#1 2024-10-11 15:59:55
edsonwolf
[SOLVED] not suspend devuan excalibur
Good afternoon. I am using devuan excalibur, when tutto suspend el suspension but does not turn off all the same in devuan daedalus. Any feedback?
When I check to suspend in the suspend option in xfce4, it suspends but does not turn off the source.
And by command the same thing
echo "mem" > /sys/power/state
#2 2024-10-11 18:08:00
edsonwolf
Re: [SOLVED] not suspend devuan excalibur
https://dev1galaxy.org/viewtopic.php?pid=51609#p51609
I found the answer in this thread. Thanks
Just did this and restart on :
/etc / init.d / elogind restart
