#1 2024-01-30 08:05:21
recklessswing
XFCE panel sometimes doesn't start, giving this error
It gives some dbus error. The name xorg xfce panel was not provided by any .service files
#2 2024-02-01 14:19:11
Re: XFCE panel sometimes doesn't start, giving this error
You're not providing too much info, I'm afraid.
For example what does :
cat .xsession-errors | grep xfce4-panel
say?
If, for some reason, you suspect one of the panel applets (which I do) you could inactivate all, and then restart the panel. Then take one after one back until the problem occurs again.
To restart the panel from a terminal: xfce4-panel -r
(The panel will quit when you close the terminal- so don't close it)
This way of starting the panel gives you good information in the terminal.
