#1 2025-11-04 15:51:35
kapqa
After installation / how select Desktop
Hello ,
have installed Devuan 6.0 on Main Computer
with 4 Desktop Choice
XFCE
MATE
Cinnamon
KDE
afterwards it asked if
SDDM
Slim
and selected SDDM.
Now however upon login, get no change to select other Desktop of choice *when press F1*
it starts automatically into Cinnamon.
What is correct procedure to change this?
Thanks
#2 2025-11-04 16:25:52
Re: After installation / how select Desktop
I am not familiar with sddm, I only use lightdm. You got a very complex installation.
When you are on the sddm login screen, there should be some sort of button behind that you should be able to choose.
#3 2025-11-04 16:45:20
kapqa
thanks rolfie,
found the solution here
vim /etc/X11/default-display-manager
(change to slim)
reboot
(have crossed cinnamon already out; too much like gnome; havenÄ't noticed earlier)
