#1 Today 07:26:16
fuchur
Lates Builds and Qemu
Hi
I have the last image running in qemu (rpi-5-devuan-daedalus-6.12.59-arm64-ext4-2025-11-29-0206.img).
I get this error message:
module XXXX: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time
for the following module
uio gpio_keys sha1_generic sha256_arm64 libaes
snd lz4_compress ipv6 rfkill
I then wanted to (re)install the following default packages
i  linux-headers-bcm2712-rpi - Linux kernel headers for 6.12.59 on arm64
i  linux-image-bcm2712-rpi - Linux kernel, version 6.12.59
but they cannot be found in the packet source. Do I need to add anything in the source.list?
Thank you
fuchur
