#1 2025-10-21 08:54:27
mclien
[SOLVED] libreoffice won't start (apparmor complain mode)
I just installed a new machine, copied my home dir.
When I start libreoffice, it won't stating something of being "still in complain" mode.
As the message is partly garbled in the splash screen, I can't make out what to do with the text snippet:
"--create profile?"
EDIT: Or is there a apparmor config in /etc, which I should sync to the new machine, too?
#2 2025-10-21 18:36:17
mclien
Re: [SOLVED] libreoffice won't start (apparmor complain mode)
deleting this file helped
~/.config/libreoffice/[1-9]/.lock
