#1 2024-06-24 19:39:50
Gregors
How to restrict WLAN access?
Hi there!
How can I restrict WLAN access to a defined list of SSIDs?
TIA
Gregor
#2 2024-06-24 21:49:03
soren
Re: How to restrict WLAN access?
Are you trying to restrict other users from connecting to ssids outside the defined list of ssid's?
If you use interfaces/ifupdown, I think wpa_supplicant should be able to do this, you just need to define the ssid's in /etc/wpa_supplicant/wpa_supplicant.conf as the root user and restrict access to this file and /etc/network/interfaces
