Air (13-inch, 2018), Bluetooth 4.2
  • Headphones: Bowers & Wilkins Px7 S2e Bluetooth Wireless Headphones
  • Operating System: macOS
How to Capture Bluetooth Audio Logs
Step 1: Disconnect Your Bluetooth Headphones
Before you begin, make sure your Bluetooth headphones are disconnected from your Mac. You can do this by:
  • Clicking the Bluetooth icon in the menu bar (top right corner of your screen)
  • Finding your headphones in the list
  • Clicking "Disconnect"
Alternatively, turn off your headphones completely.
Step 2: Open the Console Application
The Console app is macOS's built-in log viewer. It shows you what's happening inside your system in real-time.
Method 1 - Using Terminal:
  1. Open Terminal (Applications → Utilities → Terminal)
  2. Type the following command and press ENTER:
   open -a Console.app
Method 2 - Using Finder:
  1. Open Finder
  2. Go to Applications → Utilities
  3. Double-click "Console"
Method 3 - Using Spotlight:
  1. Press Command (⌘) + Space
  2. Type "Console"
  3. Press ENTER
Step 3: Configure the Search Filter
When Console opens, the window will be empty (streaming has not started yet).
  1. Locate the search bar: Look at the top-right corner of the Console window. You'll see a search field.
  2. Type "codec" into the search bar and press ENTER.
  3. Change the filter type: To the left of the word "codec" in the search bar, a dropdown menu will appear. Click it and select "Message" from the list. This tells Console to search only in the message content, not in the entire log entry.
Step 4: Start Streaming Logs
In the center of the Console window toolbar, you'll see a button that says "Start streaming" (or it might show a play icon ▶). Click this button to begin capturing logs in real-time.
The Console is now watching for any system messages that contain the word "codec".
Step 5: Connect Your Bluetooth Headphones
Now, while Console is streaming logs:
  1. Turn on your Bluetooth headphones (or click the Bluetooth menu bar icon and select your headphones to connect)
  2. Wait a few seconds for the connection to complete
You should see log messages appearing in the Console window immediately. These messages show the entire Bluetooth audio negotiation process happening in real-time.
Step 6: Review the Captured Logs
The Console will display several log entries showing how macOS and your headphones negotiate the Bluetooth audio connection. Below is an example log with detailed explanations.
The Log: Line-by-Line Explanation
1. Device Capability Check (48 kHz Support)
default    21:33:05.750639+0100    bluetoothd    Bad48KHzCodecs: Disabling 48 KHz - Device is NOT in 48 KHz AAC allowlist
What's happening: macOS maintains an internal list of Bluetooth devices that have been tested and verified to work properly with 48 kHz audio. The Bowers & Wilkins Px7 S2e is not on this allowlist. Even if the headphones claim they support 48 kHz, macOS won't use it. This is a protective measure against devices with buggy 48 kHz implementations that could cause audio problems.
Result: Audio will be limited to 44.1 kHz (CD quality) instead of 48 kHz.
2. HFP (Hands-Free Profile) Setup - Voice Calls
default    21:33:06.121260+0100    bluetoothd    Creating HFPAudioDevice for device EC:66:D1:BF:02:05 with codec: mSBC
What's happening: While setting up music playback (A2DP profile), macOS simultaneously configures the Hands-Free Profile (HFP) for phone calls, Siri, and voice communication.
Technical details:
  • Device MAC address: [font=Courier New]EC:66:D1:BF:02:05[/font] (unique identifier for these headphones)
  • Voice codec: mSBC (modified Sub-Band Codec) - provides wideband speech at 16 kHz for better call quality than older 8 kHz narrowband codecs
Note: This is separate from music quality. Voice calls and music use different Bluetooth profiles and codecs.
3. Voice Codec Parsing (HFP Capabilities)
default    21:33:06.143723+0100    coreaudiod    ParseSWCodecs uwbsMono 0, uwbsStereo 0, swbMono 0, swbStereo 0, swbStereoFake 0, mStereoSupported 0
What's happening: Core Audio (macOS's audio system) is checking which advanced voice codecs the headphones support. Each "0" means "not supported", "1" would mean "supported".
Codec breakdown:
  • uwbsMono/uwbsStereo = Ultra-wideband speech (mono/stereo): Not supported (0)
  • swbMono/swbStereo = Super-wideband speech: Not supported (0)
  • swbStereoFake = Fake stereo super-wideband: Not supported (0)
  • mStereoSupported = Stereo voice calls: Not supported (0)
Translation: These headphones only support basic mono voice codecs, not the advanced high-quality or stereo voice features.
4. Available Voice Codecs Summary
default    21:33:06.145067+0100    coreaudiod    Codecs available. NBS (CVSD): 1, WBS (mSBC): 1, UWBS (AAC-ELD): 0, mSWB:0, Stereo: 0
What's happening: macOS summarizes which voice call codecs are available:
  • NBS (CVSD) = Narrowband Speech: Supported (1) - Basic 8 kHz voice quality (sounds like an old phone)
  • WBS (mSBC) = Wideband Speech: Supported (1) - Better 16 kHz voice quality (sounds clearer, like modern mobile phones)
  • UWBS (AAC-ELD) = Ultra-wideband Speech: Not supported (0) - Premium AAC-based voice codec
  • mSWB = Modified super-wideband: Not supported (0)
  • Stereo voice: Not supported (0)
For calls: macOS will use mSBC (wideband) for decent call quality.
5-8. Codec Discovery (A2DP Music Profile)
default    21:33:10.270226+0100    bluetoothd    Audio Codec ID VENDOR-SPECIFIC for remote SEID 9
error    21:33:10.471543+0100    bluetoothd    Length of AVDTP Codec Info is too short for Apple Vendor-Specific Codec
default    21:33:10.471637+0100    bluetoothd    Audio Codec ID VENDOR-SPECIFIC for remote SEID 7
error    21:33:10.607426+0100    bluetoothd    Length of AVDTP Codec Info is too short for Apple Vendor-Specific Codec
default    21:33:10.607626+0100    bluetoothd    Audio Codec ID VENDOR-SPECIFIC for remote SEID 5
default    21:33:10.743925+0100    bluetoothd    Audio Codec ID MPEG-2,4 AAC for remote SEID 3
default    21:33:10.880295+0100    bluetoothd    Audio Codec ID SBC for remote SEID 1
What's happening: macOS is asking the headphones: "What music codecs do you support?" The headphones respond with a list of available codecs. Each codec has a SEID (Stream Endpoint ID) - think of it as a numbered slot.
The headphones advertise 5 codec endpoints:
  • SEID 9, 7, 5: Vendor-specific codecs (likely proprietary Bowers & Wilkins audio processing features)
    • Error messages: These vendor codecs don't follow Apple's expected format correctly, so macOS rejects them as incompatible
  • SEID 3: AAC (MPEG-2,4 AAC) - Apple's preferred high-quality music codec ✓
  • SEID 1: SBC (Sub-Band Codec) - The mandatory baseline codec that all Bluetooth audio devices must support ✓
Result: Two usable music codecs: AAC and SBC. macOS will prefer AAC.
9-10. Codec Selection
default    21:33:10.880630+0100    bluetoothd    Selected preferred codec AVDTP_CODEC_MPEG_AAC (0x2) out of 5 available endpoints
default    21:33:10.880740+0100    bluetoothd    Selected preferred codec AVDTP_CODEC_MPEG_AAC (0x2) out of 5 available endpoints
What's happening: macOS chooses AAC (codec ID 0x2) as the preferred codec from the 5 available endpoints.
Why twice? This message appears twice, likely confirming the selection for both audio channels or for redundancy.
Why AAC? On macOS, AAC is always preferred over SBC when available because it provides significantly better sound quality at the same bitrate.
11-12. Vendor Codec Rejection (Confirmation)
error    21:33:10.880817+0100    bluetoothd    Length of AVDTP Codec Info is too short for Apple Vendor-Specific Codec
error    21:33:10.880892+0100    bluetoothd    Length of AVDTP Codec Info is too short for Apple Vendor-Specific Codec
What's happening: macOS confirms it's rejecting the malformed vendor-specific codecs from the headphones. These errors are harmless - they just mean the proprietary Bowers & Wilkins features aren't compatible with macOS's expectations.
13. A2DP Stream Configuration (The Main Event!)
default    21:33:11.467514+0100    bluetoothd    A2DP configured at 44.1 KHz. Codec: AAC-LC, VBR max: 244 kbps. 1 frames * (12+709) bytes = 721 per RTP (max=879) every 23.22 ms
What's happening: This is the most important line - it shows the final negotiated Bluetooth music stream configuration.
Breaking it down:
  • A2DP configured at 44.1 KHz: Sample rate is 44.1 kHz (CD quality)
    • Remember: 48 kHz was disabled earlier because this device isn't on the allowlist
  • Codec: AAC-LC: Using AAC Low Complexity profile (the standard AAC variant)
  • VBR max: 244 kbps: Variable Bit Rate with a maximum of 244 kilobits per second
    • Note: Later logs reveal the actual encoding uses 192 kbps CBR (Constant Bit Rate), so this is just the negotiated maximum ceiling
  • Frame structure:
    • 1 frame per RTP packet (RTP = Real-time Transport Protocol, the Bluetooth streaming format)
    • 12 bytes = RTP header overhead
    • 709 bytes = AAC-encoded audio data
    • 721 total bytes per packet (12 + 709)
    • Maximum packet size: 879 bytes (extra headroom for variable bitrate bursts)
  • Timing: every 23.22 ms
    • Each packet contains 1024 audio samples
    • Calculation: 1024 samples ÷ 44,100 samples/second = 0.02322 seconds = 23.22 milliseconds
Translation for non-technical users: Every 23.22 milliseconds (roughly 43 times per second), your Mac sends a small packet of compressed AAC audio data (721 bytes) over Bluetooth to your headphones.
14-18. AAC Encoder Negotiation (Finding the Perfect Settings)
default    21:33:11.486010+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 1, bitrate = 128000, quality (complexity) = 64, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 0 (bits), packetBitSizeMin = 0 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
What's happening: Core Audio doesn't just blindly use any AAC settings. It intelligently tests multiple encoder configurations to find the optimal balance between quality, latency, and Bluetooth packet size. Think of this as macOS trying on different "outfits" to see which fits best.
Test 1 - High Quality CBR:
  • srIn/srOut = 44100: Input and output sample rate both 44.1 kHz (no resampling needed - bit-perfect!)
  • chans = 2: Stereo (2 channels)
  • bitRateFormat = 1: CBR (Constant Bit Rate)
  • bitrate = 128000: 128 kbps (kilobits per second)
  • quality (complexity) = 64: High CPU complexity for better encoding quality (0-127 scale)
  • VBRQ = -1: VBR Quality setting not used (because this is CBR mode)
  • speechOptimization = 0: Disabled (music-optimized encoding, not voice-optimized)
  • packetSizeLimit = 0: No packet size limit in this test
  • packetBitSizeMin = 0: No minimum packet size
  • mMaxPacketSize = 1536 bytes: Maximum 1536 bytes per packet
  • mCodecDelay = 2112: Encoder latency is 2112 samples
    • Calculation: 2112 ÷ 44,100 = 47.89 milliseconds of encoding delay
  • drcConfiguration = 0: Dynamic Range Compression disabled
default    21:33:11.490819+0100    coreaudiod      ... bitRateFormat = 1, bitrate = 128000, quality (complexity) = 32 ...
Test 2 - Medium Quality CBR:
  • Same as Test 1, but complexity reduced to 32 (medium)
  • Lower complexity = faster encoding, uses less CPU, slightly lower quality
default    21:33:11.492162+0100    coreaudiod      ... bitRateFormat = 3, bitrate = 128000, quality (complexity) = 32 ...
Test 3 - VBR Mode:
  • bitRateFormat = 3: VBR (Variable Bit Rate) - bitrate can fluctuate for better efficiency
  • 128 kbps average
  • Complexity 32 (medium)
default    21:33:11.493346+0100    coreaudiod      ... bitRateFormat = 3, bitrate = 128000, quality (complexity) = 32, VBRQ = -1, ... packetBitSizeMin = 256 (bits) ...
Test 4 - VBR with Minimum Packet Constraint:
  • VBR mode with minimum packet size = 256 bits (32 bytes)
  • This ensures packets aren't too small, which could waste Bluetooth transmission efficiency
default    21:33:11.494194+0100    coreaudiod      ... bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, ... packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits) ...
Test 5 - THIS IS THE WINNER! ✓
  • bitrate = 192000: 192 kbps average (significantly higher than the 128 kbps tests)
  • quality (complexity) = 32: Balanced CPU usage
  • packetSizeLimit = 5672 bits: Maximum 709 bytes per packet (5672 ÷ 8 = 709)
    • This matches exactly the "709 bytes" we saw in the bluetoothd configuration!
  • packetBitSizeMin = 256 bits: Minimum 32 bytes per packet
Why this configuration won:
  • Higher bitrate (192 kbps) = better sound quality
  • VBR mode = efficient use of bandwidth (complex music passages get more bits, simple passages use fewer)
  • Packet size (256-5672 bits) perfectly fits the Bluetooth MTU (Maximum Transmission Unit)
  • Complexity 32 = good quality without excessive CPU usage
19-23. Encoder Reconfiguration Events
default    21:35:26.865271+0100    coreaudiod      ... (same 192 kbps VBR config)
default    21:37:35.865684+0100    coreaudiod      ... (same 192 kbps VBR config)
default    21:37:43.660216+0100    coreaudiod      ... (same 192 kbps VBR config)
default    21:38:10.692347+0100    coreaudiod      ... (same 192 kbps VBR config)
default    21:38:12.218420+0100    coreaudiod      ... (same 192 kbps VBR config)
default    21:40:55.879479+0100    coreaudiod      ... (same 192 kbps VBR config)
What's happening: These log entries show the AAC encoder being reinitialized with the same proven configuration (192 kbps VBR, complexity 32).
When does this happen?
  • You start or stop music playback
  • You switch between different audio apps (Spotify → Apple Music → YouTube)
  • System audio routing changes
  • Headphones briefly disconnect and reconnect
  • macOS adjusts audio priorities
Each time, macOS reinitializes the encoder with the same optimal settings it discovered during the initial tests.
Technical Configuration
| Parameter          | Value        | Explanation                                    |
| Sample Rate        | 44.1 kHz     | CD quality; 48 kHz disabled (not on allowlist) |
| Codec              | AAC-LC       | Advanced Audio Coding - Low Complexity         |
| Bitrate            | 192 kbps CBR | Actually constant despite VBR negotiation      |
| Encoder Complexity | 32 (medium)  | Balanced CPU vs. quality                       |
| Frame Size         | 1024 samples | 23.22 ms per frame                             |
| Packet Size        | 721 bytes    | 12-byte header + 709-byte AAC data             |
| Codec Delay        | 2112 samples | ~48 ms encoder latency                         |
The Process macOS Follows
  1. Check device allowlist → Disable 48 kHz (device not approved)
  2. Set up voice profile (HFP) → Use mSBC for calls
  3. Discover available codecs → Find AAC and SBC
  4. Select preferred codec → Choose AAC over SBC
  5. Negotiate stream parameters → 44.1 kHz, VBR max 244 kbps
  6. Test encoder configurations → Try 5 different settings
  7. Select optimal configuration → 192 kbps VBR, complexity 32
  8. Stream audio → Send 721-byte packets every 23.22 ms
A Note on Sound Quality
It may be worth noting that, when using the same Bluetooth headphones, the sound quality on macOS is rather better than on Linux. Not enormously so, you understand, but one might say the difference is... perceptible to the discerning ear.
Both systems use AAC encoding over Bluetooth, both operate at 44.1 kHz, and both follow broadly similar technical processes. Yet the macOS implementation does seem to possess a certain refinement in its execution - perhaps in the encoder's architectural elegance, or in the rather more sophisticated manner in which Core Audio handles the signal path.
It's rather like comparing motorcars, really. A Toyota and a Rolls-Royce both have four wheels, an engine, and a steering wheel. Both will convey you from point A to point B. The fundamental principles are identical. Yet one wouldn't claim the experience is quite the same, would one?
The quality, as they say, is in the details of the realisation.
On Linux with BlueALSA:
  • You cannot force 320 kbps VBR or CBR - the bitrate is negotiated between the system and the headphones
  • Getting detailed logs like these requires modifying the BlueALSA source code with debug statements and recompiling the daemon
  • Both 44.1 kHz and 48 kHz are typically available (no allowlist restrictions)
  • You can request the AAC "afterburner" mode for maximum encoder quality using the [font=Courier New]--aac-afterburner[/font] flag
On macOS:
  • Logging is built-in via Console.app - no compilation required
  • The system automatically tests and selects optimal encoder settings
  • Device allowlists protect against buggy hardware implementations
  • The Core Audio architecture provides a cleaner signal path
This guide was created by capturing real Bluetooth connection logs and analyzing the internal behavior of macOS's Bluetooth audio stack.
default    21:33:11.490819+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 1, bitrate = 128000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 0 (bits), packetBitSizeMin = 0 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:33:11.492162+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 128000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 0 (bits), packetBitSizeMin = 0 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:33:11.493346+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 128000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 0 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:33:11.494194+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:35:26.865271+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:37:35.865684+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:37:43.660216+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:38:10.692347+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:38:12.218420+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
default    21:40:55.879479+0100    coreaudiod      ACMP4AACBaseEncoder.cpp:692   (0x7fb47f97dc40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5672 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
An amusing discovery emerged during this research: both the Bowers & Wilkins Px7 S2e and Sennheiser HD 450BT work perfectly well on macOS—they connect, they play audio, users remain blissfully unaware of any limitation. Yet according to macOS's own logs, these devices are not supported. They are excluded from the 48 kHz AAC allowlist, relegated to 44.1 kHz like common peasants.
Which headphones, then, enjoy this privilege? The answer is as predictable as it is illuminating: Beats.
Apple acquired Beats Electronics for $3 billion in 2014. Since then, Beats headphones have shipped with Apple's proprietary wireless chips—the W1, H1, and now H2. These chips are not merely Bluetooth transceivers; they are trusted devices in the macOS ecosystem.
Headphones with H1/W1/H2 chips receive preferential treatment from bluetoothd:
  • 48 kHz AAC support (others are capped at 44.1 kHz)
  • Likely higher bitrates than standard AAC-LC
  • Optimized audio pipeline routing
  • Possibly lower latency
The chips almost certainly maintain persistent encrypted connections, use custom pairing protocols beyond standard Bluetooth, and report extended capabilities that trigger allowlist matching against hardcoded device IDs.
Apple's Rationale
  1. Quality Control – They know their chips handle 48 kHz reliably
  2. Battery & Stability – Guaranteed experience without edge-case failures
  3. Product Differentiation – A tangible reason to buy within the ecosystem
  4. Ecosystem Lock-in – Yet another thread in the web
The goal is transparent: the best Bluetooth audio quality on macOS shall be delivered by Beats headphones and AirPods. The Apple audio engineers are perfectly capable of implementing this. They have simply chosen to do so exclusively for their own products.
The so-called "Bluetooth audiophiles" often insist that Beats are inferior to Sennheiser, Bowers & Wilkins, and their ilk. One might safely disregard such opinions with the same confidence one dismisses the pronouncements of fast food connoisseurs on any cuisine.
Summary
On macOS, you are graciously invited to remain within the Apple ecosystem—that is, to consume Apple products exclusively for optimal functionality.
On Linux, you are similarly encouraged to remain within the Linux ecosystem—that is, to use systemd, PulseAudio, PipeWire, ALSA, and whichever resampler happens to be fashionable this quarter, whether you like them or not.
The difference, modest though it may be, is this: on Linux, it remains possible to remove systemd, PulseAudio, and PipeWire, and enjoy the true freedom—the freedom to trust your senses and your ability to think, to understand and to solve problems.
#4 2026-01-15 13:19:53
User479
Wow.  Thanks for documenting all this.
#5 2026-08-04 23:34:26
igorzwx
Monitoring Actual Bluetooth AAC Bit Rate: CBR vs VBR
Configure AAC codec for CBR
$ grep "^BA_OPTS" /etc/init.d/bluealsad
BA_OPTS="-S -p a2dp-source -p hfp-ag -p hfp-hf -c -sbc -c aac -c msbc --aac-afterburner --aac-bitrate=320000"
Play video in YouTube
firefox-dev https://youtu.be/wINCpPCDLyo
Monitor actual AAC bit rate
$ hcitop -d 1
HCI    BUS ADDR              FLAGS           RX       TX     RX/s     TX/s
hci0   USB A0:AD:9F:6F:51:58 U RPI        23 KB     1 MB    630 B  41771 B
hcitop's TX/s column is in bytes/sec. So 40000 B/s × 8 = 320,000 b/s — exactly matching AAC encoder's configured bit rate: 320000 b/s. Option: --aac-bitrate=320000
$ ./hcistat
hci0: 333392 b/s
hci0: 333400 b/s
hci0: 333392 b/s
hci0: 333392 b/s
hci0: 333400 b/s
hci0: 341144 b/s
hci0: 333392 b/s
hci0: 333392 b/s
The extra ~4–9% is just "packaging overhead" (headers/wrappers Bluetooth adds around audio data).
The AAC payload itself is set to 320,000 b/s via AACENC_BITRATE, but before it leaves the adapter, that payload gets wrapped in an RTP header and written out over the Bluetooth socket. hcitop and hcistat measure raw bytes at the HCI adapter level via hci_devinfo(), which counts those RTP/L2CAP/AVDTP headers too — hence the ~4–9% gap above the pure 320 kb/s AAC bitrate.
If Bluetooth audio quality is still worse than on macOS, consider fixing bugs in the ALSA backend you are using.
You can also add logging to bluez-alsa/src/a2dp-aac.c, for example:
CBR (320 kb/s)
$ sudo -u bluealsad bluealsad -p a2dp-source -p hfp-ag -p hfp-hf -c -sbc -c aac -c msbc --aac-afterburner --aac-bitrate=320000
bluealsad: I: AAC: Negotiated A2DP configuration: sample rate: 44100 Hz, channels: 2, VBR: no, bit rate: 320000 b/s
bluealsad: I: AAC: Applied encoder configuration: object type: MPEG-2 AAC-LC, bit rate mode: CBR, bit rate: 320000 b/s, peak bit rate: 320000 b/s, bandwidth: 17000 Hz, afterburner: on, LATM: v1
$ ./hcistat
hci0: 333264 b/s
hci0: 341016 b/s
hci0: 333272 b/s
hci0: 333264 b/s
hci0: 333264 b/s
hci0: 333272 b/s
hci0: 333264 b/s
hci0: 333264 b/s
VBR
$ sudo -u bluealsad bluealsad -p a2dp-source -p hfp-ag -p hfp-hf -c -sbc -c aac -c msbc --aac-afterburner --aac-bitrate=320000 --aac-vbr
bluealsad: I: AAC: Negotiated A2DP configuration: sample rate: 44100 Hz, channels: 2, VBR: yes, bit rate: 320000 b/s
bluealsad: I: AAC: Applied encoder configuration: object type: MPEG-2 AAC-LC, bit rate mode: VBR-5, bit rate: N/A b/s, peak bit rate: 320000 b/s, bandwidth: 19293 Hz, afterburner: on, LATM: v1
$ ./hcistat
hci0: 150928 b/s
hci0: 164696 b/s
hci0: 156928 b/s
hci0: 152600 b/s
hci0: 151528 b/s
hci0: 168744 b/s
hci0: 157192 b/s
hci0: 143704 b/s
hci0: 155896 b/s
hci0: 170248 b/s
Updated build instruction for bluez-alsa
Buid-Deps: +libncurses-dev
Configure script: +--localstatedir=/var
Install Buid-Deps
sudo apt install libfdk-aac-dev libasound2-dev libbluetooth-dev libdbus-1-dev libglib2.0-dev libsbc-dev liblc3-dev libldacbt-enc-dev libldacbt-abr-dev libmp3lame-dev libmpg123-dev libspandsp-dev libopus-dev libncurses-dev libbsd-dev libreadline-dev check dbus-daemon python3-docutils pkgconf libudev-dev libell-dev
Clone the source and run autoreconf
mkdir BUILD2 && cd BUILD2
git clone https://github.com/arkq/bluez-alsa.git
cd bluez-alsa && autoreconf --install --force
Create a build directory
mkdir ../build && cd ../build
Run the configure script from within the build directory
"$(dirname "$(pwd)")"/bluez-alsa/configure --prefix=/usr --localstatedir=/var --sysconfdir=/etc --with-bluealsaduser=bluealsad --enable-ldac --with-libfreeaptx --enable-aptx  --enable-aptx-hd --enable-faststream --enable-lc3-swb --enable-mp3lame --enable-mpg123 --enable-msbc --enable-ofono --enable-midi --enable-opus --enable-upower --enable-rfcomm --enable-a2dpconf --enable-hcitop --enable-test --enable-aac --enable-manpages --disable-systemd
Compile
make
Install to debdir
make DESTDIR="$(dirname $(pwd))"/debdir install
How to make a Debian package
_https://dev1galaxy.org/viewtopic.php?id=7671
#6 2026-08-05 22:28:16
igorzwx
Architectural Monty Python
The removal of the notorious PulseAudio workaround from the Firefox/Cubeb ALSA backend unveils a new reality. The purified ALSA backend, aligned with BlueALSA, AAC CBR, and modest hardware (the USB-BT540 adapter and Sennheiser HD 450BT headphones), yields superior sound quality compared to the standard ALSA configuration.
This exemplifies a true dialectical absurdity reminiscent of Monty Python: a massive, complex system (ALSA) failing to solve a problem that a tiny, focused tool (BlueALSA) handles elegantly.
The reason is clear. Just as the architect in the Monty Python sketch designs a building that fails its primary purpose — a house that does not let you walk through it — the traditional Linux audio stack often prioritizes universal compatibility over functional simplicity.
BlueALSA possesses its own bugs and workarounds; however, its codebase remains minuscule compared to ALSA. This disparity explains the situation entirely.
BlueALSA's entire "quirks surface" is tiny compared to the vast, decades-deep hardware-quirk machinery in the Linux kernel's ALSA subsystem. Scale differences like that plausibly explain why BlueALSA's bug surface feels so much smaller and more tractable.
alsa-lib's complexity is substantial and driven largely by breadth of hardware support: the per-device quirk table alone in src/conf/cards/USB-Audio.conf lists dozens of named devices needing special-cased dmix disabling, surround-channel remapping, and IEC958 device-numbering exceptions. This is on top of the general PCM plugin architecture (format conversion, rate conversion, routing, software volume, etc.) that alsa-lib maintains to support arbitrary hardware capabilities.
A userspace Bluetooth bridge like BlueALSA, by design, only needs to target a much narrower surface: BlueZ's Bluetooth audio profiles (A2DP/HFP) on one side, and a generic ALSA PCM I/O device on the other — it doesn't need to enumerate and special-case hundreds of USB/PCI/HDA sound cards. So the size disparity is architecturally plausible: alsa-lib accumulates workarounds because it's the common layer for all Linux sound hardware, while BlueALSA's scope is deliberately narrow.
Dialectically, absurdity is the hidden truth of normality (Albert Camus). ALSA users are unlikely to notice the comical irony of the situation, yet it is absurd that a minimal userspace daemon (BlueALSA, comprising only a few thousand lines of code) outperforms the kernel-level subsystem and userspace server (ALSA, consisting of millions of lines) in both sound quality and stability for this specific use case. The "correct" enterprise-grade architecture (the full Linux audio stack) proves to be the broken building, while the "hacky" side project (BlueALSA) is the only one that lets you walk through the door.
Imagine you have two vehicles: a car and a bike, both neglected and rusty. The car is a seized limousine with thousands of grinding parts. Fixing it requires rebuilding the entire transmission. The bike is a lightweight frame with minor rust. Because it has only 50 parts, you can see the friction points instantly. You can file it down and oil the chain in minutes. Once you fix the bike, it rides faster and smoother than the car ever could.
Dialectically, absurdity is inherent to normality. Attempting to destroy absurdity inevitably destroys normality, strengthens the absurd, and unleashes chaos. Absurdity cannot be defeated.  But you may find a practical solution to it.
