#1 2025-01-11 12:11:51
SpongeBOB
boot on LUKS encrypted drive ( initramfs Vs initrd ) ?
Hi everyone,
I've installed a Devuan rpi version ( 2025-01-10-0317_rpi-4-devuan-daedalus-6.1.93-arm64-ext4.zip ) on my Rapsberry pi 4.
I've recompiled the https://github.com/raspberrypi/linux kernel ( 6.1.93 ) to support some additional cryptographic algorithm.
I'm following the LUKS on Raspberry Pi 2021 guide
That explain step by step how enable LUKS on raspberry pi.
But the guide use initramfs and Devuan rpi seem to use initrd
So the question is: should I migrate to initramfs ? and how check whats is inside my current initrd ?
or keep-up with initrd but then how insert the necessary to enable LUKS drive to be mounted by it ( initrd ) ?
Thanks..
#2 2025-01-12 15:06:00
SpongeBOB
Re: boot on LUKS encrypted drive ( initramfs Vs initrd ) ?
I've did
root: file /boot/broadcom/initrd.gz
initrd.gz: Zstandard compressed data ....
root: unmkinitramfs /boot/broadcom/initrd.gz Extracted/
# data where extracted to Extracted/
# but I go few error like:
# cpio: cannot link usr/sbin/vconfig to usr/sbin/watchdog: Operation not permitted
So the initrd.gz file is actually an initramfs file smile it was misleading.
But now I have a problem with mkinitramfs :'(
https://programming.dev/post/23945016
You can reply here , i'll merge both thread smile
Thanks
#3 2025-01-17 16:12:38
c0rnelius
It is just a script that creates a copy of the initramfs that is generated, so there is a static name for the config.txt to use.
/etc/initramfs/post-update.d/99-initrd
