#1 2025-07-22 13:00:17
yp
missing /run/user/... with elogind - not registering X session
Hello,
Recently, I noticed errors on some LXC containers regarding missing /run/user/XX directory, without paying much attention.
But on a desktop machine, /run/user/1000 was missing recently and it led me to find out that even though elogind is installed and registered console login, it does not register X session with lightdm.
loginctl
SESSION UID USER SEAT TTY   STATE  IDLE SINCE
     22   0 root -    pts/0 active no   -
1 sessions listed.
# ps aux | grep lightdm
root      1092  0.0  0.0   6548  2400 pts/0    S+   14:57   0:00 grep lightdm
root     22437  0.0  0.0 380968  7128 ?        SLl  14:11   0:00 /usr/sbin/lightdm
root     22445  2.5  0.6 25633760 214312 tty7  Ssl+ 14:11   1:08 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
lightdm  22482  0.0  0.0   4468  2180 ?        S    14:11   0:00 dbus-launch --autolaunch 88d78492ae7aa04b49d29220687f7529 --binary-syntax --close-stderr
lightdm  22483  0.0  0.0   5684  1692 ?        Ss   14:11   0:00 /usr/bin/dbus-daemon --syslog-only --fork --print-pid 5 --print-address 7 --session
root     22494  0.0  0.0 169752  7980 ?        Sl   14:11   0:00 lightdm --session-child 13 24
On another similar desktiop system, I get:
# loginctl
      1 1005 wark    seat0 tty7  active  no   -
     16    0 root    -     pts/0 active  no   -
     c1  136 lightdm seat0 -     closing no   -
3 sessions listed.
root      3924  0.0  0.0 307288  7172 ?        SLl  12:20   0:00 /usr/sbin/lightdm
root      3932  2.8  0.2 25496504 89184 tty7   Ssl+ 12:20   4:23 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
lightdm   4173  0.0  0.0   4512  2124 ?        S    12:20   0:00 dbus-launch --autolaunch 4edebaaa884f554dc8f3e050493a2ab4 --binary-syntax --close-stderr
lightdm   4174  0.0  0.0   5736  1852 ?        Ss   12:20   0:00 /usr/bin/dbus-daemon --syslog-only --fork --print-pid 5 --print-address 7 --session
lightdm   4176  0.0  0.0 380748  6896 ?        Sl   12:20   0:00 /usr/libexec/at-spi-bus-launcher
lightdm   4182  0.0  0.0   5700  3244 ?        S    12:20   0:00 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/at-spi2/accessibility.conf --nofork --print-address 11 --address=unix:path=/run/user/136/at-spi/bus_0
lightdm   4198  0.0  0.0 167628  7276 ?        Sl   12:20   0:00 /usr/libexec/at-spi2-registryd --use-gnome-session
root      4354  0.0  0.0 170228  8164 ?        Sl   12:20   0:00 lightdm --session-child 13 24
root      5966  0.0  0.0   9748  2276 pts/0    S+   14:57   0:00 grep lightdm
No so lightdm seat0 and no user seat0 on the first one. And I compared installed software and both PAM and lightdm config without noticing any differences.
I found no recent bug report and IA neither provided insights.
Any clue what is going on?
#2 2025-07-22 13:19:09
g4sra
Re: missing /run/user/... with elogind - not registering X session
Why does one have "/usr/share/defaults/at-spi2/accessibility.conf " opening up dbus but the other doesnt ?
#3 2025-07-22 13:58:11
yp
no handicaped user, so no need for any AT-SPI on both. It was installed by defaut only one of the other, but that should not affect the ability of elogind to register sessions.
(not to mentioned is run with user 136 which is likely lightdm)
