#1 2025-12-21 12:41:55
Roberto
[SOLVED] Unmount CIFS shares before shutdown
I am using Devuan Excalibur and I have mounted various CIFS shares in fstab at startup.
Now I want to unmount these shares before shutdown.
I created the folders Data and Storage in my home directory as mountpoint for theses shares.
I tried this with the following simple script:
umount -l /home/user/Data
umount -l /home/user/Storage
exit
I saved this script in the folder /etc/NetworkManager/dispatcher.d/pre-down.d and then made it executable with the command
sudo chmod +x /etc/NetworkManager/dispatcher.d/pre-down.d/umount.sh
Nevertheless, it takes about 3 minutes for the system to shut down.
Thank you in advance for your help an tips.
Regards
Roberto
#2 2025-12-21 13:36:07
Re: [SOLVED] Unmount CIFS shares before shutdown
Do you really want that script to exit before the unmounting has completed?
If not, then don't use "-l" as umount option.
#3 2025-12-21 13:44:03
Dutch_Master
Rename the script cifsdown.sh, copy to /etc/init.d, give it executable rights like you already did then create a symlink in /etc/rc0.d Make sure the sym-link in /etc/rc0.d is named K01cfisdown.sh DO NOT deviate from that name, as the order of shutting down services is important.
Alternatively, execute the following line by line:
sudo su #only if you use sudo, otherwise just use su instead
mv /etc/NetworkManager/dispatcher.d/pre-down.d/umount.sh /etc/init.d/cifsdown.sh
chmod +x /etc/init.d/cifsdown.sh
ln -s /etc/init.d/cifsdown.sh /etc/rc0.d/K01cifsdown.sh
You can use cp instead of mv to keep a copy in the original location. That's the difference between cp and mv: cp leaves a copy, mv (move) doesn't. Make sure you disable the script left there before rebooting:
chmod -x /etc/NetworkManager/dispatcher.d/pre-down.d/umount.sh
HTH!
#4 2025-12-22 18:26:50
Roberto
Hi guys,
thank you for your help.
The tip from Dutch_Master has solved my problem.
Regards
Roberto
#5 2026-02-12 20:43:06
Roberto
Please excuse me for reopening this thread.
I reinstalled Devuan Exclaibur 6.1 today.
I installed openRC as the init system.
To unmount my cifs shares during shutdown, I followed the exact same advice given in this post, which worked great last time.
After logging in as root with sudo su, I ran the following:
nano /etc/init.d/cifsdown.sh
I filled this script with the following:
umount -l /home/user/NAS
exit
All mount points are available in my home directory.
Then I executed the following commands:
ln -s /etc/init.d/cifsdown.sh /etc/rc0.d/K06cifsdown.sh
Despite all this, the system still takes at least 3 minutes to shut down.
Does anyone have any idea why unmounting the CIFS shares isn't working this time?
Thanks in advance for your help.
greets
Roberto
