#1 2024-03-25 11:46:35
[SOLVED] modprobe: FATAL module not found
Like I do every so often, I was having a quick look at my display printout as my box was booting this morning and noticed the dreaded FATAL.
It does not get recorded in dmesg but it does in /var/log/boot:
$ cat boot | grep -i fatal
Mon Mar 25 07:54:36 2024: modprobe: FATAL: Module scsi not found in directory /lib/modules/5.10.0-0.deb10.16-amd64
I had not noticed this before today but then I cannot for the life of me recall when I last had a look at the printout.
Indeed, /lib/modules/5.10.0-0.deb10.16-amd64 has nothing scsi in it:
~$ ls /lib/modules/5.10.0-0.deb10.16-amd64 | grep -i scsi
But a recursive listing gets me a load:
~$ ls -R /lib/modules/5.10.0-0.deb10.16-amd64 | grep -i scsi
scsi
iscsi_ibft.ko
mptscsih.ko
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi:
be2iscsi
esp_scsi.ko
iscsi_boot_sysfs.ko
iscsi_tcp.ko
libiscsi.ko
libiscsi_tcp.ko
scsi_debug.ko
scsi_mod.ko
scsi_transport_fc.ko
scsi_transport_iscsi.ko
scsi_transport_sas.ko
scsi_transport_spi.ko
scsi_transport_srp.ko
virtio_scsi.ko
vmw_pvscsi.ko
xen-scsifront.ko
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/aacraid:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/aic7xxx:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/aic94xx:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/arcmsr:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/be2iscsi:
be2iscsi.ko
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/bfa:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/bnx2fc:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/bnx2i:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/csiostor:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/cxgbi:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/cxgbi/cxgb3i:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/cxgbi/cxgb4i:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/device_handler:
scsi_dh_alua.ko
scsi_dh_emc.ko
scsi_dh_hp_sw.ko
scsi_dh_rdac.ko
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/esas2r:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/fcoe:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/fnic:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/isci:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/libfc:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/libsas:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/lpfc:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/megaraid:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/mpt3sas:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/mvsas:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/pcmcia:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/pm8001:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/qedf:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/qedi:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/qla2xxx:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/qla4xxx:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/smartpqi:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/snic:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/sym53c8xx_2:
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/ufs:
iscsi
target_core_pscsi.ko
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/target/iscsi:
iscsi_target_mod.ko
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/target/iscsi/cxgbit:
vhost_scsi.ko
xen-scsiback.ko
The system seems to be running properly and lsmod gets me this:
~$ lsmod | grep -i scsi
mptscsih               32768  1 mptsas
mptbase                77824  2 mptsas,mptscsih
scsi_transport_sas     49152  1 mptsas
scsi_transport_spi     40960  1 aic7xxx
scsi_mod              262144  9 mptsas,scsi_transport_sas,aic7xxx,sd_mod,scsi_transport_spi,drivetemp,mptscsih,libata,sg
Looking for the location of the loaded modules, I find them:
~$ locate mptscsih
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/message/fusion/mptscsih.ko
~$ locate mptbase
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/message/fusion/mptbase.ko
~$ locate scsi_tr
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/scsi_transport_sas.ko
/lib/modules/5.10.0-0.deb10.16-amd64/kernel/drivers/scsi/scsi_transport_spi.ko
Edit:
Sorry, forgot to add this:
~$ lspci
03:00.0 SCSI storage controller: LSI Logic / Symbios Logic SAS1068E PCI-Express Fusion-MPT SAS (rev 08)
05:00.0 SCSI storage controller: Adaptec AIC-7870P/7881U [AHA-2940U/UW/D/S76]
If everything is working properly (seems to be but maybe it is not) the modprobe: FATAL: warning in the log file should not exist so me thinks that something is probably amiss somewhere.
Any ideas as to how to troubleshoot this?
#2 2024-03-25 16:39:30
Re: [SOLVED] modprobe: FATAL module not found
... how to troubleshoot this?
Found the problem.
A mis-read/malinterpreted sensors-detect printout leading to a misconfigured /etc/modules file which would (had it worked) got me a case temperature reading in my conky panel through temperature sensors in each of my two scsi cards.  Sensors which did not exist.  8^°
Sorry for the bother ...
#3 2024-03-26 02:35:20
Hi, I also get similar module errors in the logs, but when I investigate further I find the system has loaded the module a bit later.
#4 2024-03-26 09:19:25
alexkemp
Hmm
$ less /var/log/boot
/var/log/boot: No such file or directory
Also, nothing in /var/log/ that gets close.
$ cat boot
cat: boot: No such file or directory
Ah, bugger!
