#1 2024-12-06 14:37:11
SpongeBOB
Supported encryption AES, Xchacha
I would like to use LUKS on the rootfs aka /
when I do cat /proc/crypto I don't find AES nor xchacha :'(
So I assume I'll have to recompile a kernel ?
Any easy way to do it for Raspberry pi 4 ?
Thanks.
#2 2024-12-06 17:58:58
SpongeBOB
Re: Supported encryption AES, Xchacha
For those who are interested I've found this https://www.raspberrypi.com/documentati … ernel.html
But Its not going deep, especially for the .config file or make menuconfig
If you have any advice, resources I'm all ears smile
BTW is the .config used to generate the kernel for the Devuan RPI is located into the /boot ? I cant find it...
