#1 2025-03-11 01:17:08
robert-e
[SOLVED] Thinkpad L512 Chimaera to Daedalus (and return)
About a year ago, I took a notion to try out Daedalus, and did a distribution
upgrade following the advice on this board.  Problems arose right off, and I
then tried a net install.  There were still problems, mainly with crashes when
quiting both VLC and Audacity, requiring a reboot. I suspected video problems.
So I clonezilla'd back to Chimaera, and locked the video drivers, mesa, ffmpeg,
and the kernel from being updated.  All was well for about a year.  Then
yesterday, I thought that perhaps Daedalus might have any bugs worked out by
now, so I again backed up Chimaera, and did a net install of Daedalus.  Well,
it still has problems for me.  With only firefox running, if a clicked on a
link, it dumped me to a logon prompt.  With only pluma and mahjong running, it
would sometimes also dump to a logon screen.  So I am now back on Chimaera for
the time being.
I am posting the output of lspci.  Note that I am not looking for help, but
am interested if anyone else has this sort of experience?
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 06)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1c.5 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 6 (rev 06)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation HM55 Chipset LPC Interface Controller (rev 06)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 06)
02:00.0 System peripheral: JMicron Technology Corp. SD/MMC Host Controller (rev 20)
02:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller (rev 20)
02:00.3 System peripheral: JMicron Technology Corp. MS Host Controller (rev 20)
02:00.4 System peripheral: JMicron Technology Corp. xD Host Controller (rev 20)
03:00.0 Network controller: Intel Corporation Centrino Advanced-N 6200 (rev 35)
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03)
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
ff:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
Best regards
Bob
edit..I tried to use code block but that did not work out.
B
#2 2025-03-14 16:01:36
robert-e
Re: [SOLVED] Thinkpad L512 Chimaera to Daedalus (and return)
Found the problem. I installed the non-free-firmware package   firmware-misc-nonfree  and the crashing has gone away for the last
24 hours of testing.
I will mark this as solved.
Bob
