#1 2024-07-31 07:19:03
tyrlak
NetworkManager and drive access fail
A while back I was writing in a post on the forum that I couldn't get the screen back on after hibernation. This was solved by getting linux-firmware repo and copy amdgpu to /lib/firmware. However the problem restarted after a while and after hibernation I was forced to restart the computer to get back in again.
Today after starting and login I could not access any network. When trying to disconnect (I cannot select 'available networks') I get:
org.free desktop.NetworkManager.network-control request failed: not authorized
What I tried:
- Restart
- Add user to netdev
- Restart NetworkManager
sudo service network-manager restart
After that I could select 'available networks'. When selecting a network I get: Not authorized to control networking
When checking access generally I noticed that I also am no longer authorized to mount a drive.
Do anyone have any idea from where these issues originates and which steps I could take to fix it?
#2 2024-07-31 07:48:22
tyrlak
Re: NetworkManager and drive access fail
If I do:
sudo nmcli connection up <uuid>
I can connect though it shouldn't work like this.
#3 2024-07-31 08:23:11
soren
Its generally a good idea to let the forum know what your system specs are,what version of devuan and what desktop environment etc. It sounds like you have a polkit issue, is polkit installed?
#4 2024-07-31 09:32:26
tyrlak
I should have, sry abt that and ty soren for reminding me in such a kind way. I have Daedalus 5.0 and I'm using xfce desktop environment.
#5 2024-07-31 09:37:57
tyrlak
I don't have polkit. It is used to give user permission for different services, such as network management?
I don't have experience using this and I'm researching to find resources and learn about it. If you have any proposal for a good resource I'd be grateful.
#6 2024-07-31 10:42:21
alexkemp
A quick n easy way to show system setup to fulfil soren's advice is the terminal command neofetch:
$ neofetch
   ..,,;;;::;,..                   alexk@ng3
           `':ddd;:,.              ---------
                 `'dPPd:,.         OS: Devuan GNU/Linux 5 (daedalus) x86_64
                     `:b$$b`.      Model: 90BJ008CUK Lenovo H30-05
                        'P$$$d`    Kernel: 6.1.0-23-amd64
                         .$$$$$`   Uptime: 7 days, 2 hours, 22 mins
                         ;$$$$$P   Packages: 3167 (dpkg)
                      .:P$$$$$$`   Shell: bash 5.2.15
                  .,:b$$$$$$$;'    Resolution: 1920x1080
             .,:dP$$$$$$$$b:'      DE: Xfce 4.18
      .,:;db$$$$$$$$$$Pd'`         WM: Xfwm4
 ,db$$$$$$$$$$$$$$b:'`             WM Theme: Default
:$$$$$$$$$$$$b:'`                  Theme: Clearlooks-Phenix-Sapphire [GTK2]
 `$$$$$bd:''`                      Icons: oxygen [GTK2]
   `'''`                           Terminal: xfce4-terminal
                                   Terminal Font: Monospace 12
                                   CPU: AMD A8-7410 APU with AMD Radeon R5 Grap
                                   GPU: AMD ATI Radeon R4/R5 Graphics
                                   Memory: 3496MiB / 7356MiB
(in life much more colourful than the above)
#7 2024-07-31 11:10:01
tyrlak
Alexkemp, thank you. I appreciate your proposal. It was helpful to get the exact information. All information is a bit privacy intrusive for me. Here is what I think matters. Tell me if anything is missing
DE: Xfce 4.18
#8 2024-07-31 16:23:58
Check what groups you are in (running id or groups will tell you). That's always worth checking when you get told you are not authorized to do something.
If you find you need to be in one or more groups then usermod -a -G group1,group2 $USER should do the job (see man usermod for details).
If /etc/group seems damaged then sudo grpck would be a good idea. But I hope you don't need to do that (or sudo pwck to check /etc/passwd etc).
#9 2024-07-31 22:59:10
soren
@trylak
As per chris2be8 advice, i think you need to also be in the "plugdev" group as well as the "netdev" group.
Im not sure how you would manage networkmanager without polkit, its probably best to install polkitd and reboot.
sudo gpasswd -a tyrlak plugdev
sudo apt install polkitd
reboot
#10 2024-08-05 08:56:05
Findgreen
Polkit is  essential component in Linux systems that allows for permission management. Without it many operations including network management can be challenging. I agree with chris2be8 that it's good to be in the plugdev and netdev groups. I also recommend checking ou  Polkit documentation to understand its functionality bettersmile
