Pages: 1
Trying to install wifi driver (Realtek RTL8852) from Github for Lenovo Thinkpad E16. I'm running Daedalus 5.0.1 amd64 XFCE. I am stuck at MAKE command getting the following errors. Not sure how to proceed.
comborico1611@devuan1611:~$ su -
Password:
root@devuan1611:~# cd rt8852be
-bash: cd: rt8852be: No such file or directory
root@devuan1611:~# git clone [url]https://github.com/HRex39/rtl8852be.git[/url]
fatal: destination path 'rtl8852be' already exists and is not an empty directory.
root@devuan1611:~# cd rtl8852be
root@devuan1611:~/rtl8852be# make -j8
#rm -f .symvers.8852be
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/6.1.0-35-amd64/build M=/root/rtl8852be modules
make[1]: *** /lib/modules/6.1.0-35-amd64/build: No such file or directory. Stop.
make: *** [Makefile:637: modules] Error 2
root@devuan1611:~/rtl8852be# apt update
Hit:1 [url]http://deb.devuan.org/merged[/url] daedalus InRelease
Hit:2 [url]https://brave-browser-apt-release.s3.brave.com[/url] stable InRelease
All packages are up to date.
root@devuan1611:~/rtl8852be# ^C
root@devuan1611:~/rtl8852be# apt install make gcc linux-headers-$(uname -r) build-essential git
make is already the newest version (4.3-4.1).
make set to manually installed.
gcc is already the newest version (4:12.2.0-3).
gcc set to manually installed.
build-essential is already the newest version (12.9).
git is already the newest version (1:2.39.5-0+deb12u2).
libwpe-1.0-1 libwpebackend-fdo-1.0-1
Use 'apt autoremove' to remove them.
linux-compiler-gcc-12-x86 linux-headers-6.1.0-35-common linux-kbuild-6.1
linux-compiler-gcc-12-x86 linux-headers-6.1.0-35-amd64
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 14.0 MB of archives.
After this operation, 65.2 MB of additional disk space will be used.
Get:1 [url]http://deb.devuan.org/merged[/url] daedalus/main amd64 linux-compiler-gcc-12-x86 amd64 6.1.137-1 [992 kB]
Get:2 [url]http://deb.devuan.org/merged[/url] daedalus/main amd64 linux-headers-6.1.0-35-common all 6.1.137-1 [10.2 MB]
Get:3 [url]http://deb.devuan.org/merged[/url] daedalus/main amd64 linux-kbuild-6.1 amd64 6.1.137-1 [1,250 kB]
Get:4 [url]http://deb.devuan.org/merged[/url] daedalus/main amd64 linux-headers-6.1.0-35-amd64 amd64 6.1.137-1 [1,523 kB]
Fetched 14.0 MB in 14s (1,027 kB/s)
Selecting previously unselected package linux-compiler-gcc-12-x86.
(Reading database ... 132689 files and directories currently installed.)
Preparing to unpack .../linux-compiler-gcc-12-x86_6.1.137-1_amd64.deb ...
Unpacking linux-compiler-gcc-12-x86 (6.1.137-1) ...
Selecting previously unselected package linux-headers-6.1.0-35-common.
Preparing to unpack .../linux-headers-6.1.0-35-common_6.1.137-1_all.deb ...
Unpacking linux-headers-6.1.0-35-common (6.1.137-1) ...
Selecting previously unselected package linux-kbuild-6.1.
Preparing to unpack .../linux-kbuild-6.1_6.1.137-1_amd64.deb ...
Unpacking linux-kbuild-6.1 (6.1.137-1) ...
Selecting previously unselected package linux-headers-6.1.0-35-amd64.
Preparing to unpack .../linux-headers-6.1.0-35-amd64_6.1.137-1_amd64.deb ...
Unpacking linux-headers-6.1.0-35-amd64 (6.1.137-1) ...
Setting up linux-compiler-gcc-12-x86 (6.1.137-1) ...
Setting up linux-kbuild-6.1 (6.1.137-1) ...
Setting up linux-headers-6.1.0-35-common (6.1.137-1) ...
Setting up linux-headers-6.1.0-35-amd64 (6.1.137-1) ...
make[1]: Entering directory '/usr/src/linux-headers-6.1.0-35-amd64'
CC [M] /root/rtl8852be/platform/platform_linux_pc_pci.o
CC [M] /root/rtl8852be/os_dep/osdep_service.o
CC [M] /root/rtl8852be/os_dep/osdep_service_linux.o
CC [M] /root/rtl8852be/os_dep/linux/rtw_cfg.o
CC [M] /root/rtl8852be/os_dep/linux/os_intfs.o
CC [M] /root/rtl8852be/os_dep/linux/ioctl_linux.o
CC [M] /root/rtl8852be/os_dep/linux/xmit_linux.o
CC [M] /root/rtl8852be/os_dep/linux/mlme_linux.o
/root/rtl8852be/os_dep/osdep_service_linux.c: In function ‘rtw_change_ifname’:
/root/rtl8852be/os_dep/osdep_service_linux.c:810:28: warning: passing argument 1 of ‘_rtw_memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
810 | _rtw_memcpy(pnetdev->dev_addr, adapter_mac_addr(padapter), ETH_ALEN);
/root/rtl8852be/os_dep/osdep_service_linux.c:48:24: note: expected ‘void *’ but argument is of type ‘const unsigned char *’
48 | void _rtw_memcpy(void *dst, const void *src, u32 sz)
/root/rtl8852be/os_dep/linux/os_intfs.c: In function ‘rtw_net_set_mac_address’:
/root/rtl8852be/os_dep/linux/os_intfs.c:79:28: warning: passing argument 1 of ‘_rtw_memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
79 | _rtw_memcpy(pnetdev->dev_addr, sa->sa_data, ETH_ALEN); /* set mac addr to net_device */
In file included from /root/rtl8852be/include/drv_types.h:25,
from /root/rtl8852be/os_dep/linux/os_intfs.c:17:
/root/rtl8852be/include/osdep_service.h:281:24: note: expected ‘void *’ but argument is of type ‘const unsigned char *’
281 | void _rtw_memcpy(void *dec, const void *sour, u32 sz);
/root/rtl8852be/os_dep/linux/os_intfs.c: In function ‘rtw_ndev_init’:
/root/rtl8852be/os_dep/linux/os_intfs.c:294:9: error: too many arguments to function ‘netif_napi_add’
294 | netif_napi_add(dev, &adapter->napi, rtw_recv_napi_poll, RTL_NAPI_WEIGHT);
In file included from /root/rtl8852be/include/osdep_service_linux.h:31,
from /root/rtl8852be/include/osdep_service.h:42:
/usr/src/linux-headers-6.1.0-35-common/include/linux/netdevice.h:2593:1: note: declared here
2593 | netif_napi_add(struct net_device *dev, struct napi_struct *napi,
/root/rtl8852be/os_dep/linux/os_intfs.c: In function ‘rtw_os_ndev_register’:
/root/rtl8852be/os_dep/linux/os_intfs.c:623:25: warning: passing argument 1 of ‘_rtw_memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
623 | _rtw_memcpy(ndev->dev_addr, adapter_mac_addr(adapter), ETH_ALEN);
/root/rtl8852be/os_dep/osdep_service_linux.c: In function ‘rtw_random32’:
/root/rtl8852be/os_dep/osdep_service_linux.c:850:16: error: implicit declaration of function ‘prandom_u32’; did you mean ‘prandom_u32_max’? [-Werror=implicit-function-declaration]
850 | return prandom_u32();
| prandom_u32_max
make[2]: *** [/usr/src/linux-headers-6.1.0-35-common/scripts/Makefile.build:255: /root/rtl8852be/os_dep/linux/os_intfs.o] Error 1
make[2]: *** Waiting for unfinished jobs....
cc1: some warnings being treated as errors
make[2]: *** [/usr/src/linux-headers-6.1.0-35-common/scripts/Makefile.build:255: /root/rtl8852be/os_dep/osdep_service_linux.o] Error 1
/root/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_cache_wback’:
/root/rtl8852be/platform/platform_linux_pc_pci.c:21:17: error: implicit declaration of function ‘pci_dma_sync_single_for_device’; did you mean ‘dma_sync_single_for_device’? [-Werror=implicit-function-declaration]
21 | pci_dma_sync_single_for_device(hwdev, *bus_addr, size,
/root/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_cache_inv’:
/root/rtl8852be/platform/platform_linux_pc_pci.c:30:17: error: implicit declaration of function ‘pci_dma_sync_single_for_cpu’; did you mean ‘dma_sync_single_for_cpu’? [-Werror=implicit-function-declaration]
30 | pci_dma_sync_single_for_cpu(hwdev, *bus_addr, size, direction);
/root/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_get_bus_addr’:
/root/rtl8852be/platform/platform_linux_pc_pci.c:39:29: error: implicit declaration of function ‘pci_map_single’; did you mean ‘dma_map_single’? [-Werror=implicit-function-declaration]
39 | *bus_addr = pci_map_single(hwdev, vir_addr, size, direction);
| dma_map_single
/root/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_unmap_bus_addr’:
/root/rtl8852be/platform/platform_linux_pc_pci.c:50:17: error: implicit declaration of function ‘pci_unmap_single’; did you mean ‘dma_unmap_single’? [-Werror=implicit-function-declaration]
50 | pci_unmap_single(hwdev, *bus_addr, size, direction);
| dma_unmap_single
/root/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_free_noncache_mem’:
/root/rtl8852be/platform/platform_linux_pc_pci.c:97:17: error: implicit declaration of function ‘pci_free_consistent’ [-Werror=implicit-function-declaration]
97 | pci_free_consistent(pdev, size, vir_addr, *bus_addr);
make[2]: *** [/usr/src/linux-headers-6.1.0-35-common/scripts/Makefile.build:255: /root/rtl8852be/platform/platform_linux_pc_pci.o] Error 1
make[1]: *** [/usr/src/linux-headers-6.1.0-35-common/Makefile:2038: /root/rtl8852be] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-35-amd64'
root@devuan1611:~/rtl8852be# apt autoremove
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 186 kB disk space will be freed.
(Reading database ... 149229 files and directories currently installed.)
Removing libwpebackend-fdo-1.0-1:amd64 (1.14.2-1) ...
Removing libwpe-1.0-1:amd64 (1.14.0-1) ...
Processing triggers for libc-bin (2.36-9+deb12u10) ...
CC [M] /root/rtl8852be/os_dep/linux/recv_linux.o
CC [M] /root/rtl8852be/os_dep/linux/ioctl_cfg80211.o
CC [M] /root/rtl8852be/os_dep/linux/rtw_cfgvendor.o
CC [M] /root/rtl8852be/os_dep/linux/wifi_regd.o
CC [M] /root/rtl8852be/os_dep/linux/rtw_android.o
| prandom_u32_max
/root/rtl8852be/os_dep/linux/wifi_regd.c: In function ‘rtw_regd_init’:
/root/rtl8852be/os_dep/linux/wifi_regd.c:697:36: error: ‘REGULATORY_IGNORE_STALE_KICKOFF’ undeclared (first use in this function)
697 | wiphy->regulatory_flags |= REGULATORY_IGNORE_STALE_KICKOFF;
/root/rtl8852be/os_dep/linux/wifi_regd.c:697:36: note: each undeclared identifier is reported only once for each function it appears in
make[2]: *** [/usr/src/linux-headers-6.1.0-35-common/scripts/Makefile.build:255: /root/rtl8852be/os_dep/linux/wifi_regd.o] Error 1
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c: In function ‘rtw_cfg80211_ch_switch_notify’:
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:494:17: error: too few arguments to function ‘cfg80211_ch_switch_started_notify’
494 | cfg80211_ch_switch_started_notify(adapter->pnetdev, &chdef, 0, false);
In file included from /root/rtl8852be/include/osdep_service_linux.h:100,
from /root/rtl8852be/include/osdep_service.h:42,
from /root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:17:
/usr/src/linux-headers-6.1.0-35-common/include/net/cfg80211.h:8443:6: note: declared here
8443 | void cfg80211_ch_switch_started_notify(struct net_device *dev,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:505:9: error: too few arguments to function ‘cfg80211_ch_switch_notify’
505 | cfg80211_ch_switch_notify(adapter->pnetdev, &chdef);
/usr/src/linux-headers-6.1.0-35-common/include/net/cfg80211.h:8427:6: note: declared here
8427 | void cfg80211_ch_switch_notify(struct net_device *dev,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c: In function ‘rtw_cfg80211_indicate_connect’:
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:1189:26: error: ‘struct cfg80211_roam_info’ has no member named ‘bssid’
1189 | roam_info.bssid = cur_network->network.MacAddress;
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c: At top level:
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10354:20: error: initialization of ‘int (*)(struct wiphy *, struct net_device *, int, u8, bool, const u8 *, struct key_params *)’ {aka ‘int (*)(struct wiphy *, struct net_device *, int, unsigned char, _Bool, const unsigned char *, struct key_params *)’} from incompatible pointer type ‘int (*)(struct wiphy *, struct net_device *, u8, bool, const u8 *, struct key_params *)’ {aka ‘int (*)(struct wiphy *, struct net_device *, unsigned char, _Bool, const unsigned char *, struct key_params *)’} [-Werror=incompatible-pointer-types]
10354 | .add_key = cfg80211_rtw_add_key,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10354:20: note: (near initialization for ‘rtw_cfg80211_ops.add_key’)
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10355:20: error: initialization of ‘int (*)(struct wiphy *, struct net_device *, int, u8, bool, const u8 *, void *, void (*)(void *, struct key_params *))’ {aka ‘int (*)(struct wiphy *, struct net_device *, int, unsigned char, _Bool, const unsigned char *, void *, void (*)(void *, struct key_params *))’} from incompatible pointer type ‘int (*)(struct wiphy *, struct net_device *, u8, bool, const u8 *, void *, void (*)(void *, struct key_params *))’ {aka ‘int (*)(struct wiphy *, struct net_device *, unsigned char, _Bool, const unsigned char *, void *, void (*)(void *, struct key_params *))’} [-Werror=incompatible-pointer-types]
10355 | .get_key = cfg80211_rtw_get_key,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10355:20: note: (near initialization for ‘rtw_cfg80211_ops.get_key’)
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10356:20: error: initialization of ‘int (*)(struct wiphy *, struct net_device *, int, u8, bool, const u8 *)’ {aka ‘int (*)(struct wiphy *, struct net_device *, int, unsigned char, _Bool, const unsigned char *)’} from incompatible pointer type ‘int (*)(struct wiphy *, struct net_device *, u8, bool, const u8 *)’ {aka ‘int (*)(struct wiphy *, struct net_device *, unsigned char, _Bool, const unsigned char *)’} [-Werror=incompatible-pointer-types]
10356 | .del_key = cfg80211_rtw_del_key,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10356:20: note: (near initialization for ‘rtw_cfg80211_ops.del_key’)
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10357:28: error: initialization of ‘int (*)(struct wiphy *, struct net_device *, int, u8, bool, bool)’ {aka ‘int (*)(struct wiphy *, struct net_device *, int, unsigned char, _Bool, _Bool)’} from incompatible pointer type ‘int (*)(struct wiphy *, struct net_device *, u8, bool, bool)’ {aka ‘int (*)(struct wiphy *, struct net_device *, unsigned char, _Bool, _Bool)’} [-Werror=incompatible-pointer-types]
10357 | .set_default_key = cfg80211_rtw_set_default_key,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10357:28: note: (near initialization for ‘rtw_cfg80211_ops.set_default_key’)
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10359:33: error: initialization of ‘int (*)(struct wiphy *, struct net_device *, int, u8)’ {aka ‘int (*)(struct wiphy *, struct net_device *, int, unsigned char)’} from incompatible pointer type ‘int (*)(struct wiphy *, struct net_device *, u8)’ {aka ‘int (*)(struct wiphy *, struct net_device *, unsigned char)’} [-Werror=incompatible-pointer-types]
10359 | .set_default_mgmt_key = cfg80211_rtw_set_default_mgmt_key,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10359:33: note: (near initialization for ‘rtw_cfg80211_ops.set_default_mgmt_key’)
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10392:20: error: initialization of ‘int (*)(struct wiphy *, struct net_device *, unsigned int)’ from incompatible pointer type ‘int (*)(struct wiphy *, struct net_device *)’ [-Werror=incompatible-pointer-types]
10392 | .stop_ap = cfg80211_rtw_stop_ap,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10392:20: note: (near initialization for ‘rtw_cfg80211_ops.stop_ap’)
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10434:24: error: initialization of ‘int (*)(struct wiphy *, struct wireless_dev *, unsigned int, struct cfg80211_chan_def *)’ from incompatible pointer type ‘int (*)(struct wiphy *, struct wireless_dev *, struct cfg80211_chan_def *)’ [-Werror=incompatible-pointer-types]
10434 | .get_channel = cfg80211_rtw_get_channel,
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10434:24: note: (near initialization for ‘rtw_cfg80211_ops.get_channel’)
| dma_map_single
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c: In function ‘rtw_wdev_unregister’:
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:10690:17: error: ‘struct wireless_dev’ has no member named ‘current_bss’
10690 | if (wdev->current_bss) {
| dma_unmap_single
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c: In function ‘rtw_get_chbwoff_from_cfg80211_chan_def’:
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:6233:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
6233 | *ht = 0;
/root/rtl8852be/os_dep/linux/ioctl_cfg80211.c:6235:9: note: here
6235 | case NL80211_CHAN_WIDTH_20:
make[2]: *** [/usr/src/linux-headers-6.1.0-35-common/scripts/Makefile.build:255: /root/rtl8852be/os_dep/linux/ioctl_cfg80211.o] Error 1
root@devuan1611:~/rtl8852be# make install
install -p -m 644 8852be.ko /lib/modules/6.1.0-35-amd64/kernel/drivers/net/wireless/
install: cannot stat '8852be.ko': No such file or directory
make: *** [Makefile:646: install] Error 1 Last edited by comborico1611 (2025-07-10 18:01:59)
please use code tag.
The answer is right there, in gigantic font, at the top of the README for the (archived) github repository you are cloning:
KERNEL > 6.0.0 NOT LONGER MAINTAIN
For kernel > 6.0.0, You should view https://github.com/lwfinger/rtw89
The module you are trying to compile references functions that no longer exist (at least under those names) in your installed (6.1.0) kernel. Either fix it yourself (out of scope here) or use a codebase that is maintained for current kernels.
Okay, great! Thanks for next step!
I blacklisted the driver per the driver given via lshw -C network: r8169. There was no blacklist.conf file so I created one by making a txt file, adding the only line 'blacklist r8169' and saving it as blacklist-r8169.conf in the modprobe.d folder.
I then resumed once again MAKE, errors remain, albeit shorter. Unable to execute MAKE INSTALL. No useful results on search engine for the errors given "linux rtl driver pci_dma_sync_single_for_device" or "linux rtl driver.
Any suggestions?
Do I need to make blacklist-r8169.conf executable? I see blacklist hash error at boot, however, search engine stated it was normal for disabled secure boot. Do I need to get A.I. involved in this?
If we work together, I think we can resolve the issue.
-Combo
P.S. I hope some humor is agreeable.
[root@devuan1611:~/rtl8852be# make
| dma_map_single
| dma_unmap_single
make: *** [Makefile:646: install] Error 1Last edited by comborico1611 (2025-07-10 18:02:31)
Any suggestions?
Yes firstly stop trying to compile as root do the ./configure, and ./make steps as a normal user then when needing to install the module use sudo make install this is the only step that requires the root user to get done. And I see nothing about the ./configure step being done. Lastly where does this crazy line come from make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/6.1.0-35-amd64/build. You are already on the x86_64 arch with the kernel headers installed and since it is the same arch you are not cross-compiling, try make instead. Start with newly extracted source for the proper driver as pointed out above the source you try to use is out of date according to the posting by steve_v. You want the linked rtw_89 and you just might have chance of having some success in getting it done.
You haven't compiled the replacement driver successfully yet, so blacklisting the in-kernel one is completely irrelevant at this point.
Without addressing (or even reading it seems) what I posted above, so...
errors remain
Of course they do.
I just told you what the compiler errors mean, a search engine won't tell you anything different - even of it has indexed that exact line, which it probably hasn't.
Nor will an Artificial Idiot. ![]()
Any suggestions?
Already provided: Get a driver that is maintained and compatible with your kernel version... Or learn enough C and kernel programming to find and fix all the deprecated function calls in the broken one you seem determined to use.
One of these is easy, the other is hard. Your choice.
Uhh, whut? Why would that matter, it's a configuration file for modprobe. Try 'man modprobe' and 'man modprobe.d' instead of flailing randomly.
If you read the README in that github repo and followed the link, I expect you would have resolved this already by yourself.
The maintained driver repo even includes DKMS packaging instructions, which I suggest you follow so you get a .deb package and automatic rebuilds on kernel changes.
Autoconf 'configure' scripts are stored in the source directory, but 'make' is a binary in system path. So './configure [--option]' and 'make [target]'.
In this case however...
The source in question does some (sort of) autoconf from the makefile (and a bunch of other crazy besides), there is no configure script.
where does this crazy line come from... try make instead
They did. Read the makefile. ![]()
since the OP seems unable to use simple code tags perhaps we might hypothesize we are interacting with ai/llm? how would we know? could we? really?
don't get me wrong, i understand. a dear one has dementia and no longer knows who they are/was/were. it is hard to relate unless/until it is personally experienced and so one must seek out others who have both experienced it and are willing to share and talk about it as well. life is short, love them long.
Sure reads like one, and I was gunna say it... But benefit of the doubt and all that. They could also just be a noob, copy-pasting the usual outdated blog-post garbage.
Then again, the Large-Regurgitation-Model hypothesis would neatly explain things like missing the "No longer maintained for kernel > 6.0.0" bit (it's an image, not plaintext), and the inane "Okay, great! Thanks for next step!" reply (while clearly not understanding the advice)...
@comborico1611
You have used the inline code tag ("c" with square brackets) whereas you should have used the large code block tag ("code" with square brackets) for that lengthy piece of code. It's a simple matter to fix. ![]()
I will help with generic advice on compiling and on the odd occasion will read and build the driver on a system, this is not one of them times. Most times though I will not install dev tools just to do that. The OP has enough problems following advice given, my effort level in that case is not that high to go that extra mile.
Though now I remember I have system like it with compiler and everything necessary just for shits and giggles since I have some time on my hands..
seeder1@8400t:~$ acp gcc
gcc:
Installed: 4:12.2.0-3
Candidate: 4:12.2.0-3
Version table:
*** 4:12.2.0-3 500
500 http://ftp.ca.debian.org/debian bookworm/main amd64 Packages
100 /var/lib/dpkg/status
seeder1@8400t:~$ acp build-essential
build-essential:
Installed: 12.9
Candidate: 12.9
Version table:
*** 12.9 500
seeder1@8400t:~$ acp make
make:
Installed: 4.3-4.1
Candidate: 4.3-4.1
Version table:
*** 4.3-4.1 500
seeder1@8400t:~$ acp git
git:
Installed: 1:2.39.5-0+deb12u2
Candidate: 1:2.39.5-0+deb12u2
Version table:
*** 1:2.39.5-0+deb12u2 500
500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
seeder1@8400t:~$ acp linux-headers-$(uname -r)
linux-headers-6.1.0-37-amd64:
Installed: 6.1.140-1
Candidate: 6.1.140-1
Version table:
*** 6.1.140-1 500
500 http://ftp.ca.debian.org/debian bookworm-proposed-updates/main amd64 Packages
seeder1@8400t:~$ alias acp
alias acp='apt-cache policy'
seeder1@8400t:~$ ll src
ls: cannot access 'src': No such file or directory
seeder1@8400t:~$ mkdir src
seeder1@8400t:~$ cd src
seeder1@8400t:~/src$ git clone https://github.com/lwfinger/rtw89.git
Cloning into 'rtw89'...
remote: Enumerating objects: 7524, done.
remote: Counting objects: 100% (1755/1755), done.
remote: Compressing objects: 100% (94/94), done.
remote: Total 7524 (delta 1703), reused 1661 (delta 1661), pack-reused 5769 (from 2)
Receiving objects: 100% (7524/7524), 7.99 MiB | 23.11 MiB/s, done.
Resolving deltas: 100% (6041/6041), done.
seeder1@8400t:~/src$ cd rtw89
eeder1@8400t:~/src/rtw89$ make
make -C /lib/modules/6.1.0-37-amd64/build M=/home/seeder1/src/rtw89 modules
make[1]: Entering directory '/usr/src/linux-headers-6.1.0-37-amd64'
CC [M] /home/seeder1/src/rtw89/core.o
/home/seeder1/src/rtw89/core.c:1751:11: warning: ‘rtw89_rxdesc_to_nl_he_gi’ defined but not used [-Wunused-function]
1751 | static u8 rtw89_rxdesc_to_nl_he_gi(struct rtw89_dev *rtwdev,
CC [M] /home/seeder1/src/rtw89/mac80211.o
CC [M] /home/seeder1/src/rtw89/mac.o
snip......
Skipping BTF generation for /home/seeder1/src/rtw89/rtw_8852c.ko due to unavailability of vmlinux
CC [M] /home/seeder1/src/rtw89/rtw_8852ce.mod.o
LD [M] /home/seeder1/src/rtw89/rtw_8852ce.ko
BTF [M] /home/seeder1/src/rtw89/rtw_8852ce.ko
Skipping BTF generation for /home/seeder1/src/rtw89/rtw_8852ce.ko due to unavailability of vmlinux
CC [M] /home/seeder1/src/rtw89/rtw_8922a.mod.o
LD [M] /home/seeder1/src/rtw89/rtw_8922a.ko
BTF [M] /home/seeder1/src/rtw89/rtw_8922a.ko
Skipping BTF generation for /home/seeder1/src/rtw89/rtw_8922a.ko due to unavailability of vmlinux
CC [M] /home/seeder1/src/rtw89/rtw_8922ae.mod.o
LD [M] /home/seeder1/src/rtw89/rtw_8922ae.ko
BTF [M] /home/seeder1/src/rtw89/rtw_8922ae.ko
Skipping BTF generation for /home/seeder1/src/rtw89/rtw_8922ae.ko due to unavailability of vmlinux
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-37-amd64'
seeder1@8400t:~/src/rtw89$ ll /vmlinuz
0 lrwxrwxrwx 1 root root 27 Jun 28 09:58 /vmlinuz -> boot/vmlinuz-6.1.0-37-amd64With the result being the bottom of the snipped output with some stupid foolishness about not being able to find vmlinuz which is clearly there. Who knows if the the make install would work I am not interested in seeing if that step works. But if the OP will actually listen to advice given he can try and and find out.
Who's asking it to look for vmlinux? I cloned the git repo and grepped for vmlinux and vmlinuz and got nothing.
Okay, I will try to find the advice I missed.
I have no clue nor the interest to search the source to find out why the stupid things "Skipping BTF generation" step is looking for vmlinux now I notice instead of the vmlinuz that is there when the auto-complete gave it to me on my Debian system when I was wondering it was not finding what I knew had to be there to boot.. I went systemd free with after seeing how easy it is to do on a Devuan conversion.
seeder1@8400t:~$ acp systemd
systemd:
Installed: (none)
Candidate: (none)
Version table:
254.26-1~bpo12+1 -1
100 http://ftp.ca.debian.org/debian bookworm-backports/main amd64 Packages
252.38-1~deb12u1 -1
252.36-1~deb12u1 -1
500 http://ftp.ca.debian.org/debian bookworm/main amd64 PackagesOnline
You may also want to apt update then apt upgrade. It appears your kernel is two versions (-35 vs -37) behind the present released version by Debian which Devuan follows very closely. Most times on my main Devuan machine I will get the new kernel before it hits the Debian archives for those other machines I have running Debian systemd free.
Pages: 1
