#1 2024-10-09 18:13:01
Alverstone
upower: very broken dependencies
upower requires up to date version of libgudev-1.0.0. No apparent error here, but when trying to start /usr/libexec/upowerd you get
/usr/libexec/upowerd: /lib/x86_64-linux-gnu/libudev.so.1: version `LIBUDEV_247' not found (required by /lib/x86_64-linux-gnu/libgudev-1.0.so.0)
The current solution to this kind of error is installing older libgudev-1.0.0 from daedalus, but it conflicts with upower, because it wants the new libgudev-1.0.0.
Why does it happen at all? Any hopes it gets resolved? This is Devuan specific thing AFAIK, see https://forums.debian.net/viewtopic.php?t=155394
#2 2024-10-09 19:50:07
Re: upower: very broken dependencies
Is this in Daedalus [stable] or Excalibur [testing]?
Because if it is Excalibur [testing], the answer to your question is in the suite's denomination.
ie: this part -> [testing].
Of course.
It will be unoubtedly solved by the time Excalibur [testing] becomes Excalibur [stable].
Maybe even before that, no way of telling.
Testing is an arduous process which takes both time and manpower, both rather in short supply here at Dev1.
Alverstone wrote:
... Devuan specific thing ...
No.
It is just part of/how the release cycle of any non-rolling Linux distribution works.
ie: it is ready when it is ready.
#3 2024-10-11 05:17:46
pcalvert
If you are indeed using Excalibur, then this may be a good example of why many people choose to run unstable (Ceres) instead of testing. Either that, or they run a mixed testing/unstable system -- testing with some packages pulled (as needed) from unstable. The latter approach is the one I would probably use if I were inclined to run a "rolling" system, but didn't want to switch to a totally different distro (e.g., Arch Linux).
Another one is called Luxxle.
#4 2024-10-11 18:00:52
I can not reproduce the error. upowerd on my excalibur works.
