#1 2024-09-15 23:14:24
backport question,
are there backports for newer kernels in it?
Like 6.10 instead of 6.1 for example.
#2 2024-09-16 08:05:02
Re: backport question,
Yes, I am running 6.10 now on Daedalus.
#3 2024-09-16 20:25:22
@rolfie that sounds good. My current kernel is screwing up a bit.
#4 2024-09-16 21:19:24
Hi, I also am using 6.10.6+bpo (unsigned) 64bit kernel
I can't remember why, but I generally use bpo kernels.
#5 2024-09-16 21:37:08
#6 2024-09-23 05:31:48
I tried the kernel, seems to have not fixed my problem. Although, I had 2 problems, one with my alt keys was resolved in a rather weird way anyhow.
Some kind of configuration oops had swapped my alt and fn keys. But now it is back to normal.
So now only 1 issue, an expansion slot that doesn't work.
