#1 2024-05-12 23:40:37
Miraculix
[SOLVED] Get back the colored output from "Beowulf" in "Deadalus" at startup
1) Copy over "20-left-info-blocks" and "init-functions" from "Beowulf" into /lib/lsb/init-functions.d
2) Remove "00-verbose" in /lib/lsb/init-functions. Maybe you can leave it, I will check it out.
3) Create a file "lsb-base-logging-sh" in "/etc"; enter a line "FANCYTTY=1" and close it
You should be done. As usual usage is at your own risk. Please report problems to me.
Kind regards
Miraculix
PS:
Maybe the admin will ask me to copy over the good old files.
#2 2024-05-12 23:51:31
Miraculix
Re: [SOLVED] Get back the colored output from "Beowulf" in "Deadalus" at startup
I've checked it out; you may leave "00-verbose"-file
KR
