#1 2025-01-05 15:56:42
wingcommander1999
[HowTo]Install OpenRGB based on AMD chipsets.
After a long time on Linux Mint Debian Edition, I come back to Devuan.
Before proposing my new HowTo, I wish you lots of good things for this new year 2025.
This HowTo based on the OpenRGB Wiki/Gitlab and other sources allows you to bring up all the RGB components of your computer, whether you are on an AMD or Intel chipset.
I. Installation, configuration and activation of I2C modules.
First step we need to dowload the I2C-Tools, open an terminal in Root:
apt install i2c-tools - y
Second step load the i2c module for AMD chipset:
modprobe i2c-dev
Add the user to the i2c group:
usermod $USER -aG i2c
Third step edit and load the i2c driver for your AMD chipset:
nano /etc/modules-load.d/i2c.conf
Add the line below to the file:
i2c-piix4
Load the i2c-piix4 module:
modprobe i2c-piix4
Now all necessary modules and driver are loaded.
II. Patching the kernel & UDEV rules.
Advice:Do not patch the kernel if you don't have a Gigabyte/Aorus motherboard.
Some Gigabyte/Aorus motherboards have an ACPI conflict with the SMBus controller, being on a Gigabyte motherboard I am impacted by this conflict.
First step edit the grub:
nano /etc/default/grub
Add the line below to your grub file:
GRUB_CMDLINE_LINUX="acpi_enforce_resources=lax"
To load the added command line we have to reload the grub and re-generate the grub.cfg file:
grub-mkconfig -o /boot/grub/grub.cfg
Second step download and install the UDEV rules:
wget https://gitlab.com/CalcProgrammer1/OpenRGB/-/raw/ca3c2ad54188c604c7626136ceda574e9fde3bc0/60-openrgb.rules?inline=false
Copy the file to the UDEV rules folder:
cp -R 60-openrgb.rules /etc/udev/rules.d/
If you installed openRGB before configuring for chipset support, you will get an error message telling you that there can only be one configuration file in the UDEV rules.
For this we need to remove one UDEV rules file at the location below:
cd /usr/lib/udev/rules.d
rm -R 60-openrgb.rules
Third step reload the UDEV rules && reboot:
sudo udevadm control --reload-rules && sudo udevadm trigger
reboot
At this point you can install OpenRGB, the application once launched will show all your RGB components.
Enjoy!
Sources:
OpenRGB Wiki
Grub editing
OpenRGB UDEV rules file
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
#2 2025-01-05 18:08:55
RedGreen925
Re: [HowTo]Install OpenRGB based on AMD chipsets.
Couple of points you are not patching the kernel, you are passing it a boot option through grub. If you patch a kernel, a re-compile then installation of new version is necessary where you boot with the patched to see the changes. For the grub there is no need to make a new file the update-grub command run as root or normal user using sudo at the front of it will have the option used in the grub.cfg upon the next boot. And now I look at that part again you do not mention you need to reboot for that change to take place setting the option and having the  grub file updated does nothing to have it used, only booting the kernel with the updated/new file has it take effect. Other than those items a reasonable effort at it.
