#1 2025-05-07 01:52:20
igorzwx
The road to freedom
Knowledge and ignorance—
        a man who knows them both together,
    Passes beyond death by ignorance,
        and by knowledge attains immortality.
            Isha Upanishad, Verse 12
The road to freedom is short and straightforward. Read PKGBUILs of AUR packages, and do the same on Devuan.
It doesn't always work. Sometimes it is much better with Debian sources, if you know the secret commands. Debian packaging is a sacred ritual, not a secular one. It requires initiation into secret knowledge. If you are not initiated, you are doomed to dwell in ignorance and doubt. In essence, initiation is a rite of passage marking entrance into a sort of esoteric society. In particular, it signifies a transformation in which the initiate is 'reborn' into a new role.
Step 1: Install a secret package
sudo apt-get install packaging-dev
Step 2: Download the source you need. For example:
Debian testing (Trixie)
_https://packages.debian.org/source/testing/gnuplot
Source Package: gnuplot (6.0.2+dfsg1-1)
Debian Package Source Repository (Browsable)
https://salsa.debian.org/science-team/gnuplot
mkdir BUILD_GIT
cd BUILD_GIT
git clone https://salsa.debian.org/science-team/gnuplot.git --depth 1
$ ls
gnuplot
$ du -sh *
17M	gnuplot
Step 3: Install "Build-Depends"
cd gnuplot
mk-build-deps
$ ls *.deb
gnuplot-build-deps_6.0.2+dfsg1-1_all.deb
Install gnuplot-build-deps*.deb
sudo dpkg -i gnuplot-build-deps_6.0.2+dfsg1-1_all.deb
You may notice a problem:
$ sudo dpkg -i gnuplot-build-deps_6.0.2+dfsg1-1_all.deb
dpkg: error processing package gnuplot-build-deps (--install):
Fix it with a magic command:
sudo apt -f install
It may remove "emacs-gtk" and install "emacs-nox" instead. You can reinstall it later, or remove them both.
Emacs - Installation options on Linux and Lucid Emacs vs. XEmacs
_https://youtu.be/ugFtz7XOOWU?t=25s
$ mv -v gnuplot-build-deps_6.0.2+dfsg1-1_all.deb ../
Step 4: Prepare the source
Execute secret commands:
export QUILT_PATCHES=debian/patches
quilt push -a
The output on terminal should look like this:
$ quilt push -a
Applying patch 04_fix_libexecdir.diff
patching file src/Makefile.am
Applying patch 50_no-webp_figures-in-documentation.patch
patching file docs/Makefile.am
Now at patch 50_no-webp_figures-in-documentation.patch
Step 5: Build GnuPlot
dpkg-buildpackage -b
$ ls -1 ../*.deb
../gnuplot_6.0.2+dfsg1-1_all.deb
../gnuplot-build-deps_6.0.2+dfsg1-1_all.deb
../gnuplot-data_6.0.2+dfsg1-1_all.deb
../gnuplot-doc_6.0.2+dfsg1-1_all.deb
../gnuplot-nox_6.0.2+dfsg1-1_amd64.deb
../gnuplot-nox-dbgsym_6.0.2+dfsg1-1_amd64.deb
../gnuplot-qt_6.0.2+dfsg1-1_amd64.deb
../gnuplot-qt-dbgsym_6.0.2+dfsg1-1_amd64.deb
../gnuplot-x11_6.0.2+dfsg1-1_amd64.deb
../gnuplot-x11-dbgsym_6.0.2+dfsg1-1_amd64.deb
Step 6: Install GnuPlot
cd ../
sudo dpkg -i gnuplot_6.0.2+dfsg1-1_all.deb gnuplot-data_6.0.2+dfsg1-1_all.deb gnuplot-qt_6.0.2+dfsg1-1_amd64.deb
Step 7: Test
You can test GnuPlot with Maxima
$ maxima
(%i1) plot2d([tanh(20*sin(x))], [x,-10*%pi,10*%pi], [y,-1.1,1.1], [plot_format, gnuplot])$
(%i3) quit();
You can export plots from GnuPlot window to SVG format. It works with gnuplot-qt
Click on "Export" icon (the top left corner of GnuPlot window), and select "Export to SVG" in drop down menu.
Doing Graphics with Maxima - Maxima Tutorial
http://www.bildungsgueter.de/MaximaEN/Pages/GraphicsSurvey01.htm
#2 2025-06-29 23:16:53
tux_99
Re: The road to freedom
Hi Igor, unfortunaltely already the first step doesn't work for me:
root@vm:~# apt-get install packaging-dev
E: Unable to locate package packaging-dev
root@vm:~#
I'm on Excalibur, does this guide maybe not apply to Excalibur?
“Either the users control the program – or the program controls the users” Richard Stallman
#3 2025-06-29 23:48:38
igorzwx
It is not a problem. It is a meta-package.
You can install everything you need manually
➤ apt info packaging-dev
Package: packaging-dev
Depends: build-essential, debhelper, devscripts, dput-ng | dput | dupload, lintian, sbuild | cowbuilder | pbuilder, quilt
Recommends: apt-file, autoconf, automake, autopkgtest, autotools-dev, bzr-debian, cdbs, cmake, debian-policy, developers-reference | developers-reference-de | developers-reference-fr | developers-reference-ja, dh-autoreconf, dh-make, git-buildpackage, gnome-pkg-tools, gnupg, libtool, piuparts, pkg-kde-tools, svn-buildpackage
Suggests: mercurial-buildpackage
You need "Depends" and "Recommends".
Do not forget quilt
sudo apt install quilt
➤ dpkg -l | grep dput
ii  dput             1.1.3           all          Debian package upload tool
➤ dpkg -l | grep sbuild
ii  libsbuild-perl         0.85.0            all          Library for building Debian binary packages from Debian sources
ii  sbuild                 0.85.0            all          Tool for building Debian binary packages from Debian sources
The available Build-Deps for gtk3-nocsd can be installed with "apt build-dep"
apt build-dep gtk3-nocsd --simulate
sudo apt build-dep gtk3-nocsd
