#1 2025-11-01 20:16:11
Gnostic
Using Windows URL files on Linux machines?
Folks on my local network like to bookmark websites by dragging & dropping from the browser address bar into their file manager.
On Windows machines that creates an Internet Shortcut URL file.
For example, for Pi-Hole it will contain this:
[InternetShortcut]
URL=https://pi-hole.net/
How to make that useful on a Linux machine?
I've written a tiny bit of Python that seems to work.
# UseDesktopLink.py
import sys
import webbrowser
script, filename = sys.argv
file_object = open(filename,'r')
for line in file_object:
    #print(line)
    if line[0:4]=="URL=":
        url=line[4:]
        #print("url=",url)
        # just in case the line has msdos cr-lf, remove that
        url=url.replace('\x0d\x0a', '')
        # or just Linux LF
        url=url.replace('\x0a', '')
        webbrowser.open_new(url)
file_object.close()
I intended it to work with a right-click on the URL file and "Open with ..", "Set default application" then a custom command.
python UseDesktopLink.py %f
But it's not working.
What might I have forgotten to do?
#2 2025-11-01 20:48:30
JWM-Kit
Re: Using Windows URL files on Linux machines?
wouldn't something like this be much simpler
xdg-open $(grep -oP http.+ "${1}")
#3 2025-11-04 00:10:35
Gnostic
@jwm-kit
Thanks, and please excuse my ignorance, how can I use that with "Open with" ?
Would it be "Open with other application" or "Set default application" ?
Or something else?
#4 2025-11-04 05:56:23
man xdg-open
#5 2025-11-05 14:15:51
JWM-Kit
@Gnostic
The set default application is probably what you want. How you configure it in file manager will vary depending on the file manager.
With Thunar (XFCE)
  • Give the script exec permission.
  • Right click on a file that is of the type you want to make the default, and choose Open With > Set Default Application
  • Enter the path to the script in the custom command entry   ( or use the browse button to find the script)
  • Ensure the "Use as default for this kind of file" is checked and then click open.
  • NOTE :   adding the %f after the path is not needed.
