Hi!
I am reading invoke-rc.d: could not determine current runlevel already on my last install
and faceing it at my current install again. So I have two setups with this error and I do not
know, where to look for it.
I am not a specialist, but one mentioned (together with other hints):
The service’s startup script is not working properly.
https://hatchjs.com/invoke-rc-d-could-n … -runlevel/
The message is in bootlog and appears between:
Starting Setting kernel variables: sysctl.
Starting: AppArmorLoading AppArmor profiles...done.
Configuring network interfaces...invoke-rc.d: could not determine current runlevel
done.
Cleaning up temporary files....And a mysterious DOT in a single line - WHO logs????
The network is ok.
The first computer does not start my LXC (container) which is set to autostart.
At this box, I tracked the occurence better (and I am just in an eraly state after
the networked setup) and it appears, after I installed some firmware packages
(amd64-microcode firmware-amd-graphics firmware-linux firmware-linux-free firmware-linux-nonfree firmware-realtek)
But the error persists if I remove (including purge) the packages and reboot.
For the first box, the problem may cause this:
$ ls /var/lib/lxcfs
ls: cannot access '/var/lib/lxcfs/sys': Input/output error
ls: cannot access '/var/lib/lxcfs/cgroup': Input/output error
total 0
dr-xr-xr-x 2 root root 0 2024-07-19 09:23:27 proc/
?????????? ? ? ? ? ? cgroup
?????????? ? ? ? ? ? sysI am using fresh network install of devuan daedalus with kernel 6.1.0-23-amd64
Can someone help?
Thanks,
Manfred
Heyo, start by checking the runlevel of your runlevel settings and check your init scripts in /etc/init.d/ for any incorrect settings. Might want to check into your boot logs with dmesg and journalctl -xb too. then check /etc/lxc/auto and check the LXC logs in /var/log/lxc/ to verify that your LXC container's autostart settings are correct. Re-configuring all packages with dpkg-reconfigure -a may also help... If the problem persists, hit up the #devuan IRC channel or something... anyways, good luck ![]()
P.s. In last resort, reinstall the firmware packages one by one to see if any of them are the culprits ![]()
Hey, it's lynchian9.
Feel free to reach out via email.
