#1 2025-05-26 23:17:19
igorzwx
[HowTo] audacious_4.5-devel-1_amd64.deb (meson+samu and muon+samu)
How to compile Audacious with meson and samurai
Portable Meson is available here:
_https://github.com/mesonbuild/meson
arch-meson is available here:
_https://aur.archlinux.org/cgit/aur.git/snapshot/meson-git.tar.gz
samurai is easy to compile
_https://dev1galaxy.org/viewtopic.php?id=7203
Install Build_Deps, compilers and utilities:
sudo apt-get install build-essentials apt-file fakeroot git libglib2.0-dev libgtk-3-dev libjson-glib-dev libopusfile-dev
sudo apt install libadplug-dev adplug-utils libjson-glib-dev libopusfile-dev libasound2-dev libavcodec-dev libavformat-dev libavutil-dev libbinio-dev libbs2b-dev libcairo2-dev libcddb2-dev libcdio-cdda-dev libcue-dev libcurl4-gnutls-dev libdbus-glib-1-dev libfaad-dev libflac-dev libfluidsynth-dev libgtk2.0-dev libjack-dev liblircclient-dev libmms-dev libmodplug-dev libmp3lame-dev libmpg123-dev libneon27-gnutls-dev libnotify-dev libogg-dev libopenmpt-dev libsdl2-dev libsidplayfp-dev libsndfile1-dev libsndio-dev libtagc0-dev libvorbis-dev libwavpack-dev libxcomposite-dev libxml2-dev
Download the source code
mkdir Build1
cd Build1
git clone https://github.com/audacious-media-player/audacious.git --depth 1
Configure the project, for example:
$ cat audacious/meson_options.txt
option('dbus', type: 'boolean', value: true,
       description: 'Whether D-Bus support is enabled')
option('qt', type: 'boolean', value: false,
       description: 'Whether Qt support is enabled')
option('qt5', type: 'boolean', value: false,
       description: 'Whether Qt 5 support is enabled')
option('gtk', type: 'boolean', value: true,
       description: 'Whether GTK support is enabled')
option('gtk2', type: 'boolean', value: false,
       description: 'Whether GTK 2 support is enabled')
option('libarchive', type: 'boolean', value: false,
       description: 'Whether libarchive support is enabled')
option('buildstamp', type: 'string', value: 'Devuan 5 Daedalus',
       description: 'Allows to set a custom build stamp')
option('valgrind', type: 'boolean', value: false,
       description: 'Whether Valgrind analysis support is enabled')
1. Setup the build system
arch-meson audacious build
2. Compile
samu -C build
3. Install to debdir
DESTDIR=../debdir samu -C build install
install -vDm644 audacious/contrib/audacious.appdata.xml -t "debdir/usr/share/metainfo"
install -vDm644 audacious/COPYING -t "debdir/usr/share/licenses/audacious"
Make a template
mkdir debian
echo -e "Source: audacious\nPackage: audacious\nDepends: \${shlibs:Depends}" >> debian/control
$ cat debian/control
Source: audacious
Package: audacious
Depends: ${shlibs:Depends}
Run "dpkg-shlibdeps" to calculate dependencies
dpkg-shlibdeps -v -xaudacious -ldebdir/usr/lib --ignore-missing-info -e $(find debdir/usr -type f 2>/dev/null)
$ cat debian/substvars
shlibs:Depends=libc6 (>= 2.35), libcairo2 (>= 1.2.4), libgcc-s1 (>= 3.3.1), libgdk-pixbuf-2.0-0 (>= 2.25.2), libglib2.0-0 (>= 2.37.3), libgtk-3-0 (>= 3.21.5), libpango-1.0-0 (>= 1.14.0), libstdc++6 (>= 12)
install -vm0755 -d debdir/DEBIAN
Create DEBIAN/control with a text editor, for example:
$ cat debdir/DEBIAN/control
Package: audacious
Version: 4.5-devel-1
Architecture: amd64
Maintainer: Devuan
Installed-Size: 2451
Depends: libc6 (>= 2.35), libcairo2 (>= 1.2.4), libgcc-s1 (>= 3.3.1), libgdk-pixbuf-2.0-0 (>= 2.25.2), libglib2.0-0 (>= 2.37.3), libgtk-3-0 (>= 3.21.5), libpango-1.0-0 (>= 1.14.0), libstdc++6 (>= 12)
Recommends: unzip
Suggests: audacious-plugins
Conflicts: audacious-dev, libaudcore5t64, libaudgui6, libaudqt3, libaudtag3t64
Provides: audacious-dev, libaudcore5t64, libaudgui6, libaudqt3, libaudtag3t64
Section: sound
Priority: optional
Homepage: https://www.audacious-media-player.org/
Description: small and fast audio player which supports lots of formats
  Audacious is a fork of beep-media-player which supports Winamp skins
  and many codecs.
  In the default install, the following codecs are supported:
   * MP3
   * Ogg Vorbis / Theora
   * AAC and AAC+
   * FLAC
   * ALAC
   * Windows Media (WMA)
   * WAVE
  Additionally, Audacious is extendable through plugins, and contains
  other useful features like LIRC support. Support for many more codecs
  can also be added through plugins.
Tag: field::arts, implemented-in::c, interface::graphical, interface::x11,
  role::program, scope::application, sound::player, uitoolkit::gtk,
  use::learning, use::playing, works-with-format::mp3,
  works-with-format::oggvorbis, works-with::audio, x11::application
Generate DEBIAN/md5sums
cd debdir
find . -type f -not -path "./DEBIAN/*" -exec md5sum {} + | sort -k 2 | sed 's/\.\/\(.*\)/\1/' > DEBIAN/md5sums
cd ..
chmod 0644 -- debdir/DEBIAN/md5sums
Make Debian package
$ fakeroot -- dpkg-deb -b debdir audacious_4.5-devel-1_amd64.deb
dpkg-deb: building package 'audacious' in 'audacious_4.5-devel-1_amd64.deb'.
Install
sudo dpkg -i audacious_4.5-devel-1_amd64.deb
How to compile Audacious-plugins
sidplay-rom-paths.patch is available here:
_https://gitlab.archlinux.org/archlinux/packaging/packages/audacious-plugins/-/raw/main/sidplay-rom-paths.patch
Download the source code and the patch
mkdir Build1p
cd Build1p
git clone https://github.com/audacious-media-player/audacious-plugins.git --depth 1
$ ls -1
audacious-plugins
Apply the patch:
cd audacious-plugins
patch -Np1 -i ../sidplay-rom-paths.patch
cd ..
Edit "meson_options.txt" with a text editor
nano audacious-plugins/meson_options.txt
Disable QT6, enable OSS4 (if it is installed), disable pulse and unwanted resamplers. For example:
# GUI toolkits
# output plugins
option('oss4', type: 'boolean', value: true,
       description: 'Whether OSS4 support is enabled')
option('pipewire', type: 'boolean', value: false,
option('pulse', type: 'boolean', value: false,
option('qtaudio', type: 'boolean', value: false,
option('resample', type: 'boolean', value: false,
option('soxr', type: 'boolean', value: false,
option('speedpitch', type: 'boolean', value: false,
arch-meson audacious-plugins build
2. Compile
samu -C build
3. Install to "debdir"
install -vDm644 audacious-plugins/COPYING -t "debdir/usr/share/licenses/audacious-plugins"
$ ls -1
audacious-plugins
build
debdir
Make a template
mkdir debian
echo -e "Source: audacious-plugins\nPackage: audacious-plugins\nDepends: \${shlibs:Depends}" >> debian/control
dpkg-shlibdeps -v -xaudacious-plugins -ldebdir/usr/lib --ignore-missing-info -e $(find debdir/usr -type f 2>/dev/null)
shlibs:Depends=libadplug-2.3.3-0 (>= 2.3.3+dfsg), libasound2 (>= 1.0.16), libavcodec59 (>= 7:5.0), libavformat59 (>= 7:5.0), libavutil57 (>= 7:5.0), libbinio1v5 (>= 1.4+dfsg1), libbs2b0 (>= 3.1.0+dfsg), libc6 (>= 2.35), libcairo2 (>= 1.10.0), libcddb2 (>= 1.3.2), libcdio-cdda2 (>= 10.2+2.0.0), libcdio19 (>= 2.1.0), libcue2, libcurl3-gnutls (>= 7.16.2), libfaad2 (>= 2.7), libflac12 (>= 1.3.0), libfluidsynth3 (>= 2.0.5), libgcc-s1 (>= 3.3.1), libgdk-pixbuf-2.0-0 (>= 2.22.0), libgl1, libglib2.0-0 (>= 2.37.3), libgtk-3-0 (>= 3.21.5), libjack-jackd2-0 (>= 1.9.10+20150825) | libjack-0.125, libjson-glib-1.0-0 (>= 1.5.2), liblirc-client0, libmms0 (>= 0.4), libmodplug1 (>= 1:0.8.8.5), libmp3lame0 (>= 3.100), libmpg123-0 (>= 1.28.0), libneon27-gnutls, libnotify4 (>= 0.7.0), libogg0 (>= 1.1.0), libopenmpt0 (>= 0.3.0), libopusfile0 (>= 0.5), libpango-1.0-0 (>= 1.22.0), libpangocairo-1.0-0 (>= 1.14.0), libsdl2-2.0-0 (>= 2.0.12), libsidplayfp6 (>= 2.4.2), libsndfile1 (>= 1.0.20), libsndio7.0 (>= 1.9.0), libstdc++6 (>= 12), libvorbis0a (>= 1.2.0), libvorbisenc2 (>= 1.1.2), libvorbisfile3 (>= 1.1.2), libwavpack1 (>= 4.40.0), libx11-6, libxcomposite1 (>= 1:0.4.5), libxml2 (>= 2.7.4), libxrender1, zlib1g (>= 1:1.1.4)
install -m0755 -d debdir/DEBIAN
Create DEBIAN/control, for example:
Architecture: amd64
Maintainer: Devuan
Installed-Size: 7313
Depends: libadplug-2.3.3-0 (>= 2.3.3+dfsg), libasound2 (>= 1.0.16), libavcodec59 (>= 7:5.0), libavformat59 (>= 7:5.0), libavutil57 (>= 7:5.0), libbinio1v5 (>= 1.4+dfsg1), libbs2b0 (>= 3.1.0+dfsg), libc6 (>= 2.35), libcairo2 (>= 1.10.0), libcddb2 (>= 1.3.2), libcdio-cdda2 (>= 10.2+2.0.0), libcdio19 (>= 2.1.0), libcue2, libcurl3-gnutls (>= 7.16.2), libfaad2 (>= 2.7), libflac12 (>= 1.3.0), libfluidsynth3 (>= 2.0.5), libgcc-s1 (>= 3.3.1), libgdk-pixbuf-2.0-0 (>= 2.22.0), libgl1, libglib2.0-0 (>= 2.37.3), libgtk-3-0 (>= 3.21.5), libjack-jackd2-0 (>= 1.9.10+20150825) | libjack-0.125, libjson-glib-1.0-0 (>= 1.5.2), liblirc-client0, libmms0 (>= 0.4), libmodplug1 (>= 1:0.8.8.5), libmp3lame0 (>= 3.100), libmpg123-0 (>= 1.28.0), libneon27-gnutls, libnotify4 (>= 0.7.0), libogg0 (>= 1.1.0), libopenmpt0 (>= 0.3.0), libopusfile0 (>= 0.5), libpango-1.0-0 (>= 1.22.0), libpangocairo-1.0-0 (>= 1.14.0), libsdl2-2.0-0 (>= 2.0.12), libsidplayfp6 (>= 2.4.2), libsndfile1 (>= 1.0.20), libsndio7.0 (>= 1.9.0), libstdc++6 (>= 12), libvorbis0a (>= 1.2.0), libvorbisenc2 (>= 1.1.2), libvorbisfile3 (>= 1.1.2), libwavpack1 (>= 4.40.0), libx11-6, libxcomposite1 (>= 1:0.4.5), libxml2 (>= 2.7.4), libxrender1, zlib1g (>= 1:1.1.4)
Recommends: audacious (>= 4.5-devel)
Conflicts: audacious-plugins-data
Provides: audacious-plugins-data
Section: sound
Priority: optional
Homepage: https://audacious-media-player.org/
Description: Base plugins for audacious
 Audacious is a fork of beep-media-player which supports winamp skins
 and many codecs.
  * MP3
  * Ogg Vorbis
  * AAC and AAC+
  * FLAC
  * Many module formats and much more!
 This package contains the plugins for Audacious.
  * Audio CD reading
  * MPEG support (mp3)
  * Ogg Vorbis support
  * Windows Media support (WMA)
  * AAC support
  * FLAC support
  * ALAC support
  * WAVE support
  * ALSA output
  * OSS4 output
  * Disk writer output
  * And many more!
cd debdir
Make a Debian package
$ fakeroot -- dpkg-deb -b debdir audacious-plugins_4.5-devel-1_amd64.deb
dpkg-deb: building package 'audacious-plugins' in 'audacious-plugins_4.5-devel-1_amd64.deb'.
Install
sudo dpkg -i audacious-plugins_4.5-devel-1_amd64.deb
$ audacious -v
Audacious 4.5-devel (Devuan 5 Daedalus)
DEBUG
$ audacious -VV
INFO ../audacious/src/libaudcore/output.cc:270 [setup_output]:
Setup output, format 11, 2 channels, 192000 Hz.
DEBUG ../audacious-plugins/src/oss4/oss.cc:219 [open_audio]:
Opening audio.
DEBUG ../audacious-plugins/src/oss4/oss.cc:144 [open_device]:
Enabled exclusive mode.
DEBUG ../audacious-plugins/src/oss4/oss.cc:61 [set_format]:
Audio format: AFMT_S32_LE, sample rate: 192000Hz, number of channels: 2.
DEBUG ../audacious-plugins/src/oss4/oss.cc:68 [set_format]:
Disabled format conversions made by the OSS software.
#2 2025-05-28 09:26:18
igorzwx
Re: [HowTo] audacious_4.5-devel-1_amd64.deb (meson+samu and muon+samu)
How to compile audacious with muon+samu
Portable static Muon (with embedded samu) is available here:
_https://muon.build/
_https://muon.build/releases/v0.5.0/muon-v0.5.0-amd64-linux
$ file muon-v0.5.0-amd64-linux
muon-v0.5.0-amd64-linux: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), statically linked, BuildID[sha1]=1a2a3022413581300d66c86f02329ed4aa782022, stripped
The procedure of compiling is very similar to that of meson. The main difference is that muon may refuse to search for headers, unless PKG_CONFIG_PATH is set. Although it might be very inconvenient for the slaves of pulseaudio (because of progressive dementia caused by pulseaudio), it provides the freedom to decide which headers should be used.
Dementia is progressive. This means signs and symptoms may be relatively mild at first but they get worse with time. Dementia affects everyone differently, however it can be helpful to think of dementia progressing in 'three stages'.
_https://www.alzheimers.org.uk/about-dementia/symptoms-and-diagnosis/how-dementia-progresses/progression-stages-dementia
⟡ AI Overview
Engaging in intellectually stimulating activities may offer a degree of protection against dementia, particularly for individuals who may have otherwise lower levels of education or occupation. While more research is needed, evidence suggests that activities like reading, playing board games, musical instrument playing, journaling, and crossword puzzles are associated with a reduced risk of developing dementia.
There is a belief that compiling with muon may protect pulseaudio users against Alzheimer's disease (AD). That is why, perhaps, muon is available even in Debian repositories (a very old version, of course).
Because of progressive dementia, it might be necessary to explain how to set PKG_CONFIG_PATH. Otherwise it might be a very difficult problem to solve.
PKG_CONFIG_PATH can be set with a secret command, for example:
export PKG_CONFIG_PATH="$HOME/.local/lib/pkgconfig:$(pkgconf --variable pc_path pkgconf)"
$ cat $HOME/.local/lib/pkgconfig/GL.pc
prefix=/usr
includedir=${prefix}/include
libdir=${prefix}/lib/x86_64-linux-gnu
Description: Legacy OpenGL and GLX library and headers.
Version: 1.2
Libs: -L${libdir} -lGL
Cflags: -I${includedir}/GL
GL.pc is needed for Audacious-plugins (OpenGL Spectrum Analyzer).
The "meson_options.txt" of Audacious and Audacious-plugins can be configured in the same way as it was done for "meson+samu" (see above). Audacious-plugins should be patched, of course (as it was described above). In any case, Audacious should be compiled and installed BEFORE the compilation Audacious-plugins. And, of course, the Debian packages can be made in exactly the same way.
Audacious:
cd audacious
muon setup -Dprefix=/usr -Ddefault_library=shared -Dbuildtype=release build
2. Compile
muon samu -C build
3. Install to a folder "debdir"
cd build
DESTDIR="../../debdir" muon install
cd ../../
Audacious-plugins:
2. Compile
muon samu -C build
cd build
cd ../../
#3 2025-11-02 20:55:39
kapqa
Hello ,
have completed part1 (How to compile audacious with muon+samu) up until "Audacious Plugins";
no not fully complete therfore getting error:
ERROR ../audacious/src/libaudcore/plugin-init.cc:155 [start_required]: No output plugin found.
(Did you forget to install audacious-plugins?)
Aborted
Could you please include support for .aiff since have backup of CD library mostly in this format;?
Thank you very much.
#4 2025-11-03 00:11:37
igorzwx
First you compile Audacious and install install it.
When Audacious is installed, you can compile Audacious-plugins.
Audacious is a build dependency for  Audacious-plugins.
Audacious-plugins are dependency for Audacious (it does not work without plugins).
When both installed everything should work.
sox input.aiff output.wav
flac -o output.flac input.wav
for f in *.aiff; do sox "$f" "${f%.aiff}.wav"; done
for f in *.wav; do flac "$f" "${f%.wav}.flac"; done
#5 2025-11-03 10:12:11
kapqa
thank you,
there is error with devuan 6.0?
(have upgraded just yesterday=)
Selecting previously unselected package audacious-plugins.
(Reading database ... 279591 files and directories currently installed.)
Preparing to unpack audacious-plugins_4.5-devel-1_amd64.deb ...
Unpacking audacious-plugins (4.5-devel-1) ...
dpkg: dependency problems prevent configuration of audacious-plugins:
audacious-plugins depends on libavformat59 (>= 7:5.0); however:
  Package libavformat59 is not installed.
audacious-plugins depends on libflac12 (>= 1.3.0); however:
  Package libflac12 is not installed.
dpkg: error processing package audacious-plugins (--install):
audacious-plugins
also, have not disabled "qt6" since it included in devuan excalibure?
#6 2025-11-03 12:45:35
igorzwx
It has nothing to do with qt6.
To install dependencies run
sudo apt install -f
This "magic command" should fix all problems.
dpkg does not install dependencies from repositories, This can be done with apt or apt-get
You may notice that I got the same dependencies (see above):
libavformat59 (>= 7:5.0), ..., libflac12 (>= 1.3.0)
The are available in the official repositories and can be easily installed.
NOTE: There is a conspiracy theory about a secret Devuan wiki, which explains how to install Debian packages with secret esoteric commands apt and apt-get
#7 2025-11-03 13:24:40
kapqa
for devuan 6.0 howver?
 sudo apt install libavformat
libavformat61        libavformat-dev      libavformat-extra    libavformat-extra61
sudo apt install libflac
libflac++11        libflac14          libflac++-dev      libflac-dev        libflac-doc        libflac-ocaml      libflac-ocaml-dev
thanks
#8 2025-11-03 13:36:51
igorzwx
The package "audacious-plugins" was compiled on Devuan 5 or Devuan 6 ?
Or you simply wrote wrong dependencies into DEBIAN/control to minimize work?
To minimize work, you should remove almost all dependencies from DEBIAN/control.
#9 2025-11-03 13:42:57
kapqa
both for devuan 6.0;
just added daedalus 5 to the sources.list, now it functions (it installed 3 packages).
Have however the same issue as with the pre-compiled version:
when i try to add "open folder" from a NFS share that is on the NAS, it would not find the ".aif" files?
maybe this is a limitation of the NFS share, since am just learning how to do it?
audacious
ERROR ../audacious-plugins/src/alsa/config.cc:238 [guess_element]: No suitable mixer element found.
Input:  44100 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 1764
Output: 192000 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 7680
Rates:  44100 --> 192000 (J: 0.00%, T: DCT, W: Vorbis)
Ok.
it looks like here
https://ibb.co/cK9vCpLF
https://ibb.co/fz9xbjLn
https://ibb.co/whzdP5Qz
#10 2025-11-03 13:46:54
igorzwx
How you got my dependencies for Devuan 5 into your package for Devuan 6.
The were not calculated, they were copied from my package.
Do you have pulseaudio installed?
#11 2025-11-03 13:48:44
kapqa
just followed your routine anyway, since this is quite complciated procedure, above my linux-skills.
#12 2025-11-03 13:59:38
igorzwx
If a package was compiled on your system, it cannot have unsatisfied dependencies.
"No suitable mixer element found" is a well known pulseaudio problem (permissions)
For example:
The issue was permission-based. I logged into x as root briefly and pavucontrol opened with no problem, as did Audacious.
_https://www.linuxquestions.org/questions/linux-software-2/alsa-error-no-suitable-mixer-element-found-and-can%27t-connect-to-pulseaudio-4175623535/
#13 2025-11-03 14:05:13
kapqa
no, no pulse, but thanks for reminding, the pipewire has krept back in; was wondering if the sound suddenly became "tinnier" again;
now it is removed; however, the .aif issue seems a limitation of the program itself or how it handles file/folder structures?
now, no pulseaudio, no pipewire. but folder containing files with .aif structure when added give "no files found".
#14 2025-11-03 14:08:52
igorzwx
No files found from Audacious? Can you get these files in file browser?
#15 2025-11-03 14:15:41
kapqa
alright, gonna check whats going on, maybe gonna use another program than itunes to make the CD Backup in the future;
(i like .aiff since it is like WAV and allows for metadata)
big thanks, bye.
for f in *.aif; do sox "$f" "${f%.aif}.wav"; done
sox FAIL formats: can't open output file `1-01 The Four Seasons, Rv269 (Pt. 1) Spring.wav': Read-only file system
sox FAIL formats: can't open output file `1-02 The Four Seasons, Rv269 (Pt. 2) Spring.wav': Read-only file system
sox FAIL formats: can't open output file `1-03 The Four Seasons, Rv269 (Pt. 3) Spring.wav': Read-only file system
sox FAIL formats: can't open output file `1-04 The Four Seasons, Rv315 (Pt. 1) Summer.wav': Read-only file system
sox FAIL formats: can't open output file `1-05 The Four Seasons, Rv315 (Pt. 2) Summer.wav': Read-only file system
sox FAIL formats: can't open output file `1-06 The Four Seasons, Rv315 (Pt. 3) Summer.wav': Read-only file system
sox FAIL formats: can't open output file `1-07 The Four Seasons, Rv293 (Pt. 1) Autumn.wav': Read-only file system
sox FAIL formats: can't open output file `1-08 The Four Seasons, Rv293 (Pt. 2) Autumn.wav': Read-only file system
sox FAIL formats: can't open output file `1-09 The Four Seasons, Rv293 (Pt. 3) Autumn.wav': Read-only file system
sox FAIL formats: can't open output file `1-10 The Four Seasons, Rv297 (Pt. 1) Winter.wav': Read-only file system
sox FAIL formats: can't open output file `1-11 The Four Seasons, Rv297 (Pt. 2) Winter.wav': Read-only file system
sox FAIL formats: can't open output file `1-12 The Four Seasons, Rv297 (Pt. 3) Winter.wav': Read-only file system
sox FAIL formats: can't open output file `1-13 Concerto For 2 Trumpets & Strings, Rv537 (Pt. 1).wav': Read-only file system
sox FAIL formats: can't open output file `1-14 Concerto For 2 Trumpets & Strings, Rv537 (Pt. 2).wav': Read-only file system
sox FAIL formats: can't open output file `1-15 Concerto For 2 Trumpets & Strings, Rv537 (Pt. 3).wav': Read-only file system
sox FAIL formats: can't open output file `1-16 Concerto For Mandolin & Strings, Rv425 (Pt. 1).wav': Read-only file system
sox FAIL formats: can't open output file `1-17 Concerto For Mandolin & Strings, Rv425 (Pt. 2).wav': Read-only file system
sox FAIL formats: can't open output file `1-18 Concerto For Mandolin & Strings, Rv425 (Pt. 3).wav': Read-only file system
sox FAIL formats: can't open output file `1-19 Concerto For Flute & Strings, Rv428 (Pt. 1).wav': Read-only file system
sox FAIL formats: can't open output file `1-20 Concerto For Flute & Strings, Rv428 (Pt. 2).wav': Read-only file system
sox FAIL formats: can't open output file `1-21 Concerto For Flute & Strings, Rv428 (Pt. 3).wav': Read-only file system
sox FAIL formats: can't open output file `1-22 Concerto For Violin & Strings, Rv453 (Pt. 1).wav': Read-only file system
sox FAIL formats: can't open output file `1-23 Concerto For Violin & Strings, Rv453 (Pt. 2).wav': Read-only file system
sox FAIL formats: can't open output file `1-24 Concerto For Violin & Strings, Rv453 (Pt. 3).wav': Read-only file syste
mediainfo 1-01\ The\ Four\ Seasons\,\ Rv269\ \(Pt.\ 1\)\ Spring.aif
General
Complete name                            : 1-01 The Four Seasons, Rv269 (Pt. 1) Spring.aif
Format                                   : AIFF
Format/Info                              : Apple/SGI
File size                                : 36.8 MiB
Duration                                 : 3 min 38 s
Overall bit rate mode                    : Constant
Overall bit rate                         : 1 411 kb/s
Album                                    : Venetian Splender
Part/Position                            : 1
Part/Total                               : 62
Track name                               : The Four Seasons, Rv269 (Pt. 1) Spring
Track name/Position                      : 1
Track name/Total                         : 24
Performer                                : Antonio Vivaldi
Composer                                 : Antonio Vivaldi
Genre                                    : Classical
Recorded date                            : 2004
iTunPGAP                                 : 0
iTunes_CDDB_1                            : 4611AA18+339339+24+150+16562+27328+47520+71604+80905+94587+118757+131250+147776+163458+173840+189095+200828+204540+218387+232751+242412+253047+269720+285051+298613+311306+322732
iTunes_CDDB_TrackNumber                  : 1
Audio
Format                                   : PCM
Format settings                          : Big
Bit rate mode                            : Constant
Bit rate                                 : 1 411.2 kb/s
Channel(s)                               : 2 channels
Sampling rate                            : 44.1 kHz
Bit depth                                : 16 bits
Stream size                              : 36.8 MiB (100%)
#16 2025-11-03 14:35:47
igorzwx
To convert a WAV file to FLAC while keeping the metadata
flac --keep-foreign-metadata input.wav -o output.flac
Bellezza Crudel is a small selection of delightful cantatas and concertos. Vivaldi's world is one of heartfelt, musical intensity, confirming the Venetians' adoration of theatrical beauty.
Antonio Lucio Vivaldi (1678-1741)
Cantate RV 679, 660, 664, 678 / Concerti RV 484, 441
Original source DXD (352.8kHz/24bit)
Producer Morten Lindberg, balance engineer and recording producer
2L - the Nordic sound
Audacious macOS, Homebrew repository:
"bit perfect" mode is already implemented and works,
"exclusive mode" is also implemented, but fails.
On macOS, both "bit perfect" and "exclusive mode" work with IINA player (from Homebrew), but above 96 kHz crappy resamplers are automatically enabled.
Hog mode (aka, exclusive mode) in CoreAudio refers to exclusive access to an audio output device, allowing a single application to lock the DAC (Digital-to-Analog Converter) for its exclusive use, thereby bypassing system-level software mixing and resampling and potentially improving audio quality by reducing processing overhead.
This mode is particularly relevant for achieving bit-perfect audio playback, where the audio stream is transmitted without software resampling or format conversion.
On macOS, hog mode is implemented through CoreAudio's exclusive access capabilities, enabling applications to take control of the audio device and avoid interference from other audio streams.
#17 2025-11-03 15:16:46
igorzwx
"Read-only file system"
Copy aiff files to your home directory and convert → wave → flac
A common strategy is to first extract the metadata using ffmpeg, perform the audio processing with sox, and then reapply the metadata to the final output file using ffmpeg.
Extract metadata from the original file to a text file using ffmpeg:
ffmpeg -i input.file -f ffmetadata metadata.txt
This saves global metadata. For more detailed stream-specific metadata, you might need a more complex ffmpeg command.
Process audio using sox:
sox input.file temp_output.file
Note that temp_output.file will have the default SoX comment and lack the original metadata.
Re-apply metadata to the final output file using ffmpeg:
ffmpeg -i temp_output.file -map_metadata 0 -metadata_global_key=value ... final_output.file
The -map_metadata 0 option tells ffmpeg to copy metadata from the first input file (which is temp_output.file in this case, but typically this step involves mapping from a third, metadata-only input file, which is more complex).
For simplicity, many users find it easier to work with a text file to set specific metadata fields manually using the -metadata option or a text file input.
#18 2025-11-05 15:58:58
kapqa
Hello ,
tried tis today once more;
it seemed to build, but thenb it would not start??
audacious -v
Audacious 4.5.1 (Devuan 6 Excalibur)
 audacious -VV
INFO ../audacious/src/audacious/dbus-server.cc:1132 [name_acquired]: Owned D-Bus name (org.atheme.audacious) on session bus.
INFO ../audacious/src/audacious/main.cc:400 [main]: No remote session; starting up.
INFO ../src/libaudcore/probe-buffer.cc:30 [ProbeBuffer]: <0x5558ace2f430> buffering enabled for /home/rich/.config/audacious/config
INFO ../src/libaudcore/vfs.cc:105 [VFSFile]: <0x5558ace2f430> open (mode r) /home/rich/.config/audacious/config
DEBUG ../src/libaudcore/vfs.cc:130 [fread]: <0x5558ace2f430> read 511 elements of size 1 = 242
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: gio
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: mms
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: neon
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: asx
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: asx3
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: audpl
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: cue
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: m3u
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: pls
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: xspf
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: xsf
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: aac-raw
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: amidi-plug
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: cdaudio-ng
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: console
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: madplug
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: openmpt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: psf2
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: opus
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: sid
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: metronom
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: tonegen
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: vtx
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: wavpack
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: flacng
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: modplug
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: vorbis
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: sndfile
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: ffaudio
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: bs2b
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: bitcrusher
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: crystalizer
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: compressor
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: echo
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: stereo
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: ladspa
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: silence-removal
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: speed-pitch
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: voice_removal
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: mixer
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: resample
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: sox-resampler
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: crossfade
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: background_music
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: pulse_audio
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: pipewire
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: alsa
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: sndio-ng
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: oss4
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: qtaudio
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: sdlout
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: filewriter
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: jack-ng
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: blur_scope-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: gl-spectrum-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: cairo-spectrum
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: qt-spectrum
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: vumeter-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: albumart-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: aosd
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: cd-menu-items
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: delete-files
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: notify
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: hotkey
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: qthotkey
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: lirc
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: lyrics-gtk
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: lyrics-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: mpris2
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: playlist-manager-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: scrobbler
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: search-tool-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: song_change
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: song-info-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: statusicon-qt
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: gtkui
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: qtui
INFO ../src/libaudcore/plugin-registry.cc:431 [operator()]: Plugin not found: skins-qt
INFO ../src/libaudcore/plugin-init.cc:140 [start_required]: Probing for output plugin.
ERROR ../src/libaudcore/plugin-init.cc:155 [start_required]: No output plugin found.
Aborted
is it because of this ?
sudo apt remove libasound2-plugins --version
apt 3.0.3devuan1 (amd64)
#19 2025-11-05 16:06:20
kapqa
Hello ,
audacious -v
 audacious -VV
Aborted
EDIT: have added to /DEBIAN/control all the dependencies found in substvars ... do i need to install some more packages to get it to function?
#20 2025-11-05 16:09:34
igorzwx
It cannot find audacious-plugins, because they were compiled with another "audacions"
OSS4 plugin will not be compiled, because you do not have OSS4 installed. It will newer find it.
The method:
1. Compile Audacious
2. Install Audacious
3, Compile Audacious-plugins.
4. Install them
Do not enable OSS4 in the config, because you do not have it installed.
#21 2025-11-05 16:16:53
kapqa
was about to ask if it should be installed since you told above "if installed".
well then i might correct the error, if still possible. there are many other error message.
:Actually during install found out, that Pipewire-Pulseaudio was still installed
(thanks to KDE possibly)
maybe therefore the error?
EDIT:
maybe the error is
shlibs:Depends=libaudcore5t64 (>= 4.4~beta1),
however
Get:1 http://deb.devuan.org/merged excalibur/main amd64 libaudcore5t64 amd64 4.4.2-1 [157 kB]
Unpacking audacious (4.5-devel-1) ...
dpkg: dependency problems prevent configuration of audacious:
audacious depends on libaudcore5t64 (>= 4.4~beta1); however:
  Package libaudcore5t64 is not installed.
  Version of libaudcore5t64 on system, provided by audacious:amd64, is <none>.
will leave for another day.
#22 2025-11-05 16:27:13
igorzwx
If you want to try OSS4, you may better try it on ArchLinux.
Arch Linux AUR repository
_https://aur.archlinux.org/packages/oss
Package Details: oss 4.2_2020-2
Package Actions
View PKGBUILD / View Changes
Download snapshot
Search wiki
Git Clone URL:    https://aur.archlinux.org/oss.git (read-only, click to copy)
Package Base:    oss
Description:    Open Sound System UNIX audio architecture
Upstream URL:    http://developer.opensound.com/
Keywords:    oss
Licenses:    GPL2
Conflicts:    libflashsupport-oss-git, libflashsupport-oss-nonfree, oss-git, oss-nonfree
Submitter:    keenerd
Maintainer:    alexdw
Last Packager:    alexdw
Better oss-git:
_https://aur.archlinux.org/packages/oss-git
Package Details: oss-git 5693e1e-2
Package Actions
Download snapshot
Search wiki
Git Clone URL:    https://aur.archlinux.org/oss-git.git (read-only, click to copy)
Package Base:    oss-git
Keywords:    oss
Licenses:    GPL2
Conflicts:    libflashsupport-oss, libflashsupport-oss-nonfree, oss, oss-nonfree
Provides:    oss
Submitter:    Nowaker
Maintainer:    seawright
Last Packager:    seawright
I used PKGBUILD of oss-git package.
Error was because they both should be recompiled correctly.
#23 2025-11-05 16:37:58
kapqa
well arch-linux nothing for me;
will leave it at that;
maybe will try once more another time;
bye.
EDIT: after second try, it compile&start. error was with libaudcore that i installed by default and made error afterwards (next of course OSS4 as mentioned)
#24 2025-11-05 17:29:59
igorzwx
libaudcore is inside Audacious
libaudcore is searching for "registered" plugins and cannot find them.
debdir/usr/lib/libaudcore.so.5.5.0
#25 2025-11-05 17:58:43
kapqa
now it starts
audacious -VV
INFO ../audacious/src/libaudcore/probe-buffer.cc:30 [ProbeBuffer]: <0x558c52b31050> buffering enabled for /home/rich/.config/audacious/config
INFO ../audacious/src/libaudcore/vfs.cc:105 [VFSFile]: <0x558c52b31050> open (mode r) /home/rich/.config/audacious/config
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x558c52b31050> read 511 elements of size 1 = 313
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Transport/mms.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Transport/neon.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Transport/gio.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Container/m3u.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Container/asx3.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Container/asx.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Container/pls.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Container/xspf.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Container/audpl.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Container/cue.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/amidi-plug.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/metronom.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/flacng.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/tonegen.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/madplug.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/aac-raw.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/vtx.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/sid.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/ffaudio.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/wavpack.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/psf2.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/openmpt.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/adplug.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/console.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/modplug.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/xsf.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/vorbis.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/opus.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/cdaudio-ng.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Input/sndfile.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Output/jack-ng.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Output/sndio-ng.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Output/sdlout.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Output/filewriter.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Output/alsa.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Output/oss4.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/background_music.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/mixer.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/stereo.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/echo.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/ladspa.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/voice_removal.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/bitcrusher.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/crossfade.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/bs2b.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/compressor.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/silence-removal.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/crystalizer.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/scrobbler.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/gtkui.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/hotkey.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/skins.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/aosd.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/albumart.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/notify.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/statusicon.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/cd-menu-items.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/lyrics-gtk.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/search-tool.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/playlist-manager.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/song_change.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/mpris2.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/lirc.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/General/delete-files.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/cairo-spectrum.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/gl-spectrum.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/blur_scope.so
INFO ../audacious/src/libaudcore/plugin-registry.cc:556 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/vumeter.so
INFO ../audacious/src/libaudcore/plugin-init.cc:133 [start_required]: Starting selected output plugin ALSA Output.
INFO ../audacious/src/libaudcore/plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/Output/alsa.so.
DEBUG ../audacious-plugins/src/alsa/alsa.cc:261 [init]: Initialize.
INFO ../audacious/src/libaudcore/probe-buffer.cc:30 [ProbeBuffer]: <0x558c52b94100> buffering enabled for /home/rich/.config/audacious/playlists/order
INFO ../audacious/src/libaudcore/vfs.cc:105 [VFSFile]: <0x558c52b94100> open (mode r) /home/rich/.config/audacious/playlists/order
DEBUG ../audacious/src/libaudcore/vfs.cc:258 [fsize]: <0x558c52b94100> size = 4
DEBUG ../audacious/src/libaudcore/vfs.cc:196 [ftell]: <0x558c52b94100> tell = 0
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x558c52b94100> read 4 elements of size 1 = 4
INFO ../audacious/src/libaudcore/playlist-files.cc:49 [playlist_load]: Loading playlist file:///home/rich/.config/audacious/playlists/1000.audpl.
INFO ../audacious/src/libaudcore/playlist-files.cc:62 [playlist_load]: Trying playlist plugin Audacious Playlists (audpl).
INFO ../audacious/src/libaudcore/plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/Container/audpl.so.
INFO ../audacious/src/libaudcore/probe-buffer.cc:30 [ProbeBuffer]: <0x558c52b66dc0> buffering enabled for file:///home/rich/.config/audacious/playlists/1000.audpl
INFO ../audacious/src/libaudcore/vfs.cc:105 [VFSFile]: <0x558c52b66dc0> open (mode r) file:///home/rich/.config/audacious/playlists/1000.audpl
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x558c52b66dc0> read 511 elements of size 1 = 349
INFO ../audacious/src/libaudcore/plugin-init.cc:188 [start_plugins]: Starting Audio CD Menu Items.
INFO ../audacious/src/libaudcore/plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/General/cd-menu-items.so.
INFO ../audacious/src/libaudcore/probe.cc:89 [aud_file_find_decoder]: Probing file:///home/rich/Test/Dave%20Seaman%20-%20Renaissance%20Awakening%20CD1/Dave%20Seaman%20-%20Bias.flac.
INFO ../audacious/src/libaudcore/probe.cc:115 [aud_file_find_decoder]: Matched FLAC Decoder by extension.
INFO ../audacious/src/libaudcore/plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/Input/flacng.so.
INFO ../audacious/src/libaudcore/plugin-init.cc:188 [start_plugins]: Starting MPRIS 2 Server.
INFO ../audacious/src/libaudcore/plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/General/mpris2.so.
INFO ../audacious/src/libaudcore/probe-buffer.cc:30 [ProbeBuffer]: <0x7f7c20002060> buffering enabled for file:///home/rich/Test/Dave%20Seaman%20-%20Renaissance%20Awakening%20CD1/Dave%20Seaman%20-%20Bias.flac
INFO ../audacious/src/libaudcore/vfs.cc:105 [VFSFile]: <0x7f7c20002060> open (mode r) file:///home/rich/Test/Dave%20Seaman%20-%20Renaissance%20Awakening%20CD1/Dave%20Seaman%20-%20Bias.flac
DEBUG ../audacious-plugins/src/flac/metadata.cc:286 [read_tag]: Probe for tuple.
DEBUG ../audacious/src/libaudcore/vfs.cc:171 [fseek]: <0x7f7c20002060> seek to 0 from beginning
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 4 elements of size 1 = 4
DEBUG ../audacious/src/libaudcore/vfs.cc:196 [ftell]: <0x7f7c20002060> tell = 4
DEBUG ../audacious-plugins/src/flac/metadata.cc:85 [tell_cb]: Current position: 4
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 34 elements of size 1 = 34
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 18 elements of size 1 = 18
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 32 elements of size 1 = 32
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 14 elements of size 1 = 14
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 9 elements of size 1 = 9
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 24 elements of size 1 = 24
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 10 elements of size 1 = 10
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 13 elements of size 1 = 13
DEBUG ../audacious/src/libaudcore/vfs.cc:171 [fseek]: <0x7f7c20002060> seek to 8066 from current
DEBUG ../audacious/src/libaudcore/vfs.cc:196 [ftell]: <0x7f7c20002060> tell = 8934
DEBUG ../audacious-plugins/src/flac/metadata.cc:85 [tell_cb]: Current position: 8934
DEBUG ../audacious-plugins/src/flac/metadata.cc:353 [read_tag]: Stream length: 351000 seconds
DEBUG ../audacious/src/libaudcore/vfs.cc:258 [fsize]: <0x7f7c20002060> size = 39092987
DEBUG ../audacious-plugins/src/flac/metadata.cc:320 [read_tag]: Vorbis comment contains 6 fields
DEBUG ../audacious-plugins/src/flac/metadata.cc:321 [read_tag]: Vendor string: reference libFLAC 1.5.0 20250211
DEBUG ../audacious-plugins/src/flac/metadata.cc:240 [parse_comment]: Found key ALBUM <Renaissance: Awakening CD1>
DEBUG ../audacious-plugins/src/flac/metadata.cc:240 [parse_comment]: Found key ARTIST <Kinesis>
DEBUG ../audacious-plugins/src/flac/metadata.cc:240 [parse_comment]: Found key DATE <2000>
DEBUG ../audacious-plugins/src/flac/metadata.cc:240 [parse_comment]: Found key GENRE <Progressive Trance>
DEBUG ../audacious-plugins/src/flac/metadata.cc:240 [parse_comment]: Found key TITLE <Bias>
DEBUG ../audacious-plugins/src/flac/metadata.cc:240 [parse_comment]: Found key TRACKNUMBER <4>
DEBUG ../audacious/src/libaudcore/vfs.cc:212 [feof]: <0x7f7c20002060> eof = no
DEBUG ../audacious/src/libaudcore/vfs.cc:130 [fread]: <0x7f7c20002060> read 8192 elements of size 1 = 8192
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:153 [metadata_callback]: total_samples=15514380
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:156 [metadata_callback]: bits_per_sample=16
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:159 [metadata_callback]: channels=2
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:162 [metadata_callback]: sample_rate=44100
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:171 [metadata_callback]: bitrate=888982
DEBUG ../audacious/src/libaudcore/vfs.cc:196 [ftell]: <0x7f7c20002060> tell = 16384
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:80 [tell_callback]: Current position: 16384
INFO ../audacious/src/libaudcore/plugin-init.cc:133 [start_required]: Starting selected interface plugin GTK Interface.
INFO ../audacious/src/libaudcore/plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/General/gtkui.so.
DEBUG ../audacious/src/libaudcore/effect.cc:46 [effect_start]: Starting effects.
INFO ../audacious/src/libaudcore/output.cc:270 [setup_output]: Setup output, format 0, 2 channels, 44100 Hz.
INFO ../audacious-plugins/src/alsa/alsa.cc:331 [open_audio]: Opening PCM device default for FLOAT_LE, 2 channels, 44100 Hz.
INFO ../audacious/src/libaudcore/interface.cc:70 [interface_load]: Loading GTK Interface.
Rates:  44100 --> 192000 (J: 0.00%, T: FFT, W: Vorbis)
Ok.
INFO ../audacious-plugins/src/alsa/alsa.cc:365 [open_audio]: Buffer: hardware 160 ms, software 340 ms, period 40 ms.
DEBUG ../audacious-plugins/src/alsa/alsa.cc:224 [pump_start]: Starting pump.
DEBUG ../audacious-plugins/src/alsa/alsa.cc:527 [pause]: Pause.
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:110 [length_callback]: Stream length is 39092987 bytes
DEBUG ../audacious/src/libaudcore/vfs.cc:171 [fseek]: <0x7f7c20002060> seek to 856645 from beginning
INFO ../audacious/src/libaudcore/probe-buffer.cc:50 [release_buffer]: <0x7f7c20002060> buffering disabled for file:///home/rich/Test/Dave%20Seaman%20-%20Renaissance%20Awakening%20CD1/Dave%20Seaman%20-%20Bias.flac
DEBUG ../audacious/src/libaudcore/vfs.cc:196 [ftell]: <0x7f7c20002060> tell = 864837
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:80 [tell_callback]: Current position: 864837
DEBUG ../audacious/src/libaudcore/vfs.cc:196 [ftell]: <0x7f7c20002060> tell = 873029
DEBUG ../audacious-plugins/src/flac/seekable_stream_callbacks.cc:80 [tell_callback]: Current position: 873029
DEBUG ../audacious-plugins/src/gtkui/ui_gtk.cc:967 [init]: hooks associate
DEBUG ../audacious-plugins/src/gtkui/ui_gtk.cc:970 [init]: playlist associate
remeins the issue which format to use for CD library
.aiff which is hardly supported /but all in one with metadate (can also burn CD of it for backup)
.wav (which has hardly matedate)
.wav + flac (which is better) but more space
.flac only (which is good, but not supported by itunes)(seem not supported by rhythmbox-daap as of november 2025)
for audacious, flac seem preferable.
