Pages: 1
Just wanted to report that ascii seems stable and usable at the moment. I upgraded from jessie to ascii and all went well, with the addition of a manual upgrade of xconf (it appears to be broken in ascii).
Proceedure:
change all jessie to ascii in /etc/apt/sources.list
=>apt-get update
=>apt-get dist-upgrade
then I manually installed an xfconf package
=>dpkg -i xfconf_4.12.0-0mx150+1_amd64.deb
I believe Devuan xfconf problem has something to do with d-bus. I chose to use an xfconf package from MX Linux, because I have it installed on another pc; probably most any distro package would work.
Its nice having a more current system, much improved; xfce 4.12, kernel 4.x, libreoffice 5.2...., have had no problems.
Pages: 1
