#1 2024-08-29 23:50:22
rdav
[SOLVED] Suspend to Ram logs out user in Excalibur/Ceres on waking up
Hi All,
When I use suspend to ram via pm-suspend, then computer goes to sleep nicely.
When I go to restart, I see X gui briefly with the desktop, then promptly get logged out and back to login screen.
I have done the steps outlined in https://dev1galaxy.org/viewtopic.php?id=6740
however this is still occuring.
Thanks in advance to your suggestions!
#2 2024-08-30 09:06:10
Re: [SOLVED] Suspend to Ram logs out user in Excalibur/Ceres on waking up
had a similar experience when my active partition had very little free space left. don't remember how "little" the actual amount was. as always, your mileage may vary.
#3 2024-08-30 14:30:09
rdav
Hi stargate-sg1-cheyenne,
This happening when I suspend to ram with "pm-suspend".
I haven't tried suspend to disk "pm-hibernate", though there is a enough disk free at 106G.
I'll try "pm-hibernate" and report back,
cheers!
#4 2024-10-01 09:15:00
rdav
Posting this as "solved" in as much my solution was to roll back from Testing/Unstable to Stable.
After this and other annoying dramas, eventually I relented, dumped Excalibur/Ceres and went back to Daedalus (stable).
Took a day over the weekend, and another hour installing missing packages.
Has been worth it.
Suspend now works which is great, what I didn't expect is the lappie is now running 10-20C cooler in Daedalus than in Exccalibur/Ceres! ;-)
