#1 2025-08-02 05:49:29
Strapicarus
[SOLVED] System level DNS how to?
i use netxdns setinng resolv.conf, but to my surprise i can not modify /etc/resolv.conf (i can but...), because the net stop working, no (dns) connection. after restar the wifi i notice that reslv.conf has change to the previous configuration, it is set/generated by networkManager each time the wifi connects, so how to set the prefered dns at system level?
have a nice day.
#2 2025-08-02 06:57:13
Re: [SOLVED] System level DNS how to?
a: Stop using NetworkMangler and set up your nameservers manually.
b: Disable DNS management in NetworkMangler (add dns=none and rc-manager=unmanaged to the [main] section in the config file) and set up your nameservers manually.
c: Install something that allows multiple sources (i.e. NetworkMangler + You) to mess with nameserver records, such as openresolv, then set up NetworkMangler to use it.
Debian apparently has it's own implementation of (c), but I have no idea how (or if, absent systemd) it works.
I also have no idea what this "nextdns" privacy-koolaid thing and it's "pipe curl to a shell" roll "installer" does to your DNS configuration, or whether it supports openresolv. That's for you to figure out if you want to use it.
#3 2025-08-02 07:59:26
Strapicarus
Thanks! @steve_v
setting/creating /etc/NetworkManager/conf.d/dns.conf /etc/NetworkManager/conf.d/rc-manager.conf
[main]
dns=none
rc-manager=resolvconf
i was able to modify /etc/resolv.conf and set the nameservers manually.
many thanks.
And i never
if i can do it by "hand".
And i use nextdns because i can't affor pi-hole or something similar. i could use quad9 but that does not allow me to set multiple levels of blocking for differents devices, routers, browsers.
Thanks again is working now.
#4 2026-06-05 19:27:35
safari
Would you mind elaborating on exactly what you did with the `/etc/NetworkManager/conf.d` files to make this work? I didn't quite understand.
UPDATE, tried this, not tested yet https://askubuntu.com/a/623956
