#1 2024-05-01 05:43:14
antn
Debian SD card images - https://sd-card-images.johang.se/
This project is a unoffical, minimal, pure and up-to-date vanilla Debian/Ubuntu Linux SD card images for various ARM-based single board computers (SBCs).
I have used this images to install Devuan in old armv7 but I have to deal with the process of remove systemd and then install all that systemd has removed to have connection again to the net so I can put a Devuan system.
Would it be possible to generate these images for Devuan in the same way? Thanks.
License of the project is GPL3.
https://github.com/johang/sd-card-image … /README.md
Edit: Supported boards: https://sd-card-images.johang.se/boards.html
#2 2024-05-01 08:33:33
Re: Debian SD card images - https://sd-card-images.johang.se/
Maybe you don't know about these images - https://arm-files.devuan.org/RaspberryP … %20Builds/
#3 2024-05-01 12:42:21
vortex
Note that for compatibility and usability of all RPi hardware interfaces, these images are not 'bare minimum', but a pragmatic blend that allows use of networking, bluetooth & video devices, etc. out-of-the-box across all RPi hardware models.
#4 2024-05-01 12:58:43
antn
RPI images are easy to find, but for other arm hardware is difficult to find ready images that boot without problems, where you only have to change the root password. These images works but when systemd is removed you have to install the packages by hand without network or via chroot. Debian with systemd is a useless systemd and everytime is more difficult to remove it without to broke the system.
#5 2024-05-01 13:01:32
antn
While the pictures are the RPI, the supported borads are more from different arm/arm64 cpus: https://sd-card-images.johang.se/boards.html
#6 2024-05-21 18:04:43
antn
Devuan images can be now generated and it have been added to a fork of johang/sd-card-images at https://github.com/watchful-0wl/sd-card-images. There are no pre-built Devuan images there, it is for DIY Devuan builds.
https://github.com/johang/sd-card-image … ges:master
Edit: Original post: https://github.com/johang/sd-card-images/issues/125
