#1 2025-11-20 12:56:37
wavyzedd
Cannot login to GUI after updating
Hello everyone
After doing apt update, the system only show the CLI and startx always failed. I had to enter GRUB and choose older kernel before i can login to GUI system.My guess is something wrong with either the kernel or Nvidia driver. Here are the packages that has been updated before i cannot login to GUI. Thanks in advance
Install: linux-image-6.12.57+deb13-amd64:amd64 (6.12.57-1, automatic)
Upgrade: libmagickcore-7.q16-10:amd64 (8:7.1.1.43+dfsg1-1+deb13u2, 8:7.1.1.43+dfsg1-1+deb13u3),
qemu-system-x86:amd64 (1:10.0.3+ds-0+deb13u1, 1:10.0.6+ds-0+deb13u2),
console-setup:amd64 (1.240, 1.242~deb13u1),
libssh-4:amd64 (0.11.2-1, 0.11.2-1+deb13u1),
imagemagick-7-common:amd64 (8:7.1.1.43+dfsg1-1+deb13u2, 8:7.1.1.43+dfsg1-1+deb13u3),
libfluidsynth3:amd64 (2.4.4+dfsg-1devuan1, 2.4.4+dfsg-1+deb13u1devuan1),
cups-common:amd64 (2.4.10-3+deb13u1, 2.4.10-3+deb13u2),
libldb2:amd64 (2:2.11.0+samba4.22.4+dfsg-1~deb13u1, 2:2.11.0+samba4.22.6+dfsg-0+deb13u1),
libqt6sql6-sqlite:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libxml2-utils:amd64 (2.12.7+dfsg+really2.9.14-2.1+deb13u1, 2.12.7+dfsg+really2.9.14-2.1+deb13u2),
qemu-system-modules-opengl:amd64 (1:10.0.3+ds-0+deb13u1, 1:10.0.6+ds-0+deb13u2),
libbrlapi0.8:amd64 (6.7-3.1, 6.7-3.1+deb13u2),
libqt6network6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1), x11-common:amd64 (1:7.7+24, 1:7.7+24+deb13u1),
qt6-gtk-platformtheme:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libqt6core6t64:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
xserver-xorg-input-all:amd64 (1:7.7+24, 1:7.7+24+deb13u1),
qemu-system-modules-spice:amd64 (1:10.0.3+ds-0+deb13u1, 1:10.0.6+ds-0+deb13u2),
openssl-provider-legacy:amd64 (3.5.1-1+deb13u1, 3.5.4-1~deb13u1),
libqt6widgets6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libwbclient0:amd64 (2:4.22.4+dfsg-1~deb13u1, 2:4.22.6+dfsg-0+deb13u1),
libqt6concurrent6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
xserver-xorg:amd64 (1:7.7+24, 1:7.7+24+deb13u1),
libxml2:amd64 (2.12.7+dfsg+really2.9.14-2.1+deb13u1, 2.12.7+dfsg+really2.9.14-2.1+deb13u2),
libxml2:i386 (2.12.7+dfsg+really2.9.14-2.1+deb13u1, 2.12.7+dfsg+really2.9.14-2.1+deb13u2),
libmpv2:amd64 (0.40.0-3, 0.40.0-3+deb13u1), libqt6dbus6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libcups2t64:amd64 (2.4.10-3+deb13u1, 2.4.10-3+deb13u2),
libcups2t64:i386 (2.4.10-3+deb13u1, 2.4.10-3+deb13u2),
libmagickwand-7.q16-10:amd64 (8:7.1.1.43+dfsg1-1+deb13u2, 8:7.1.1.43+dfsg1-1+deb13u3),
console-setup-linux:amd64 (1.240, 1.242~deb13u1),
poppler-utils:amd64 (25.03.0-5, 25.03.0-5+deb13u2),
ibcurl3t64-gnutls:amd64 (8.14.1-2, 8.14.1-2+deb13u2),
libqt6printsupport6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libqt6gui6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libmagickcore-7.q16-10-extra:amd64 (8:7.1.1.43+dfsg1-1+deb13u2, 8:7.1.1.43+dfsg1-1+deb13u3),
linux-image-amd64:amd64 (6.12.48-1, 6.12.57-1),
libsmbclient0:amd64 (2:4.22.4+dfsg-1~deb13u1, 2:4.22.6+dfsg-0+deb13u1),
libqt6xml6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libpoppler147:amd64 (25.03.0-5, 25.03.0-5+deb13u2),
base-files:amd64 (13.8+deb13u1devuan1, 13.8+deb13u2devuan1),
libtdb1:amd64 (2:1.4.13+samba4.22.4+dfsg-1~deb13u1, 2:1.4.13+samba4.22.6+dfsg-0+deb13u1),
libcurl4t64:amd64 (8.14.1-2, 8.14.1-2+deb13u2), xorg:amd64 (1:7.7+24, 1:7.7+24+deb13u1),
megasync:amd64 (5.16.0-1.1, 6.0.0-2.1),
libqt6sql6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libtevent0t64:amd64 (2:0.16.2+samba4.22.4+dfsg-1~deb13u1, 2:0.16.2+samba4.22.6+dfsg-0+deb13u1),
qemu-system-common:amd64 (1:10.0.3+ds-0+deb13u1, 1:10.0.6+ds-0+deb13u2),
systemd-standalone-sysusers:amd64 (257.8-1~deb13u2, 257.9-1~deb13u1),
qemu-block-extra:amd64 (1:10.0.3+ds-0+deb13u1, 1:10.0.6+ds-0+deb13u2),
samba-libs:amd64 (2:4.22.4+dfsg-1~deb13u1, 2:4.22.6+dfsg-0+deb13u1),
keyboard-configuration:amd64 (1.240, 1.242~deb13u1),
libqt6openglwidgets6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
libssl3t64:amd64 (3.5.1-1+deb13u1, 3.5.4-1~deb13u1),
libssl3t64:i386 (3.5.1-1+deb13u1, 3.5.4-1~deb13u1),
7zip:amd64 (24.09+dfsg-8, 25.01+dfsg-1~deb13u1),
curl:amd64 (8.14.1-2, 8.14.1-2+deb13u2),
libpoppler-glib8t64:amd64 (25.03.0-5, 25.03.0-5+deb13u2),
libpoppler-qt6-3t64:amd64 (25.03.0-5, 25.03.0-5+deb13u2),
libqt6opengl6:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
qt6-qpa-plugins:amd64 (6.8.2+dfsg-9, 6.8.2+dfsg-9+deb13u1),
xserver-xorg-video-all:amd64 (1:7.7+24, 1:7.7+24+deb13u1),
qemu-system-data:amd64 (1:10.0.3+ds-0+deb13u1, 1:10.0.6+ds-0+deb13u2),
libtalloc2:amd64 (2:2.4.3+samba4.22.4+dfsg-1~deb13u1, 2:2.4.3+samba4.22.6+dfsg-0+deb13u1),
orphan-sysvinit-scripts:amd64 (0.21+deb13u1, 0.21+deb13u2),
qemu-system-gui:amd64 (1:10.0.3+ds-0+deb13u1, 1:10.0.6+ds-0+deb13u2),
dns-root-data:amd64 (2024071801, 2025080400~deb13u1),
dkms:amd64 (3.2.0-1, 3.2.2-1~deb13u1), openssl:amd64 (3.5.1-1+deb13u1, 3.5.4-1~deb13u1),
linux-libc-dev:amd64 (6.12.48-1, 6.12.57-1)
#2 2025-11-20 13:09:25
g4sra
Re: Cannot login to GUI after updating
Last time I tried NVidia dkms did not support kernel versions greater than 6.11.xxx.
Suggest you try to manually run dkms in a console to compile the nvidia drivers and check for errors
