I would like to install the lastest version of wireguard* on Chimaera.
wireguard as been incorporated into Linux kernel since version 5.6
cat /boot/config-5.10.0-9-amd64 | grep WIREGUARD
CONFIG_WIREGUARD=m
# CONFIG_WIREGUARD_DEBUG is not set
ok so my kernel have wireguard as module.
So I presumed I had only need an interface to interact with wireguard.
but
apt show wireguard
Version: 1.0.2021 02 23-1
Depends: wireguard-modules (>= 0.0.20191219) | wireguard-dkms (>= 0.0.20200121-2), wireguard-tools (>= 1.0.20210223-1)
apt show wireguard-modules
Package: wireguard-modules
State: not a real package (virtual)
N: Can't select candidate version from package wireguard-modules as it has no candidate
N: Can't select versions from package 'wireguard-modules' as it is purely virtual
N: No packages found
I'm lost here.
apt show wireguard-dkms
This package uses DKMS to automatically build the wireguard kernel module.
I supposes this is required for system that do not have the CONFIG_WIREGUARD ?
apt show wireguard-tools
I see on https://www.wireguard.com/install/#debian-module-tools that the lastest version of tools is v1.0.2021 09 14
Is this version will be compatible with Chimaera ? Is yes, how can I install it ?
Linux noob, plz be kind ![]()
I have wireguard installed on chimaera. Only "wireguard" and "wireguard-tools" are installed:
root@localhost:/home/user# apt policy wireguard*
wireguard-dkms:
Installed: (none)
Candidate: 1.0.20210219-1
Version table:
1.0.20210219-1 500
500 http://gnlug.org/pub/devuan/merged chimaera/main amd64 Packages
wireguard-tools:
Installed: 1.0.20210223-1
Candidate: 1.0.20210223-1
Version table:
*** 1.0.20210223-1 500
100 /var/lib/dpkg/status
wireguard-modules:
Installed: (none)
Candidate: (none)
Version table:
wireguard:
Version table:
100 /var/lib/dpkg/statusI "think" I installed it with
apt install wireguard
Wireguard works fine. There are many good tutorials on the web about setting up the keys after installing.
I think the wireguard-dkms and wireguard-modules packages are for the older packages that were before wireguard was included in the kernel.
Thank you nixer
We can see that the candidate version for wireguard-tools is 1.0.2021 02 23-1
The latest for debian is 1.0.2021 09 14
In Daedalus the candidate version is 1.0.2021 09 14
So I was wondering if we could for example update the /etc/apt/sources to
deb http://deb.devuan.org/merged daedalus main
deb http://deb.devuan.org/merged daedalus-updates main
deb http://deb.devuan.org/merged daedalus-security mainToo get this latest version of if this will not cause problems ?
Thanks
I would not do that. I would use the current version shown for the chimaera release. Generally speaking, you should not mix "newer" versions of a program unless they were found in the "backports" section of that release cycle. Even this could be considered for more advanced users. I would use the version of wireguard for chimaera, as shown in my first post above. It works fine and it installs and configures the same way.
I have some links to the tutorials that I used to configure wireguard, but there are many guides that can be found on the internet.
