#1 2024-09-12 21:14:02
metala
[HOW-TO] Prevent laptop suspend / sleep on lid close
The Problem:
I have installed fresh Devuan 5 without X server on an 2011-ish laptop. However, when I closed the lid of the "soon to be server" laptop, the device went to sleep.
The Solution:
1. Edit /etc/elogind/logind.conf
2. Uncomment and set the following parameters:
HandleLidSwitch=ignore
HandleLidSwitchExternalPower=ignore
HandleLidSwitchDocked=ignore
3. Reload elogind:
# service elogind reload
Note. I did it few months ago and I am not sure if the elogind reload helped or I needed a restart. service elogind reload works fine.
#2 2024-09-16 14:14:02
JWM-Kit
Re: [HOW-TO] Prevent laptop suspend / sleep on lid close
I've configured many laptops just as you have, and it works well. The only difference is I just reboot instead of reloading the services.
It may also be helpful to change the behavior of the power key so it does not trigger sleep
I do this by adding the following to logind.conf
HandlePowerKey=poweroff
PowerKeyIgnoreInhibited=yes
