Pages: 1
So I'm trying to install OpenCanary on Daedalus but am hitting errors I don't understand.
First, I clone the repository and start the setup:
git clone https://github.com/thinkst/opencanary
cd opencanary
sudo python3 setup.py installIt runs for a few seconds, then bombs here:
Installed /usr/local/lib/python3.11/dist-packages/opencanary-0.9.3-py3.11.egg
Processing dependencies for opencanary==0.9.3
Searching for zope.interface==5.0.0
Reading https://pypi.org/simple/zope.interface/
Downloading https://files.pythonhosted.org/packages/4e/a2/0c1e3441940174a6b920e029376621ae656770d9221495910ab9b569eec9/zope.interface-5.0.0.tar.gz#sha256=9da542aa8fb13671e3aa03722cf479dc3611a4e767de256629d609bcb2e99285
Best match: zope.interface 5.0.0
Processing zope.interface-5.0.0.tar.gz
Writing /tmp/easy_install-hzhtdxgg/zope.interface-5.0.0/setup.cfg
Running zope.interface-5.0.0/setup.py -q bdist_egg --dist-dir /tmp/easy_install-hzhtdxgg/zope.interface-5.0.0/egg-dist-tmp-ijfust3a
/usr/lib/python3/dist-packages/setuptools/config/setupcfg.py:515: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
warnings.warn(msg, warning_class)
/usr/lib/python3/dist-packages/setuptools/dist.py:285: SetuptoolsDeprecationWarning: The namespace_packages parameter is deprecated, consider using implicit namespaces instead (PEP 420).
warnings.warn(msg, SetuptoolsDeprecationWarning)
warning: no previously-included files matching '*.dll' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.pyo' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
warning: no previously-included files matching 'coverage.xml' found anywhere in distribution
warning: no previously-included files matching 'appveyor.yml' found anywhere in distribution
no previously-included directories found matching 'docs/_build'
no previously-included directories found matching 'benchmarks'
/usr/lib/python3/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 156, in save_modules
yield saved
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 198, in setup_context
yield
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 259, in run_setup
_execfile(setup_script, ns)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 46, in _execfile
exec(code, globals, locals)
File "/tmp/easy_install-hzhtdxgg/zope.interface-5.0.0/setup.py", line 102, in <module>
File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 108, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3/dist-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/usr/lib/python3/dist-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/usr/lib/python3/dist-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 1213, in run_command
super().run_command(command)
File "/usr/lib/python3/dist-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/usr/lib/python3/dist-packages/setuptools/command/bdist_egg.py", line 165, in run
cmd = self.call_command('install_lib', warn_dir=0)
File "/usr/lib/python3/dist-packages/setuptools/command/bdist_egg.py", line 151, in call_command
self.run_command(cmdname)
File "/usr/lib/python3/dist-packages/setuptools/_distutils/cmd.py", line 318, in run_command
self.distribution.run_command(command)
File "/usr/lib/python3/dist-packages/setuptools/_distutils/dist.py", line 987, in run_command
cmd_obj.ensure_finalized()
File "/usr/lib/python3/dist-packages/setuptools/_distutils/cmd.py", line 111, in ensure_finalized
self.finalize_options()
File "/usr/lib/python3/dist-packages/setuptools/command/install_lib.py", line 17, in finalize_options
self.set_undefined_options('install',('install_layout','install_layout'))
File "/usr/lib/python3/dist-packages/setuptools/_distutils/cmd.py", line 296, in set_undefined_options
setattr(self, dst_option, getattr(src_cmd_obj, src_option))
File "/usr/lib/python3/dist-packages/setuptools/_distutils/cmd.py", line 107, in __getattr__
raise AttributeError(attr)
AttributeError: install_layout. Did you mean: 'install_platlib'?
During handling of the above exception, another exception occurred:
File "/home/scott/opencanary/setup.py", line 46, in <module>
setup(
dist.run_commands()
cmd_obj.run()
File "/usr/lib/python3/dist-packages/setuptools/command/install.py", line 74, in run
self.do_egg_install()
File "/usr/lib/python3/dist-packages/setuptools/command/install.py", line 131, in do_egg_install
cmd.run(show_deprecation=False)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 444, in run
self.easy_install(spec, not self.no_deps)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 686, in easy_install
return self.install_item(None, spec, tmpdir, deps, True)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 733, in install_item
self.process_distribution(spec, dist, deps)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 778, in process_distribution
distros = WorkingSet([]).resolve(
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 815, in resolve
dist = self._resolve_dist(
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 851, in _resolve_dist
dist = best[req.key] = env.best_match(
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 1123, in best_match
return self.obtain(req, installer)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 1135, in obtain
return installer(requirement)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 705, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 731, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 924, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1198, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1182, in run_setup
run_setup(setup_script, args)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 249, in run_setup
with setup_context(setup_dir):
File "/usr/lib/python3.11/contextlib.py", line 155, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 190, in setup_context
with save_modules():
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 169, in save_modules
saved_exc.resume()
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 143, in resume
raise exc.with_traceback(self._tb)
yield saved
yield
dist.run_commands()
cmd_obj.run()
AttributeError: install_layoutOffline
Pages: 1
