#1 2025-07-16 13:34:06
FM81
[SOLVED] do not group in panel - HOW?
Hello all together!
A daedalus installation with XFCE, the default panel on top, nothing special at all.
If I have opened, for example, three terminals I wish, that they are all showed separate in the panel.
But they are grouped together to one button. How can I avoid this, an show them separate in the panel?
In SETTINGS --> PANEL (OK, this is german in my case and ist named EINSTELLUNGEN --> LEISTE) there is nothing like "do not group"?
Thank you very much, best regards, FM_81
The most brilliant role in comedy is that of a fool, he must not be in order to make it seem. (Miguel de Cervantes)
#2 2025-07-16 15:17:44
JWM-Kit
Re: [SOLVED] do not group in panel - HOW?
in panel preference --> choose your panel (the one with the app list) --> Items tab --> Window Buttons (double click to show options)
Remove check next to  "Group Windows by application"
#3 2025-07-16 16:00:23
FM81
Thank you very much, that was the solution!
Greetings, FM_81
