#1 2025-12-08 11:32:16
fsnix
MATE freezes after being started with startx
Hello everyone,
this is my first post here, I hope I'm doing it right. I've been using Debian for some years, but I recently switched to Devuan Excalibur.
However, I'm having some problems starting MATE desktop environment with startx. Here my .xinitrc and .xsessionrc (respectively):
# /etc/X11/xinit/xinitrc
# global xinitrc file, used by all X sessions started by xinit (startx)
# invoke global X session script
. /etc/X11/Xsession
exec mate-session
#!/usr/bin/bash
# kill any existing pipewire instance to restore sound
pkill -u "$USER" -fx /usr/bin/pipewire-pulse 1>/dev/null 2>&1
pkill -u "$USER" -fx /usr/bin/wireplumber 1>/dev/null 2>&1
pkill -u "$USER" -fx /usr/bin/pipewire 1>/dev/null 2>&1
exec /usr/bin/pipewire &
# wait for pipewire to start before attempting to start related daemons
while [ "$(pgrep -f /usr/bin/pipewire)" = "" ] ; do
   sleep 1
done
exec /usr/bin/wireplumber &
exec /usr/bin/pipewire-pulse &
MATE starts correctly at first, but later the problem arises. For example, if I mistype the name of a directory and then press "tab" to autocomplete it, instead of just doing nothing, the entire desktop environment freezes for 10/15 seconds.
If I use lightdm instead of startx, everything goes smoothly.
Thank you very much for your time and your help.
