#1 2025-11-04 10:51:30
kapqa
[SOLVED] (Devuan 6) USB local printer no longer function
Hello ,
found that the printing did no longer function over USB cable after updating to Devuan 6.0 Excalibur.
If someone incurs the same problem, the package missing it
"libcupsimage2-dev"
after installing , the Ecotank Printer would again print over USB locally.
Maybe it got uninstalled in the Upgrade process or at some other point;
Thanks.
#2 2025-11-04 12:03:17
kapqa
Re: [SOLVED] (Devuan 6) USB local printer no longer function
#3 2025-11-04 14:53:40
kapqa
thank you,
on fresh installation of devuan 6.0 the problem is solved.
*maye be above package still needed for correct printing.
